Question about Frigidaire Kitchen Ranges
Frigidaire Gallery Series range/oven showing an F-10 error code on the display. Model# GLGF376D (S). Top burners seem OK, but the oven temps are going crazy. Unit is 2 1/2 yrs new. Does this code mean that the control board is shot? Looks like its gonna be a rough holiday for my family. Happy Thanksgiving to all!
Service tech came the next morning (Nov.26th). The sensor tested out OK. He said that the control board needs to be replaced. Unfortunately there wasn't one available for this model - he had to order it, and he'll be back next week. The good news is that my lovely wife had purchased an extended warranty - so it appears that all parts and labor is covered. We all ended up eating out for the Thanksgiving holiday, and no- the restaurant bill wasn't covered by the warranty. I'll keep you posted on the control board replacement.
Posted on Nov 28, 2008
Self cleaning mode towards the end of its cycle went into a failure code cleared it by flipping breaker. Now when I run bake/convection it runs broil at 600. Lower oven now run under temp.
Amazon.com: Frigidaire Gallery 27 In. Stainless Steel ...
www.amazon.com/Frigidaire-Gallery.../B002HMRIBI
Amazon.com, Inc.
Rating: 4 - ‎4 reviews
When your appliance is delivered it will be brought into your room of choice and all ...The Frigidaire FGET2765KF Gallery Series 27 In. Double Electric Wall Oven, ... Using the "Quick" Pre-heat function on this oven, the timer goes off ... Great, until you check the temperature and find that it's only reached 225 degrees.
Frigidaire FGET2745KF Gallery 27 Double Ele
Frigidaire Model FPDS3085KA getting error code F90 ...www.shopyourway.com > Manage My Life > QuestionsMy wife did start the self cleaning and cancelled it and we have not been able to ...Frigidaire Model FPDS3085KA getting error code F90 ... I have tried holding the lock button down for 3 seconds and that puts it into a mode where it looks like it ...Missing: fget2765kfFrigidaire Range Error Codes for Self-Cleaning Rangeswww.searspartsdirect.com/.../error-codes/frigidaire-self-cleaning-range-e...Find error codes for your Frigidaire self-cleaning range at Sears PartsDirect. ...should only occur when the oven is active or when you attempt to enter a mode.Missing: fget2765kfFrigidaire Self-Cleaning Wall Oven Error Codes ' Sears ...www.searspartsdirect.com/.../error-codes/frigidaire-self-cleaning-wall-ov...
Jan 03, 2016 | Frigidaire FGET2765KF
Getting an F15 error code when trying to start Oven.
Error code f15 'Frigidaire FEB30T7FC Stainless Steel ...
www.faqqq.com/.../error-code-f15-frigidaire-feb30t7fc-stainless-steel-ele...
Error code f15 'Frigidaire FEB30T7FC Stainless Steel Electric Double Oven ... I'mtrying to open up a Unity3D game.exe that is on a remote computer through my main desktop. ... How 2016 will be the start of your virtual reality future - CNET.
Kenmore range shows f15 error code - ApplianceJunk.com
appliancejunk.com > ... > Forum Index > Range, Oven & Cooktop Repair
Oct 31, 2010 - 10 posts - ‎5 authors
Kenmore range suddenly started flashing f15 error code. With Thanksgiving just around the corner, i need help with this repair. Thanks.
Dec 30, 2015 | KitchenAid Kitchen Ranges
Why do my top burners do not work, but oven and inicator lights and clock work
Good Afternoon Friend, this is Z. I am happy to assist you!
I understand the burners on your Frigidaire range are working, however you are having trouble with your oven. Do you have an electric or gas range? Can you elaborate prior to your problems any other symptoms or specific error codes before having this issue? Also, may I have your model number please? The serial tag, which lists your model number, is typically located in the storage drawer, on the right side. With this information I can assist you better in pinpointing the problem. Thank you!
Jul 13, 2014 | Frigidaire Gallery GLEFM397DS Electric...
My oven when turned on goes to F1 and the heat is like broil...only the top burner comes on????
Hello,Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Thanks
May 28, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Frigidaire Gallery Professional Series Oven Won't Turn On
Suspect a bad oven element. Worse case is a bad oven relay on the clock control board.
Sep 20, 2009 | Frigidaire Gallery GLEFM397DS Electric...
Frigidaire Gallery ES340 electric range, burners will not turn on
Okay,
1, check your power, locate your breaker for the range. turn the breaker off and turn it back on.
Your Range it is electronic control on the Oven but not the Stove Top heating elements.
After you reset the breaker and it still not work.
Please let me know more about the unit.
When you purchase.
How/when it happen.
What is the indicator showing.
nguyen@ite.net
Jun 09, 2009 | Frigidaire 30 in. Electric Gallery Series...
Frigidaire Range - Oven does not work
If your ignitor looks real dull orange then that is what is wrong. It needs to be bright as the sun or it is weak.
Dec 18, 2008 | Frigidaire GLGF386DC Stainless Steel Gas...
My kenmore oven is beeping and will not stop. the display shows F-1.
Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacment of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal checksum error.
Dec 16, 2008 | Ovens
Frigidaire Gallery Professional Series - No clock/oven functions
i have an old model of the fridgedare gallery professional series stove. After self cleaning, the ignition sparks for the burners will not come off, they keep clicking and only stops when i pull out the plug. can you help me with this situation?
Nov 01, 2008 | Frigidaire FGB24S5A Gas Single Oven
1998 frigidaire wall oven intermittant f1 code
F0 & F1 EOC (Electronic Oven Control) failure Replace EOC (Electronic Oven Control)
Aug 02, 2008 | Frigidaire Gallery GLEFM397DS Electric...
Kitchen Ranges Logo
222 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
