Question about Microwave Ovens
Sharp r-21 atp runs and seems to work as normal but no heat at all.
  • Microwave Ovens Master
  • 9,098 Answers
If, when you hit Start, the fan comes on, you either have a bad relay (RY2) or a bad latch switch (the bottom, outside switch) or a failed part in the high voltage section, most likely a bad connection at the FA terminal of the magnetron, or a bad magnetron itself.
If, when you hit Start, the fan does not come on, you have a bad 1st interlock switch (the top switch).
We have the service manual for the similar model R-21AT and have uploaded it to our site here to help you.
You will need the
free Acrobat Reader to view or print it in case you don't have it already.
Please note that some parts for this model are not the same as for your variant, so please contact the distributor (below) for the proper part number.
The best place to order Sharp parts is Tritronics. You can also call them at 866-779-5835.
Posted on Nov 27, 2008
My question does this model have in the ceiling mould these three small circle indents or are they defects?
The indents are probably there to make the ceiling stiffer, and are not likely defects. Sharp, historically at least, has had a tendency to use thinner metal parts than other manufacturers, but it hasn't seemed to reduce reliability significantly.
If you run the oven with food in it, a sizzling sound could be a sign of a problem, or it could be normal for this oven. Ask the dealer about the noise.
Sep 22, 2016 | Sharp Microwave Ovens
Sharp r2103j microwave lights on doenst heat up
No heat, but unit seems to run normally in all other ways - possible causes: failure of high voltage rectifier, shorted high voltage capacitor, magnetron failure, power transformer open/shorted winding(s), thermal protector open, or no 120 v supplied to power transformer.
May 04, 2014 | Sharp R310J 1200 Watts Microwave Oven
Sharp microwave wont heat at all.
looking for a tray or plate roller wheel for a Sylvania model SM81001 ser. no. 0008001033
Nov 24, 2013 | Sharp R-1870 Convection/Microwave Oven
GE microwave JEB1860 runs like normal but no heating. 21 months old. What is causing the no heating.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 gfsghhgs
Aug 05, 2010 | General Electric JEB1860 1100 Watts...
Sharp modelR1381 everything works but will notheat
If it runs and makes normal noise but just no heat, issues is either a loose connector to magnetron or at diode to capacitor. Be careful with capacitor because it stores thousands of volts.
Nov 21, 2009 | Sharp Microwave Ovens
Sharp R-963 900 Watts Convection / Microwave Oven does not heat
This isn't exactly a solution but information that might help other Sharp product owners.
I acquired a Sharp Combi Microwave oven - an expensive looking stainless steel piece of equipment. All works except the LCD screen. It seems that others have this problem too. I am not sure of the guarantee BUT In the UK I phoned the Trading Standards Officer and his info is very interesting indeed:
Apart from the normal guarantees, any equipment sold should have a normal useful life of 6 YEARS! Therefore if the item has a 'generic or 'inherent' fault the cmpany should repair or replace the item up to the 6 year period.
This was news to me!
Why should companies sell expensive stuff when the is something just waiting to go wrong? They just shrug their shoulders and say it is out of guarantee! In the UK, at least, that is not quite the end of story.
So I intend to chase up Sharp and see what they have to say about the fault on mine.
Ralfwil
Apr 06, 2009 | Sharp R-963 Convection/Microwave Oven
My sharp microwave r- 490f runs normally but does not heat Ajay
It's your MAGNATRON, the thing that heats the food. mine did the same thing, luckily it was still under warranty. Good luck
Sep 28, 2008 | Microwave Ovens
Sharpe microwave oven
We have the owner's manual for the model R-21AT and maybe it will be close enough to the suffix P model to help you?
I've uploaded two versions of them here and here.
Hope this helps.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Apr 26, 2008 | Microwave Ovens
Fan runs when door is closed - no heat
This is normally 1 of the interlock door micro-switches not working.
Jun 20, 2007 | Sharp R-1490 Microwave Oven
Microwave Ovens Logo
340 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
