Question about Disney DT1350-P 13" TV
Disney tv picture rolling
We have tuned in our tv but the picture won't stop rolling up
  • Claire Young Jan 05, 2007
    we have opened up the tv but we can't find the v synch
Many older tv's had a vertical synch adjustment knob which would correct this, but I doubt yours has one thats accesible without opening the case. If you decide to open the case, be very careful of the flyback and other high voltage points, even when it's unplugged. possibly there will be a trim pot on one of the boards silkscreened V SYNC.
Posted on Jan 04, 2007
VERTICAL LINES ON OLDER ZENITH FLOOR MODEL TV
this was adjusted by the fine tune on the selector It is the picture not being held in place by being out of tune Same as if the picture goes sideways On the real old units there were 2 knobs to make these adjustments.
Jun 10, 2013 | Televison & Video
Zenith TV modelB25A74R picture rolls
can you please tell us what model maker of your TV unit..
May 07, 2008 | Zenith B25A76R 25" TV
Disney tv model # dt1350-c looking for speakers to this tv.
It can be bought from electronic spare part selling shops. Go with the damaged speaker. Let it be in hand as sample. It won't cost more.
May 11, 2012 | Disney Lightning McQueen TV
My child had her remot to her disney tv ad thevolume went out. I want to know wats wrong with tv. I tried everything and volume won't comeback on.
Check if you mistakenly hot the mute button. If not check other remotes, i.e cable, set top box remote volume. Thumb me up if I helped. :)
Jul 02, 2011 | Disney DT1350-P 13" TV
TV was working fine, moved to new home and the problem began. Picture rolls to the right, picture is fuzzy and will clear up somewhat at times. The picture will stop rolling at times also,but may be a half...
TV was working fine, moved to new home and the problem began. Picture rolls to the right, picture is fuzzy and will clear up somewhat at times. The picture will stop rolling at times also,but may be a half and half screen. Sound is fine, can you help me with this problem please.
Jun 23, 2010 | Sony KP-51HW40 51" Rear Projection...
Getting a sound and picture but with a strange noise
tap tv with palm and see if it stops if it does you have bad solder conection
Oct 19, 2008 | Disney DTD1363-CAR 13" TV/DVD
Disney tv has a picture but no sound
Common issue with some of the TV sets. If your headphone socket is squeeky clean it is more than likely a manufacturers fault. Please seek a re-fund or contact the manufacturer
Oct 12, 2008 | Disney 13" TV
Disney TV (only 5 months old) just stopped working.
I have a Disney cars tv with built in dvd player and after 2 months it stopped working. The power will not turn on, the light just flashes once and then goes off. I have tried replacing the fuses and it did not work, could you please help me.
Jul 05, 2008 | Disney 13" TV
Picture is Rolling..stops after some warm-up
I have seen this many times. There is a 9 volt regulator on the small signal board that causes this. The regulator goes bad and the 9 volts starts dropping, especially at start-up when the regulator is cold. If the voltage is below 8 volts then the picture gets dark and the vertical becomes unstable, with the picture squeezing down and/or rolling. As the regulator warms up the voltage starts rising back towards 9 volts and the symptoms start clearing up. There are 3 regulators in a row on the board and the regulator in the middle is always the bad one. Replacing that regulator should cure your problems but it should be replaced by someone experienced in servicing Mitsubishi projection TV's because pulling the chassis out is quite tricky.
Aug 05, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Disney princess tv
your receiver's vertical sync is out of control, i suggest you bring it to a technician
Jan 07, 2007 | Disney DT1350-P 13" TV
Disney DT1350-P 13" TV Logo
67 people viewed this question
Top Disney Televison & Video Experts
Jaime Hernandez
Demonic-2011
Demonic-2011
Are you a Disney Televison and Video Expert? Answer questions, earn points and help others
