Question about Craftsman 26 Hp 54" Deck Yard Tractor
Deck Height Adjusting
I removed the deck height adjusting arm to repair a broken plunger When I reinstalled the arm, the arm which previously raised the deck from the lowest position on the arm , now picks up the deck half way through its travel and does not lift the deck fully. I tried adjusting the deck height knob on the left to no avail. Are there special installation steps for reinstalling the arm?? Is it spring loaded??
Craftsman Garden Tractor 54" deck
Please let me know
Thanks
Chris
    Loyalty:
    Visited the website for 30 consecutive days.
  • Craftsman Master
  • 1,489 Answers
You should have holes on the arms of the adjuster look for the most worn hole that is where the studs should go
Posted on Dec 30, 2017
4 Suggested Answers
SOURCE: Repair Parts Manual / Book Service Garden Tractor
C I am thanking a lot for dealing with my matter and very much I am counting for your help in getting the list of the spare parts with catalogue numbers of my model of the garden small tractor.
I am greeting Ted
Posted on Nov 25, 2008
  • 57 Answers
SOURCE: replace drive belt
Not an easy fix. There are likely 2 belts which should be replaced as a pair. Engine pulley must be lowered to remove long belt. Pay special attention to belt routing. Most times small belt requires removal of transmission pulley. Good Luck.
Posted on May 15, 2009
SOURCE: 2010 Craftsman Lt 2000 deck height adjustment?
just bought a new craftsman riding mower. model lt1500. 17.5 hp with 42 inch deck. first time using I had the deck hight handle set on 6 the highest setting and still cuts grass to short, matter of fact it scalped the grass. anyway to set the deck higher. Its only 3 days old and still under warranty but the sears store is 20 miles away and I rented a trailer to go pick it up and hate to go rent another trailer to bring it back if its just a simple adjustment.
Posted on Jul 29, 2011
I am trying to figure out how to adjust deck height
most mowers have a lever to raise and lower the deck . that is the height adjustment also then the wheels need adjusted to meet the ground . without a make listed we really can do no more
Sep 03, 2016 | Garden
How to level the mowing deck on 2002 John Deere (Scotts) 42 " mower. Mower deck drags on right side. Mower height adjuster doesnt work seems jammed.
Have a look underneath while someone operates the height adjustment. There's probably a link arm come off which does deck height. Go to google images for this machine, type height adjustment and look at the pictures if you don't have a handbook. Google JD handbooks and see if you can find a free download.
Aug 13, 2016 | John Deere Garden
How can I hook up the snowblower attachment?
if its a garden tractor then you will first need to remove the mowing deck , this is easy if you have something to run front wheels up on to allow you room to pull deck out the side ,set deck height all the way down, save the drive belt . save the deck pins . locate the front chassis mounting arms and drive up to blower allow rear mounting arms to go between the two front wheels till the back of blower meets the front of chassis mounting arms (tight fit) install pins at all four points of contact , install belt to blower and front pto of machine (install any guards for belt) then raise blower from ground with deck height adjustment lever (it might feel heavier) test it to prove good contact your done
if its a three point (this is the reason I own one know) you back up to blower lower the mounting arms , engage the quick pins , install the drive shaft between the blower and machine with a quick spring snap , connect top link to tractor get back in seat and start machine raise three point an go !!
Jan 19, 2016 | Garden
I have a John Deere LX178 lawn tractor and the mower deck will not raise/lower. It is all the way down and pushing in the button is how i've ALWAYS adjusted the height. It will not budge
1) NEVER adjust to where the deck wheels touch the ground. The wheels are to ride 1/4" off the ground. 2) The long lever to your left which raises & lowers the deck has 3 settings. 1- Fully back toward you which has the deck raised (called transport mode). 2- Halfway down which is the normal mowing mode (called float mode) 3- Fully away from you which sets the deck fully on the ground. This mode is ONLY used for VERY rough terrain where the deck risks getting pushed into "transport" or "full up" mode & getting stuck there. 3) On front-to-back tilt, the front should be 1/2inch lower than the back for least damage to the grass. Ok-now to adjust "cutting" height. 1) Park on a level, flat surface. 2) Pull the deck lever fully back toward you to put the deck into "transport" mode. 3) twist the "cutting" height knob (just below your seat) to the height you want the grass cut. Has choices by 1/2" increments from 1" to 3.5". The deck in "transport" mode is 4". 4) Lower the deck lever to the midway/"floating" mode point. 5) Adjust each deck wheel with its own peg & pin to have at least 1/4" clearance from ground. Thats it for "cutting height" adjustments
call your deere dealer,
Troubleshooting
Service Mower
cant find info for you,call dealer
Jun 03, 2015 | Garden
I need to adjust my scag mower deck
The mower deck can be adjusted from a height of 1.0 inch to 6.0 inches at 1/4-inch intervals. To adjust the cutting height:
1. Disengage the power to the cutter blades.
2. Push the cutting height adjustment foot pedal all the way forward using your right foot until it locks in place
3. Insert the lanyard pin into the cutting height index at the desired cutting height. Push forward on the deck lift foot lever, hold in place and pull back on the deck release lever. Slowly release the foot pedal. A deck height decal is located on the cutting height index as an aid in adjusting the deck to the desired height.
Aug 18, 2013 | Scag STT61V-27CH Hydrostatic, Gas Turf...
Troy Bilt zero turn Mustang Xp 50" deck height. My
raise the back as high as you like but unless you raise the front as well it will still cut short. If you want it higher and there appears there is no adjustment left you may have to re thread the adjusting screws to shorter dimensions or if it is on levers you may have to drill new holes further up the bars.
Jun 02, 2013 | Garden
Fix deck height adjustment on a Snapper Comet 308X.
reset the chains to raise it up
Apr 19, 2012 | Garden
Deck only raises a little bit, not the way it is supposed to. Selections 1-4 is the same level, resting on the ground. how do i fix this
The bolts or wing nuts for the deck adjustment have likely come loose or off entirely from the raising/ lowering undercarriage.
Once you have identified the loose or missing nuts (and replaced, making sure to add lock washers) then move the mower to a flat, level surface and move height lever to the lowest setting (some mowers have a flap over an ultra-low setting for this purpose).
Now tighten the nuts on the raising / lowering arms. You should now have normal control over the height. Farmerbear at FixYa.com
Sep 28, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Jul 31, 2010 | Craftsman 20 hp 42 in. Deck Yard Tractor
Hower do you do the adjusting for height on the
The dial only sets the height or the total deck, it is more of a stop than an adjuster.
If it seems too low in the front, you can adjust it by tightening the nuts on the 2 bolts/pins that are attached to the deck and the frame.
First of all, though, check your tire pressures, 10 psi in the rear and 14 psi in the front. If front pressures are too low, this will make a huge difference in your cut. You want to adjust the bolts an equal amount to maintain your side to side level keeping in mind that it should have 1/4 to 1/2 " difference front to rear.
Make your adjustments on your driveway or garage floor so you have a flat level surface to go by.
If you make these adjustments and it still scalps, you will either have to set the deck to cut a bit higher or approach the high spots from a different angle or remember to lift the deck up a bit with the handle when you get to those areas
Hope this solves your problem
Nov 03, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 26 Hp 54" Deck Yard Tractor Logo
139 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
