When I press 'start copy' the printer does not pull the paper from the tray.I have tried with various makes of paper.Have only had the printer for two weeks and have done printing with it before with no problems. Please help I have spent hours on this and am demented!!!!!
  • babs kay Nov 25, 2008
    Your reply was to play with the gears------ as an OAP I have no idea how to do this.
  • 162 Answers
You can try to clean the printer and get a temporary fix. I suggest to have it replaced as it is showing some potential headache in just under a month.
Posted on Nov 25, 2008
  • 1,879 Answers
If it does go to the motion of printing without the paper, look at the paper loading tray, look for the piece that grabs the paper and is usually rubber mounted and swab it with warm water.
if the issue persists, get a replacement asap. you only had the printer for two weeks and it does not function properly.
  • 10,594 Answers
Looks mechanical problem with gears, I hope its still under warranty so get replacement from store.
  • 19,396 Answers
Check that the tractor that picks up the paper is not stuck , try playing with the gears.
  • Ginko
    Ginko Nov 25, 2008
    To start , ensure that paper is loaded correctly.
    Try the following:
    1. Make sure there is paper loaded in the tray. Fan the paper before loading.
    2. Look for paper jammed in the printer.
    3. Adjust
      the paper guides to the correct markings in the tray for the paper size
      you are loading. The guides should be snug, but not tight, against the
      stack.
    4. Make sure the printer supports the paper in use.
    5. Make sure there is only one type of paper in each tray.
    6. Make sure the tray is inserted correctly.
    7. Uncurl any curled paper by bending it in the direction
      opposite the curl."
    from canon.
    If that does not work , try playing with the gears at the back.
    If still no luck, the printer has a mechanic problem and must be inspected by a technician.
Canon PIXMA MX880 will not pull paper from front tray when copying. The MX880 will pull paper from the front tray when printing from the computer and the rear tray when printing envelopes. I only have a...
The reason for that is the front is the paper output tray, the rear tray is where you load the paper. Anything you print, copy, or scanned (to print) will come out the output tray (in front) and will pull paper from the rear tray.
Nov 03, 2013 | Canon PIXMA MX860 All-In-One InkJet...
I am trying to just make a copy and the printer is pulling paper from the photo tray, I'm not sure why, I'm pressing the copy button.
Go to front panel of the printer
press set up then got to paper tray settings
you can choose adf tray or the main tray for pulling out papers
it may help you a bit
try also to power cycle the printer
Hope my idea will help you a bit just give it a try
Thanks
Mar 27, 2011 | HP Photosmart C5580 All-In-One InkJet...
I use a CM2320nf MFP connected to Windows XP. The unit seems to be defaulted to print 2 pages - and for double sided copies, it stops after 2 pages, then the Cleaning window pops up, then I get an error...
Problem 1 :
As far as the machine printing 2 pages per job. To fix this it's usually the default number of copies the printer is set to. To change/ confirm the setting is set to one:
Press the menu button
Arrow down to -> Printing, Press the green check to enter the menu
Arrow down to -> Copies Press the green check to enter the menu
Change or confirm the value = 1, (Based on your question this might be set to 2) Press the green save the value.
* If your number of copies is set to 1 and the machine is still printing 2 copies, then the problem relays in your print driver.
Problem 2: General Misprint Error message something like 41.3
2 things to check:
1st - Press the menu button
Arrow down to Paper Handling, Press the green check to enter the menu
Now you will see options like Tray 1 size - Tray 1 type. Here their will be a option for each tray installed on your machine. You will go into each tray option and confirm the paper size and type.
Example
Tray 1 Size = Envelope #10 (This is the manual feed tray)
Tray 1 Type = Envelope
Tray 2 Size = Letter
Tray 2 Type = Plain
To perform arrow down to tray X size press the green check to access the menu, arrow up or down to select your paper size. Once the paper size is selected press the green check to save it. repeat for each tray.
2nd -
Pull out your tray and remove the paper, towards back of the tray you will see a guide (Tab) in the middle of the tray which allows you to expand the tray to accept various paper sizes, Please confirm the guide is set to the correct type. If your using letter, make sure the guide is set to letter (LTR) you can see these codes by looking at the base of the guide, their is a little arrow pointer.
Hope this helps
Jan 14, 2011 | HP LaserJet 2420 Printer
Printer comes up with (caution! aps size error) error message after i press the start button in the control to make copies.
1-Press "Tray" button or "Paper" button from the panel.
2-Select the paper size from the menu shown.
3-Now press the start button. No caution will appear.Next time use the same procedure for making copies.
Dec 28, 2010 | Konica Minolta bizhub 180 All-In-One...
My copier wont pull the paper from the tray...it has a full load of paper in it but when I go to try and make the copy it won't pick it up and then it flashes "P" like it is out of paper
Have you taking out the paper tray and look inside for a piece of paper jammed behind the paper tray. Also, make sure the paper guides in the paper tray are tight against the paper in the tray & make sure the copier is on a level surface. You may also, need the paper feed rollers or clutch. If you need to make copies, use the by - pass tray on the right side.
Apr 05, 2010 | Sharp AL 1631 Copier
PAPER JAMMED-PRINTER HL5150D
Hello a_bowen1
You can clear the jammed paper as follows.
If the jammed paper is removed completely by using the information in the following steps, you can install the paper tray first, and then close the front cover and the printer will resume printing automatically.
If the printer does not start printing automatically, press the Go button. If the printer still does not start printing, please check that all the remaining jammed paper has been removed from the printer. Then try printing again.
Note
    • If a paper jam occurs when using the optional lower tray unit, check for correct installation of the upper paper tray.
    • Always remove all paper from the paper tray and straighten the stack when you add new paper. This helps prevent multiple sheets of paper from feeding through the printer at one time and reduces paper jams.
  1. Pull the paper tray completely out of the printer.
  1. Pull the jammed paper up and out of the printer.
  1. Press the cover release button and then open the front cover.
  1. Pull out the drum unit assembly. Pull the jammed paper up and out of the printer. If you cannot remove the drum unit assembly easily at this time, do not use extra force. Instead, pull the edge of the jammed paper from the paper tray. If the jammed paper can not be pulled out easily, turn the jam dial towards you as you gently pull the paper out.
hl50_05712.gif Caution
    To prevent damage to the printer caused by static electricity, do not touch the electrodes shown below.
  1. Open the face-up output tray. Pull the jammed paper out of the fuser unit. If the paper jam can be cleared, go to Step 7.
Note
    If you have to pull the paper toward the back of the printer, the fuser may get dirty with toner powder and it may scatter on the next few printouts. Print a few copies of the test page until the scattering of toner stops.
chap0615.gif Caution
    After you have just used the printer, some internal parts of the printer are extremely hot! Wait for the printer to cool down before you touch the internal parts of the printer.
  1. Open the jam clear cover. Pull the jammed paper out of the fuser unit.
  1. Close the jam clear cover. Close the face-up output tray. If the paper jam still cannot be cleared, for HL-5130 and HL-5140 users go to Step 10, and for all other users go to the next step.
  1. Pull the Duplex Tray completly out of the printer.
  1. Pull the jammed paper out of the printer or the Duplex tray. Put the Duplex tray back into the printer.
  1. Push the lock lever down and take the toner cartridge out of the drum unit assembly. Take out the jammed paper if there is any inside the drum unit.
    Put the toner cartridge into the drum unit until you hear it lock into place. If you put it in properly, the lock lever will lift automatically.
hl50_047.gif Caution
    To avoid print quality problems, DO NOT touch the shaded part shown in the illustration.
    If you accidentaly touch the shaded part, wipe the surface with a dry lint-free soft cloth.
  1. Put the drum unit assembly back in the printer.
  1. Put the paper tray in the printer.
  1. Close the front cover.
Good Luck and don't forget to leave a rating based on my solution:
Mark
Apr 04, 2009 | Brother HL 5150D Laser Printer
Only 4x6 tray prints clearly
For this concern try pressing "copy+cancel" for media calibration then try again, make sure you have an A4 paper loaded. If this doesnt help you out try using the Kodak website www.kodak.com/go/itg and use "image quality" for class.
Oct 21, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
HP P3005 Will not pull from Tray 1
Click File > Print > Properties to check your settings.
To verify that tray 1 is working, put paper in tray 1. Press green check until you see Information Menu. Scroll using arrows until you see Print Menu Map then press green check. If it prints from tray 1, your problem is not with the printer, but with the PC settings.
i has follow this step, but need to press green check button to resume print menu map.
tray 1 manual feed set to A4 paper plain size
manual feed is on.
there is paper on tray 1
ps setting tray1 manual feed is A4 plain size paper.
send print to tray1 manual feed even there is paper at tray 1
i still need go to the printer and press green check button to resume print
Sep 23, 2008 | HP LaserJet P3005n Printer
Cannot print photos from photo tray. automatic paper sensor failed.
Issue An Automatic paper sensor failed. error message displays on the printer screen when the paper sensor is obstructed or damaged. Solution Follow the steps below to resolve this issue.
  1. Move the printer out of direct sunlight.
  2. Press the OK button.
  3. Try printing again.
Jul 06, 2008 | HP Office Equipment & Supplies
Paper Jams on letter tray
The paper pickup rollers are dirty and needs cleaning. take out trays and give it a wipe with damp cloth, if problem remains than need to replace the rollers
Oct 12, 2007 | Canon imageRUNNER 3300 All-In-One Laser...
22 people viewed this question
k24674
jasbo
jasbo
