I have connected the USB cable to my laptop and camera and removed the memory card. What is the next step?
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
SOURCE: Help! My pictures are trapped on my digital camera!!
On PLAY mode, with a valid memory card inside, press MENU/SET, goto to COPY, select internal--> memory card, select YES, and then MENU/SET.
You better charge your battery before doing copy. Don't turn off the camera during copying.
Good luck.
SOURCE: I put a 4GB Sandisk SDHC card into my Panasonic
no way to solve...only SD is applicable...4G SDHC is not suitable for it
SOURCE: memory card locked
There is a switch on the SD memory card, slide the switch to unlock position before you insert the card into your camera.
More detail, see here How to fix a ‘card locked’ problem
SOURCE: Pictures will not upload to laptop.
I had a similar problem recently - the computer wasn't even recognising that it was plugged in. I eventually took the battery out and charged it up, then later it worked perfectly. I hope this is helpful to you.
SOURCE: Panasonic Lumix DMC-FS5 cant upload photos!!
Did your friend use the "safely remove hardware" function when removing your card from her computer? That could corrupt your card if she didn't. Try this...take your card to a store like Walmart that has a Kodak picture kiosk. They can usually read everything on a card. There, you can print the pics or even make a cd of them. Afterwards, format your card in your camera.
