Question about HP LaserJet 9500n Printer
57.70 error for hp colorlaserjet 9500n
How i can solve this error codes to my printer hp lj 9500n
    Champion:
  • HP Expert
  • 202 Answers
This is the fuser fan error replace them ur problem will be resolved
Posted on Jul 20, 2010
57.7
Posted on Apr 30, 2009
  • 412 Answers
6L/5L Check memory card compatibliity - 1,2,4,8 MB, 5 volt, 70 nanosecond or faster6P/5P/5 Main motor problem, check gear train for binding. Check connections to DC controller - replace main motor
4L/4 Main motor problem, check gear train for binding. Replace main motor
IIIP/IIP+/IIP Error 57-1 Incompatible memory can be either top or bottom slot. Also check motor cable connections. Replace main motor. Can also be DC controller.
5Si/4+/4Si/IIISi (X=2, 3 or 4) Fan motor faulty, check fan number X or duplexor fan and replace as necessary
5 Main motor failure - replace main motor
4+ 57.1 Gears are siezed, motor is bad or DC controller is bad
4Si/IIISi 57.1 Gears siezed, faulty top cover switch, faulty AC interlock switch, J010 loose or faulty, bad main motor PCA
LJ 4000/405 An error occurred with the Fan’s motor. X = Description
4 Printer Fan 7 Duplex Fan
1. Check the Fan’s connector and make sure the Fan is not blocked.
2. Replace the Fan.
LJ 5100 A temporary printing error occurred. x = description 1—printer fan
1. Check the fan connector and make sure that the fan is not blocked.
2. Replace the fan.
LJ8100/8150 A fan motor failure occurred. All fans are enabled to low speed operation
at power on. Fans will go into high speed operation during the print cycle.
X Description
2 Fan 3 - Formatter Fan (intake)
3 Fan 2 - Laser/scanner (exhaust)
5 Fan 1 -Low-voltage power supply (exhaust)
6 Fan 4 - Face-down delivery (exhaust)
9 Fan 5 - Tray 1 fan
A temporary printing error occurred in one of the printer fans. X represents the fan motor number associated with the error. For example, 1 = fan motor 1. Power the printer off/on to clear error. Replace appropriate fan as needed.
Posted on Mar 09, 2009
  • remoteserver Mar 09, 2009
    the main problem seems in --
    1. The cooling fan in the optional duplexer is bad.
    1. Replace the duplexer fan.
Service error 494co6
check your print Que to see if you have a corrupt print job. cancel any and all prints in there, if any. if that doesn't solve it check/upgrade firmware or replace formatter board.
Nov 09, 2015 | HP LaserJet 4250n Printer
Hp color lj 9500 printer 57.70 error
That error code indicates a failed fuser fan. You will need to get it replaced. PN: RH7-1522-000CN
May 02, 2011 | HP LaserJet 9500n Printer
Hp color laserjet 9500 error code 57.70
Fuser fan is shot. Has to be replaced.
Rear, right side, the lower fan
Dec 28, 2010 | HP LaserJet 9500n Printer
I have the hpcolorlaserjet 9500n shows error code 50.6, how to solve
50.6 error is an open fuser heating circuit
between the fuser and low-voltage power supply.
Problem could be the fuser, the low voltage power supply
or the DC Controller.
The 1st thing to do is replace the fuser. If you have another one.
You should really call a printer tech to look at it.
Dec 16, 2010 | HP LaserJet 9500n Printer
I have an hp LJ 9500 and the paper keep jamming
first check for the life of maintenence kit if it expires then
replace the maintenence kit / clear the position where the paper jaamed
in maintenence kit all the roller & fuser replaced .
Apr 27, 2010 | HP LaserJet 9500n Printer
How do you resolve 59.30 error code on HP color laserjet 5550
finally i solve this problem hp colorlaserjet 5550 error 59.30 same with an error 59.40 ERROR this is occurred with the fuser motor during startup or not rotating. take the left cover off and replace the motor. hope this will help.
Jun 09, 2009 | HP LaserJet 5550 Printer
50 .2 Fuser Error in HP Laserjet 4100N
you need an maintenance kit 4100
ACC C8057A 4100-mk-c4110a-mini.jpg Maintenance Kit, Fuser, 110V, LJ 4100 LJ 4100 Series ACC C8057-67901 4100-mk-c4110a-mini.jpg Maintenance Kit, Fuser, 110V, LJ 4100 LJ 4100 Series ACC C8058A 4100-mk-c4110a-mini.jpg Maintenance Kit, Fuser, 220V, LJ 4100 LJ 4100 Series
Selected Item RG5-5069-000 See RG5-5069-090 Not Available 0
Alternate Item(s) RG5-5069-090 Fuser Film ***'y, 220V, LJ 4100 180.50 2 http://www2.printerworks.com/cgi-win/tpwall.exe/find?RG5-5069-000
HP LJ 4100 Fuserkit RG5-5069 HP
Dec 11, 2008 | HP LaserJet 4100n Printer
57.70 error messages for hp printer lj 9500n
Error 57 is generally a fan fault ; on the LJ9500, 57.70 is indicating a fault with the fuser fan in particular.
plz do rate this post
Nov 25, 2008 | HP LaserJet 9500n Printer
from hp repair manual
HP LaserJet 9500n Printer Logo
4,485 people viewed this question
Ben Johnson
