Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Ice maker stopped working in refridgerator
How do i correct this?
  • KitchenAid Master
  • 5,568 Answers
Water flow is governed by a solenoid valve which is controlled by a timer that sets the cycle for all of the icemaker functions. The timer is controlled in turn by the switch that is actuated when the bin is full. One of these three is malfunctioning and to determine which is at fault will require the removal of the icemaker mechanism (to check the switch) and possibly sheet metal on the back of the fridge.
You will also need a multimeter of some kind to check for switch operation and continuity of the solenoid coil. Adequate instruments can cost as little as $3 and in any case under $20, have digital displays and are normally accompanied by some instructions in Chinglish which are sometimes pretty entertaining.
Posted on Nov 25, 2008
SOURCE: Refridgerator ice maker not making ice
i have the same problem with mine it just happened.i checked the tube and it was forze up.what is the best way to unthaw it? using a hair dryer?please let me know.thanks
Posted on Mar 16, 2008
cresguy
  • 75 Answers
SOURCE: Not making ice
The oil from the compressor has pumped up to the top part because of it only the ice maker s not workind change the lead valve of the compressor which can rectify your problem
Posted on Jul 25, 2008
geemarie
  • 876 Answers
SOURCE: ice maker kitchenaid
You did remember to turn it back on? Mine has a handle that detects when the tray is full and you flip it up to turn it off and down to turn it on. Good Luck
Posted on Aug 01, 2008
peyton32034
  • 410 Answers
SOURCE: Ice maker stopped working
if you will remove the front plastic cover on the icemaker take a look at the drive gear. see if the 2 center pins are still present this is a common problem one of the pins will break off causing the gear to pull loose and loose electrical contact for the icemaker motor. replacing the motor module partnumber 8201515 will fix your icemaker thanks for using FixYa Peyton
Posted on Feb 18, 2009
  • 153 Answers
SOURCE: Ice Maker
well ur refrigretor is;nt producing enough gas to produce ice make sure u hire some expert who can examin and solve it.
Posted on Jul 21, 2009
Newly installed ice maker two days old, not dropping ice, frididaire refridgerator
Ice maker under warranty have them look at it will not cost you anything.
Aug 29, 2014 | Kitchen Appliances - Others
My Whirlpool refridgerator has water in it. Where could it be coming from and how do I fix it.
Water must be getting melting from freezer section/.See if over ice is getting collected in freezer vents and freezer walls.
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 21, 2012 | Whirlpool Refrigerators
Whirlpool refridgerator is leaking water on the freezer side (side by side refridgerator) onto the floor. The ice machine was overflowing with ice and has frozen ice in the ice maker that won't budge. We...
WAS IT LEAKING FROM INSIDE THE FREEZER OR FROM BOTTOM OF FRIDGE? ONCE IN A WHILE YOU NEED TO TAKE OUT THE ICE BIN AND DUMP ICE OUT AND CLEAN IT. HOW CAN THE ICE MACHINE OVERFLOW WITH ICE WHEN THE ICE IN THE TRAY WON'T BUDGE? NEED CLARIFICATION. SOUNDS LIKE YOU EITHER HAVE A BAD ICE MAKER MODULE OR THE SOLENOID FOR THE ICE ON THE WATER VALVE IS BAD.
Jan 24, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
My ice maker on the freezer side door stopped working so I changed out the motherboard CCA in the back of the refridgerator & it started working again but the water did not. I need to replace the...
Blake are you talking about the dispenser control board? The ice maker tells the water control valve to come on for the preset amout of time to refill the ice trays most times about 7.5 seconds. and filling ice maker with tap water will test icemaker. If water freezes and the ice dumps the signal is sent to the water control valve Click here=> WR57X10050 here is a service manual=> PROFILE ARTICA SERVICE MANUAL CLICK HERE Have questions you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, Thanks, Sea Breeze
Jan 22, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
The ice maker stopped working .There is water in the plastic tube in the back of the refridgerator but it only gets to about 3/4 of the way up the tube. The water dispencer stopped working years ago but...
Pour about 1/2 cup of water into ic emaker . If it dumps the cubes , then replace the water valve . If it doesn't , replace the ice maker . Also make sure the fridge coils are clean and free of dust , lint , pet hair , etc..
VE6GAR 73 88 99...thumbs up..
Aug 10, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Our Hotpoint side by side refridgerator, the ice/water not workin
It sounds like you have a failing relay/valve that wont stay open when current is passed through them, check there first otherwise your control board could have water/heat damage remove inspect and if necessary replace let me know how it goes :)
Jul 11, 2009 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Refridgerated water spout suddenly stopped producing water
Have you changed the water filter. It should be located in the front loer grille of the refrigerator.
Jan 10, 2009 | Refrigerators
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
55 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
