Question about Toshiba Satellite A105 Notebook
How can I get at the motherboard to remove the CMOS battery, or the JBAT1 plugs?
I am a novice with computers, so I know absolutely no terminology or anything. How can I get at the motherboard to remove the CMOS battery, or move the JBAT1 plugs? Will this erase the data on my computer? Pictures would be nice, but a vivid description will do. Thanks in advance.
  • 624 Answers
This will take you to the posting referenced by sandrew: http://www.fixya.com/support/t129319-laptop_freezes_during_startup_before
Posted on Jan 05, 2007
    President:
  • 2,961 Answers
See other post about warranty, do not touch any components
Clear CMOS Jumper JBAT
Unplug the power cord and remove the RTC battery,quarter size watch type battery, for 10 min's.Put the battery back in and power it up.that should clear the cmos
May 19, 2014 | Asrock 775S61 Motherboard
Video controller ( vga compatible ) required
Here is an official link for downloading the on board VGA drivers for MSI 865GVM3-V for windows xp operating system. In case thisd is not you op. system you can use this link to choose another one. Note that Windows 7 are not supported, if this is your case you have to try the compatibility option.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Aug 15, 2011 | MSI 865GVM3-V Motherboard
I m having trouble with my SONY VAIO (VGN-FE770G). i forgot my bios password. kindly send me a solution.
The most common way that we know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the Cmos battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased. Hope this helps
Jul 03, 2011 | Computers & Internet
Where is the clear bios jumper in my mis k9n6pgm-FI motherboard
JBAT1 is right next to the SATA2 connector.
Clear CMOS Jumper: JBAT1
There is a CMOS RAM on board that has a power from external battery to keep the data of system
configuration. With the CMOS RAM, the system automatically boot OS every time it is turned on. If you
use the JBAT1 (Clear CMOS Jumper) to clear data. Follow the instructions below to clear the
data:
You can clear CMOS by shorting 2-3 pin while the system is off. Then return to 1-2 pin position.
Avoid clearing the CMOS while the system is on; it will damage the mainboard.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
May 21, 2011 | MSI K9N6PGM-F Socket AM2/ nVIDIA MCP61V/...
Where is cmos reset jumper? Is it near battery,
Try
http://support.acer.com/acerpanam/manuals/acer/0000/servicemanuals/S.G_Aspire_M5640_M3640M1640_BOOK_VerC.pdf
page 77
label CLR CMOS 3 pin type 1-2 clear 2-3 normal
May 16, 2010 | Acer Computers & Internet
Cmos
Hi stan_z4, do you have the manual for you're board?
I'm showing the P4VMM2 is made by ESC = EliteGroup.
Which is not listed above (Intel D845EPI).
If you do have the board EliteGroup P4VMM2 than turn to page 11 in the user manual. The jumper for the cmos/bios JBAT1, Pins must be set to 1 & 2. If JBAT1 is set to pins 2 & 3 you will reset you're bios every time you boot up.
Don't have you're manual? Click on the link.
http://www.ecs.com.tw/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=272&DetailName=Manual&DetailDesc=P4VMM2%20%20(V3.2A)&CategoryID=1&MenuID=82&LanID=0
Mike
Apr 28, 2008 | Intel D845EPI (INTELKD845EPILPAK10)...
Windows boot password reset
to delete any bios password, remove the cmos battery and locate the bios clear terminals, normally called JBAT1, CLRCMOS, CLRCLK or similar, refer to the manual.
Nov 26, 2007 | ASUS M2N-MX Motherboard
Won't Boot up
you need to locate the JBAT1, CLRCMOS,CLRCLK, or similair terminals to clear the cmos settings or try removing the cmos battery, althogh you may need to do both as this will set the clock speed back to default
Oct 11, 2007 | MSI K7N2G-ILSR (MS-6570G-020) Motherboard
Bios password
You have to locate the cmos battery on the motherboard and remove it for a few minutes, and possibly need to locate the clear cmos terminals and short the cmos terminal pins, but the name of the pins you need to locaye depends on the motherboard, normally JBAT1 terminal or CLRCMOS or CLRCLK or similair.
Sep 24, 2007 | Fujitsu Siemens LifeBook N6110 Notebook
No video etc.
on the motherboard will be a JBAT1 terminal with the jumper across pins 1-2, so put jumper on pins 2-3, then back to pins 1-2. If not JBAT1, then it may be a 2 pin terminal called CLRCMOS, of which you put a jumper across the two pins for seconds then remove. Although, i can't think of a way to update the bios without seeing whats on the screen.
Mar 27, 2007 | ASUS Intel 440BX Chipset P2B Motherboard
Toshiba Satellite A105 Notebook Logo
97 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
