I have an Acer SA90. When I start up the monitor and keyboard stays off. The base unit turns on, but the red light at the front stay solid instead of blinking. i have checked all connectionos and it is definatley not the monitor as that says no singal being received on it. Also the base unit won't let me do a cold shutdown, no matter how long i hold the power button in for. Could the problem be my graphics card?
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 17 Answers
Could be a whole lot of things.
Any beeps from the mobo?
Reseat the RAM.
Are your drives spinning up (hard disk drives)
How old is your SSD (if that is what you have)
Have you tried a different monitor?
What GPU do you have?
From what you have described, it really does sound like the motherboard (mobo) has died, without more information it is hard to tell though.
Posted on Jul 24, 2017
Raveler
  • 36 Answers
SOURCE: PC is dead
I assume you installed the new graphics card already. Did you check if your power supply could handle the increased power? If your power supply is rated at 350W or less, I'd upgrade to at least 400W.
Also, ensure that the graphics card, if it has a power connector, is connected properly to the power supply, and that in the process of installing it, you didn't accidentally remove any of the power connections to your motherboard.
The Green LED lets you know that it is receiving power from the wall, and that the problem lies in the computer somewhere.
Posted on Dec 30, 2007
tbirdfan1
  • 3051 Answers
SOURCE: red light and monitor will not start up
you need to shut down the computer and pull the power cord off powersupply then remove the wire harness that goes on to the mother board then press the and hold the computer on button for 3 seconds then plug in the the harness back on the mother board and and plug in all power cords then try to turn on the computer it should give u a beep or the monitor should go from orange to green good luck e-mail me if u want tbirdfan1@yahoo.com
Posted on Aug 09, 2008
pinoy_atinto
  • 52 Answers
SOURCE: acer aspire T120c wont start red
If you turn on the computer and it will beep once and the red light blinks means the computer is starting will.. but if the computer beep once and the red light blinks once means there are something missing or something bothering the computer.. try this Check the connection cable of your computer, the power source, the hardware interface, and if you installed a new hardware, try taking that hardware out and turn on again the computer. if the problem still exist try to disassemble and assemble the hardware of the computer. You must have someone with you know how to assemble and disassemble the computer hardware for safety method TY.
HOPE I CAN HELP
Posted on Dec 05, 2008
SOURCE: Tv will not turn on
all you have to do is replace the 25 volt 1000 uf capacitor on the inverter board. there are 2 of them. typically, only 1 goes bad. I had the same problem, replaced the ca, and now it works great.
Posted on Jun 06, 2009
sabharish
  • 297 Answers
SOURCE: projector turns on the power light flashing and lamp light solid
Here's the fix: Take off the top cover of the projector. Unplug the wire leading from the two fans in the back of the unit to one of the circuit boards in front of you. Just trace one wire from fan to board. Unplug at board. Turn unit on and it will again turn on, show HP splash screen and then shut down, like it should, because the fans are now disabled. After it completly shuts down, plug the fan wire back into the board. Turn the unit back on and, presto, its working again. It will not turn off.
Try it!
Posted on Jun 23, 2009
Braun 8995 - YELLOW LIGHT STAYS ON!
I experienced the same symptoms on my 8995; solid yellow light (even though the cartridge was full), cleaning failed (red light on) after pressing either start button. After many failed attempts to clean the razor, unplugging the station and pushing start button, I decided to clean the razor under running water. I rinsed the razor under water and then turned it on allowing it to run in a pool of water (like it would in the station). After water cleaning, I returned the razor to the station, pressed the start button and it worked! Was able to do both the quick clean and auto clean.
Jan 06, 2013 | Braun 8995 Electric Shaver
Hello, My Graco monitor shows a red light instead of the normal green light and it says "discard jetez". It also beeps. What could be wrong?
I just fixed my unit that had this same problem. You have to re-pair the two units... Turn the parent unit off. Hold the "volume down" button while you turn the parent unit back on. The unit should beep and flash all volume lights. Release the volume button and the press again for ~2 seconds. The volume lights will light up and stay on. Next, turn the nursery unit off and then back on. This should re-pair the two. I hope it fixes your problem!
Mar 12, 2011 | Graco Imonitor Vibe 2791vib Digital Baby...
I have the dual graco baby monitors which I love and want to salvage. They weren't cheap. They have brand new batteries in them which I had to have made. You can tell the batteries work, they turn the...
You might have to pair the parent units to the base units. here is the manual, look under troubleshooting:
http://ubermanuals.com/product/graco-multichild-2794dig1-1069
Mar 16, 2010 | Graco Monitor 2794Dig Imonitor Dual
Green light flashing, but monitor won't come on
Sounds like signal issue, some older monitor lights do not turn orange when no signal is present from the computer. They simply blink instead of staying solid.
- I would test to see if monitor works on another computer with a known working monitor. If the monitor works then you know you have a video output issue.
If the monitor does not, you have a dead monitor.
Cheers,
Oct 21, 2009 | Computers & Internet
Acer Aspire 5920 will not boot at all...
The power button may not work, that is most common in laptops, or you have a short.
Aug 23, 2009 | Acer Aspire 5920-6727 Notebook
Monitor Not Showing A Picture. Light flashes Yellow and Green.
use the onboard graphics instead of a seperate graphics card (if installed) to test the screen.if it still doesn't work then unplug your monitor from the mains supply and plug in again to reset it. i doubt it's your monitor that is the problem though. but look on the back of your pc for another connection for your screen. the onboard graphics connection is normally vertical near your ethernet port and mouse and keyboard inputs.
please rate me and give me a fixya! if it helped.
Apr 05, 2009 | Acer AL1713M 17" LCD Monitor
Toner light stay on
1. Power Unit off
2. Open front cover
3. Press and hold GO and turn power on
4. When all 3 lights lit release and press GO twice
5. All lights turn solid
6. With all solid, press GO 5 times
7. Ready light GOes red
8. Close door and you're all set
Jul 29, 2008 | Brother HL-2040 Laser Printer
BROTHER 2030 TONER LIGHT STAYS ON CONTINUOUSLY
I had the same problem and Brother tech support walked me through this procedure which worked fine..
1. Power Unit off
2. Open front cover
Sep 13, 2007 | Brother HL-2040 Laser Printer
Computers & Internet Logo
David Payne
David Payne
