Can't unlock EXT 1 & 2 on Mitsubisi VS 4504R Projection TV
When I try to access EXT 1 or EXT 2 inputs on my Mitsubushi VS 4054R TV I get a message ''this input is locked enter your access code and press enter to unlock''. I never did set up a code for this so I don't know why they are locked. I' tried every combination of 4 number codes I can think of but so far nothing has worked. I would like to use these inputs---- HELP I also would like to get an users manual on this TV.
Thanks Al C
  • 276 Answers
First unplug the tv from main power cord and then plug it in with menu button pressed on the screen then go to the set up mode and there is a choise to enter the code in ext mode .
Posted on Nov 25, 2008
If you try to change the chanel on the remote and you don't get snow, then your set is in home theater mode and stuck on EXT-1 input.
You will have to get into the menu under advanced settings and turn off Home Theater.
Hope this helps.
Thanks for using FixYa
Mar 02, 2011 | Mitsubishi VS-50609 50" Rear Projection...
Input is locked - code needed to unlock
If you have a Mitsubishi remote or the one that came with the TV, you can try the following.
Select the input.
When it asks for the code press and hold the QV button on the remote, then press the number 9.
That should unlock the input.
Then navigate through the menu and turn off the input lock, or any other locks that may have been set with the same key combo listed above.
I hope that this helps you with this issue.
Thanks for usning Fixya.
Oct 17, 2009 | Televison & Video
When i press av on my remote control i have tv ext and digital options but where has the options for ext2 and 3 etc gone
Dont know your specific model, **** some new tv's will only allow access to av inputs that is connected with cables and a component. Move your cabling from ext 1 to ext 2 or 3 and see if you can access the av ext. If still no access on ext 2/3 the av input board or backup memory could be faulty.
Aug 10, 2009 | Philips 42PF7220A 42 in. Plasma Television
My Mother has the VS-5003R big screen television that she purchased back in 1990. the television portion works fine but the ext-1 and ext-2 inputs are locked from a code that probably died with my father...
I have the same tv and same issue. I found chain of notes indicating that you can clear the lock by pressing 9-QV (two buttons) on the original remote at the same time. This works... however if you change the input again the EXT1 and EXT2 inputs will be locked again. It would be really nice if you can remove the lock feature completely.
Aug 07, 2008 | Mitsubishi Televison & Video
Tv will not turn on
are either one of the sets binking? If so can you count the blinks in between the pauses?
Feb 14, 2008 | Televison & Video
Mitsubushi Big Screen TV Screen Protector vs 60601
that will have to be a dealer orderd item.. Unless you can find one used. I would try the tv shops in your area , they may have a used mitsubishi screen
Jan 21, 2008 | Mitsubishi VS-60601 60" Rear Projection...
Mitsubishi VS-50603, input is gone
happened to me also. Go to the menu, select setting, thrn av (home theater) and see if "locked to input 1" is "on". Mine was. then I set it to "off" and everyting works great
Dec 06, 2007 | Mitsubishi VS-50603 50" Rear Projection...
Mitsubishi tv
Without the code, you must get an original remote and press the "QV" and the "9" buttons together to unlock the TV.
Oct 16, 2007 | Televison & Video
Locked ext inputs
I'll give you the master reset, with set on, and from the remote hit Menu-1-2-7-0 this will bring up the Intilize screen and the word Initlize should be highlighted, if it is hit enter on the remote, this is the factory default settings so now if the set ask for a parental code it will be 0000
Nov 06, 2006 | Mitsubishi VS-45607 45" Rear Projection...
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
