Question about Fisher and Paykel DE08 Gas Dryer
Dryer belt installation
For whirlpool ultimate care II
  • Treestain Dec 20, 2008
    The new belt seems to be loose, and the pulley doesn't have much tension with the belt. Are we we missing something?
  • Anonymous Dec 26, 2008
    a peice fell out and i doooont no where it goes back
    Sergeant:
    Champion:
  • 214 Answers
To install a a belt you will need a puddy knife a star screwdriver 1/4 or 5/16 nut driver and a good memery.First you must remove the lint screen then remove the 2 screws after that there are 2 clips on the two corners push your puddy knife in there till you feel the clips.Then push forward and lift the top at the same time it should lift.After that you will need a 1/4 inch nut driver or 5/16 not sure.The screws will be on the left and right inside front panel the whole front panel then should come off by lifting and pulling towards you aftet that you need to look under to remember how the old belt is on the idler wheel.Then you install new belt and go backward on instructions good luck :)
Posted on May 07, 2009
How to fix a broken belt of motor of whirpool wash ultimate care 2
  • Replacing the Belt in a Whirlpool Ultimate Care II ' Home ... homeguides.sfgate.com > ... > Mortgage-Backed Securities Replacing the Belt in a Whirlpool Ultimate Care II by Rogue Parrish. Email; ... The Ultimate Care II washer, ... it may have a broken belt.
  • Whirlpool Washer: Ulitimate Care II - YouTube www.youtube.com/watch?v=bVmjmSzMXHE
    • BY CHERRY HILL
    • 3 MIN
    • 36K VIEWS
    2012-05-30 · Video embedded · Whirlpool Ultimate Care II: ... This is fully funcational washer. Direct Motor Drive works perfectly through each ... Whirlpool Washer: Ulitimate Care II
  • How to replace a broken dryer belt. Whirlpool Ultimate ... www.youtube.com/watch?v=PU8QZeDRl_0
    • BY BAILSOFSTEEL
    • 5 MIN
    • 3.5K VIEWS
    2015-04-04 · Video embedded · This video shows me replacing a belt in a Whirlpool Ultimate Care II ... a broken dryer belt. ... Whirlpool ultimate care II clothes washing
  • http://www.bing.com/videos/search?q=broken+belt+of+motor+of+whirpool+wash+ultimate+care+2&FORM=HDRSC3
    Jul 15, 2016 | Washing Machines
    My whirlpool ultimate care II electric dryer won't
    There can be many reasons why your dryer will not start or turn...
    The most common causes are the belt breaking or jumping off, or the motor goingbad...
    Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
    Dryer Repair - The Dryer is not Turning
    Dryer Repair - The dryer will not start
    heatman101
    Jul 21, 2011 | Whirlpool Dryers
    Whirlpool Ultimate Care II Dryer timer knob
    The timer cam is not aligning the internal switches. Replacing it is the only fix.
    Eric
    Sep 17, 2009 | Kenmore 62602 Electric Dryer
    Whirlpool Ultimate Care II LSQ9564J Top Load Washer Sm8525079 what is the capacity of this washer and what is the capacity of the matching dryer?
    Hello.
    The capacity of your washer is 3.2 cu ft and the dryer is 6.0 cu ft. This is pretty much a standard for newer top load washers and dryers. You can get bigger but it is not that much bigger.
    Jul 22, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
    Whirlpool ultimate care II dryer will not dry clothes
    does dryer heats up if yes take hose out from back of your dryer run dryer if you have good power air coming out from your dryer i think your dryer is fine you need to clean your air vent. system.
    Feb 28, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
    Whirlpool Ultimate Care II LGQ9558KQ! is not spinning. Whre is the belt?
    galitbunny
    Welcome to our site.
    You siad, the dryer is not spinning.
    Can you hear the motor?
    If you can not hear it then not your door switch or the main fuse inside the dryer is bad.
    You pop the top and you will see both the belt and the fuse.
    Let me know how you are.
    Bless You,
    Huuum
    Sep 20, 2008 | Whirlpool Dryers
    Whirlpool Ultimate Care II LGQ9558kQ1 is not spinning
    can you hear the motor?if not your door switch or main fuse inside the dryer is bad,if you pop the top you can see the belt and fuse,let me know,mike
    Appliance rewiring wiring WIRLPOOL ULTIMATE CARE II
    The Whirlpool Ultimate Care II cannot be outfitted for a standard 115 VAC wall outlet. Your dryer is a 220 VAC appliance. It needs to have it own dedicated 30 amp, 220 VAC circuit with the proper outlet and power cord installed. The dryer heating circuits and timer will not run on 115 VAC. I think you need to reconsider what you are about to do...
    Jan 23, 2008 | Dryers
    Fisher and Paykel DE08 Gas Dryer Logo
    241 people viewed this question
    Top Fisher and Paykel Dryers Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Craig Butler
    Craig Butler
    Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
