Question about Sony Handycam CCD-TRV87 Camcorder
New Batter won't fully charge and camera won't power off
Hi, I got this camera used and when you put the switch to off/charge it goes off and comes right back on. I purchesed a new battery, put it on the camera and plugged it in but I'm not seeing the display for the amount the battery has charged all the time but when it does show up, it's not fully charged. Otherwise this camera tapes quite nicely but you have to always remove the battery or it will constantly drain. Any ideas out there?
    President:
  • 4,402 Answers
The battery will not hold a charge or cannot be charged at all.
Follow the steps below to troubleshoot this issue.
IMPORTANT: It is recommended that you only use a Sony® brand rechargeable battery.
  1. Remove the battery from the camcorder or charger.
  2. Ensure the metal contacts on the battery are free of corrosion.
  3. NOTE: If necessary, the metal contacts can be cleaned using a soft cloth.
  4. Reinsert the battery into the camcorder or charger.
If the issue is still unresolved, then the battery may need to be replaced. If still unresolved after trying a replacement battery, then service may be required. The Sony® eService Web site at http://eservice.sony.com/ can assist you in obtaining service from a Sony Service Center or locating a Sony Authorized Servicer.
Posted on Dec 20, 2007
SOURCE:
My rebel t3i wont turn on!!!
I just bought a T3i and only used it 2 days of shooting. On third day, it's not turning on and it's 80 degree's. So not cold weather. Batteries are fully charged. When I put batter in and turn the switch on, the red light comes on for only a second and then nothing! Other times the red light won't even come on, period. As I said, I've only had it 3 days and it's dead....
May 06, 2013 | Canon EOS 600D Rebel T3i Digital Camera
Zeki 10" tablet won't load
Hi, Is your Zeki fully charged? My suggestion is to hold the on/off button for a few secs. to fully power down. Put it on the charge and let it fully charge before trying it again. Then try turn it on again.
Feb 18, 2013 | Shopnbc Zeki 10" 8GB Android 4.0 Ice Cream...
Won't turn on
I had this same problem! Scoured the web and found no solution. This is what I did to fix it...
Remove battery. Unplug charger. Press and hold the power button for 20 - 30 seconds. While still holding the power button, re-insert the battery and/or plug in the charger. Voila! Came back to life and worked like nothing ever happened.
I also did the same thing with the record button, but it was the power button that got the result.
Hope this helps!
Feb 29, 2012 | Toshiba Camileo S30 HD Camcorder -...
My camera lense won't go in. Everytime I switch it
Your batteries are too low.
When you switch on the camera, the lense go in. Then lense comes out fully. Then, if the batteries are low, lense goes in and camera turns off.
But if the batteries are too low, camera turns off before the lense retracts or even before the lense comes out fully.
Aug 27, 2011 | Sony Cameras
Though my Worx WG781 cordless 36V, 19 inch lawn mower came with what appeared to be a fully charged battery according to the battery LED lights , it is suggested that it be put on the charger "over...
Could be.Those batteries leak charge even when not in use.I would let it go for 24-48 hours just to be sure.Unless the batteries or charger becomes very hot.
May 20, 2011 | Worx WG788 19Inch 36 Volt Cordless 3In1...
Panasonic vx37
My old Panasonic Palmcorder IQ shows a red light in both switch positions-camera and VCR. Maybe yours has red for camera and green for VCR so you could tell them apart. I found that the Panasonic battery that came with the camera was the cheapest kind with the least charging time. I bought other batteries, they were good for a while, but now, many years later, they won' t hold a charge. Since I am only recording inside of my house, I have resorted to using the AC wall socket for power. I have to take the battery out of the camera. I found a power plug-in hole (like ones on cell phones) in the battery compartment. I also found one of these holes on my battery charger. My camera came with a double ended power plug. I plug one end into my camera and the other end into the battery charger. I plug the charger power cord into the wall outlet, and I have power to my older camera. Maybe you can find this double ended power cord at a store or on line.
Did you know that there are 2 kinds of batteries? Some have memories and others do not rely on a memory. The ones with memories have to be fully discharged or they will only charge a little, and keep charging less and less each time they are charged. The ones without the memory can be charged fully without being discharged fully. Check into battery information on line to get more information. Maybe you can get the non-memory kind.
May 18, 2009 | Panasonic NV-VX37 Mini DV Digital...
Put new batteries in, camera bleeps three times & switches off
hi meeshfriel,
The battery might be damaged. try recharged the battery at least 2 hours maximum of 4 hours. If the problem persist it is your battery needs to be replaced......
Thanks.
jonags
Dec 14, 2008 | Samsung Digimax S800 Digital Camera
Canon sd630
Hi
Sounds like it would need the fuse replaced, about $35 if we can do it.. some of them are very hard to get at or solder. If that doesnt work it would need a new mainboard, $85 if I can get one used.
sales AT darntoothysam DOT com
Thomas
darntoothysam com
Nov 02, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
Advent mp 82 camer says replace battery even when new batteries are used
my camera worked, and as i was playing with the menues i changed the batter setting from alkaline to nimh, or the other way round now when i put in ni mh battteries fully charged, it say low battery, gotta try high power alakline now and hope it works
Jun 20, 2008 | Cameras
Camera wont switch on
hte battery LID has not closed properly.
or u must have kept the auto shut down settings very low.
this can be resolved by resetting the camera.
Have you tried a hard reset on their camera by removing the main power batteries for 60 seconds and the reinserting them as if it were the first time power up. This may not fix your particular problem, but when the processor that runs all of the electronic features of the camera gets confused, this is the best way to clear its confusion.
even if problem is not cleared take it to service centre.
Dec 01, 2007 | Samsung L700 Digital Camera
Open Questions:
See all Sony Handycam CCD-TRV87 Camcorder Questions
Sony Handycam CCD-TRV87 Camcorder Logo
182 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Parshiv Luthra
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
