Question about Samsung - Projection TV replacement lamp Projector Lamp
I have a Samsung HLN507w1x/xaa the TV will from time to time shut off. Does that mean I need a new lamp? I have had TV for about 3-4 years and never changed lamp yet. Joe
    Problem Solver:
  • 17 Answers
Yes replaced the lamp
Posted on Jul 23, 2010
Samsung hlt4675sx/xaa lamp ballast keeps going out
Hello Leeann,
Wow 3 ballasts is too many too quick. Did this solve you problem every time?
Have you checked the voltage going to the ballast? this might be a power supply issue. The power going into the ballast should be between 320V - 380V. Please do not try to measure the power going to the lamp! The ignition charge can be 15kV and it is dangerous to you and a multimeter.. please let me know and I will try to help you get to the bottom of this
Jan 06, 2014 | Samsung HLT4675SX/XAA OEM TV Lamp
Sound but no picture on samsung tv HLT5687SX/XAA
I unscrewed the panels on both sides of the tv to find out that the lamp was not turning on. What I did was I got my broom, tapped the lamp with it about 3 times when it was turned on, turned it off, tapped the lamp 3 more times, turned the tv on and it started working again.
Sep 01, 2013 | Samsung DLP HL-P5663W 56" TV
MY SAMSUNG MODEL CODE HLS6187WX/XAA KEEPS SHUTTING OFF BY ITSELF EVERY 15-30 MINUTES
2 defective parts can cause this symtom 1, the lamp defective 2 color wheel, if you have a lamp for more than 2 years may be the lamp if not the color wheel is defective also check the timer on the tv may sure is disable.
Dec 18, 2010 | Samsung Televison & Video
The LED indicator is flashing/blinking we replaced the lamp and it will not still turn on. someone suggested the cooling fan? Thank you Shawna2735@Gmail.com
If Fan is running when you turn TV on and keeps running then its OK ,Ballast Board is what turns Lamp on, Is Lamp Lighting at all?
Encompass Parts Distribution has Ballast board for $62.00
Be sure to give the whole model # to TV Ending in WXXaa
WAX/XAA or WX/Xaa HLR6167wxxaa or wax/xaa or wx/xaa
1-800-638-3328 You can also go to their website and type in your model # for List of Parts and Free Service Manual.
Sep 28, 2010 | Samsung HL-R6167W 61" HDTV
My TV turns off by itself. It is a Samsung HlP6163W. Service Model HLP6163WX/XAA. The two green lights flash at the same time. I think it is overheating the bulb. How do I fix it.
Lamps don't really last very long typically 1 to 3 years depending. You may just need to replace the lamp. A burner gap of a lamp expands as the lamp warms up. If the gap is too large due to age (normal usage) the lamp will fail to light or shut down once the expansion occurs. The solutions to either problem is to replace the lamp.
Mar 15, 2010 | Samsung HLP6163W 61" Rear Projection...
Samsung HLS4266WX/XAA warnings w/ new lamp also
You may be in need a new ballast, the assembly that excites the bulb into producing output.
Sep 20, 2017 | Samsung Televison & Video
Samsung lns4095dx/xaa after 30min the screen goes
The first place to start is with the Main bd. The second cause would be the T-con bd. Have a trained Samsung tech troubleshoot to find out and repair the set.
Jul 05, 2009 | Samsung LN32A550 32 in. LCD TV
495 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
