Question about Tricity Bendix AW1054 Front Load Washer
Bendix 1500 series Washer is leaking from bottom
This machine is 10 years old. No one has a clue who Bendix is. It's like I purchased a machine from MARS! Help.
I need service in the Long Island NY area. I need some number to contact Bendix. I do not have manual or any phone numbers to get this thing fixed
  • dcny1993 Nov 29, 2008
    Thanks.
    This information was helpful at least I have more names to search
  • Tricity Bendix Master
  • 3,463 Answers
It is now Tricity Bendix, and comes under the ZANNUSI name.
Try looking under Zannusi in your directory
Posted on Nov 25, 2008
My washer is leaking from the bottom of the wash tub I believe it is the agitator seal? is this something worth trying to tackle and how expensive. My washer is probably over 10 years old and the model I...
no sealwell yor gonna need to purchase a specialty tool called a spanner wrench $35.00 plus center seal and bearing like AROUN D $70.00 EMPTY GARAGE AND ABOUT 2 HOURS THERE IS A COUPLE OF VIDEOS YOU CAN WATCH ON YOUTUBE
Jan 26, 2011 | Maytag Centennial MTW5800TW Top Load...
I have a Frigidaire Gallaxy Series top loading washing machine, 4 years old that seems to be leaking from the bottom. Is this something I can fix myself? THANK YOU.
Before you buy a new $100 door gasket, pull out the soap dispenser tray and look inside the washer where it normally sits. If there is significant soap accumulation (even 3/8 inch), the water can become backed up and trickle down the washer front to the door bottom, making it look like a door leak. Fixed mine this way.
Jul 30, 2010 | Washing Machines
Twice now I have pieces of metal in the pump
its the diecast of your inner tub cross members,nothing you can do but replace the inner tub,its just after a while the detergents start to diteriate the die cast
Mar 29, 2010 | Tricity Bendix WDR1040W Front Load Washer...
Kenmore Heavy Duty 70 Series Leaking in the back
If you bought a new washer and you still have a leak, i guess it was not the washer but where it drains into. Sink or stand pipe has a leak. unless you are useing the old drain hose from your old washer. Dry up everything and look for the sorse of water with a bright light when the washer drains .
Nov 22, 2009 | Washing Machines
Washing machine trips my electricity as its about to spin,
There is almost certain to be a small leak which could be from a variety of things. The water sounds like it has found its way onto your motor windings. Once it starts burning,carbon is left behind on motor.The decision to replace motor and possibly hole in drum is the question.Need to weigh up if a new purchase is possibly the right way to go. Remove covers to see if the source of the leak is visible.
Oct 02, 2009 | Tricity Bendix AW1000W Front Load Washer
My GE dishwasher is leaking water from the bottom of the machine
first check to make sure door gasket is ok, if bad, replace and test. Make sure to remove bottom front panel during a test and inspect the motor and motor gaskets. It may be leaking here, replace leaking components as needed.
Jul 01, 2009 | GE 24 in. GLD6200L Built-in Dishwasher
Kenmore top load washer approx. 10 years old
f7686aa.jpgPump is leaking around the drive shaft.
To get to the pump CLICK HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 28, 2008 | Kenmore 24032\24036 Top Load Washer
Ammana washer less than 5 years old making loud noise and leaking water from bottom of washer
it sounds like the tub seal is going bad and leaking on the bearings,not good,you can remove the top with a putty knife into the front seam one clip on each side(make sure no screws on bottom front,you can now check everthing out to see what you find,let me know -mike
Sep 26, 2008 | Whirlpool Washing Machines
Tricity Bendix AW1054 Front Load Washer Logo
142 people viewed this question
Top Tricity Bendix Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you a Tricity Bendix Washing Machine Expert? Answer questions, earn points and help others
