Question about Whirlpool Dryers
How to install belt - Whirlpool Dryers
    Sergeant:
    Champion:
  • 291 Answers
On a whirlpool you take out the 2 screws beside the filter on top and pop up the top and there are 2 5/16 screws going into the door cabinet and 2 at bottom and front comes off and belt is there ,,,, follow instruction on bag on belt as far as installing it.
Larry
Posted on Nov 25, 2008
Need timing belt digram for a 2000 kia sportage
  1. Install lower timing belt cover.
  2. Install upper timing belt cover.
  3. Install power steering drive belt and adjust belt tension.
  4. Install fan pulley.
  5. Install generator drive belt and adjust belt tension.
  6. Install A/C drive belt and adjust belt tension.
  7. Install splash guard.
  8. Install fan and fan shroud.
  9. Install 4 fan bolts. Tighten to 24 ft lb (33 Nm).
  10. Install fan shroud mounting bolts.
  11. Install fresh air duct.
  12. Connect hose to resonance chamber.
  13. Connect battery negative cable.
Apr 17, 2013 | 2000 Daewoo Nubira
99 kia sporage timing marks
Hi there:
Check this information...
Crankshaft match marks
Align marks on timing belt pulley and pump body.
Camshaft pulley alignment marks
  1. Align marks on camshaft pulleys with alignment marks on seal plate.
  2. Install timing belt. NOTE: No looseness should exist on the tension side and at the camshaft pulleys.
  3. Loosen tensioner lock bolt.
  4. Turn crankshaft 2 revolutions in direction of rotation and check that timing marks are still in alignment.
  5. Tighten timing belt tension lock bolt to 27-38 ft lb (32-52 Nm).
  6. Apply a force of 22 lbs to timing belt between camshaft sprockets.
  7. Belt deflection should measure 0.30-0.33 in (7.5-8.5 mm)
  1. NOTE: Replace tensioner spring if timing belt deflection is excessive.
  2. Timing Belt Installation
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Mar 14, 2012 | Kia Sportage Cars & Trucks
Problem with 99 kia
Hi there:Check this information...
Need belt routing diagram for 2001 chrysler sebring lxi
Thanks for using FixYa.
Fig. Accessory drive belt routing-2.7L engine
Chrysler Cirrus & Sebring Convertible; Dodge Stratus; Plymouth Breeze
Fig. Accessory drive belt routing-Chrysler 2.7L engine
2.7L Engine
A/C & Alternator Belt
  1. Raise and safely support the vehicle.
  2. Remove the right front wheel and belt splash shield.
  3. Loosen tensioner locking bolt and pivot bolt.
  4. Rotate tensioner clockwise to allow enough slack to remove belt
To install:
  1. Install the air conditioning compressor/alternator belt on pulleys, tensioner in slack position, slip belt over idler last.
  2. Adjust drive belt tension.
  3. Install the belt splash shield and right front wheel.
  4. Lower vehicle.
    Fig. Installing A/C & alternator belt-2.7L engine
  1. Before servicing the vehicle, refer to the Precautions Section.
  2. Raise and safely support the vehicle.
  3. Remove the right front wheel and belt splash shield.
  4. Loosen the tensioner locking bolt and pivot bolt.
  5. Rotate tensioner clockwise to allow enough slack to remove the belt
To install:
  1. With the tensioner in a slack position, install the Air Conditioning (A/C) compressor/alternator belt on the pulleys. Slip the belt over the idler last.
  2. Adjust the drive belt tension.
  3. Install the belt splash shield and right front wheel. Tighten the wheel lug nuts to 100 ft. lbs. (136 Nm).
  4. Lower the vehicle.
Power Steering Belt
  3. Remove the air conditioning compressor/alternator belt.
  4. Loosen belt adjusting bolt. It is not necessary to loosen the pivot bolt on the power steering pump. There is a bushing incorporated into the power steering pump/bracket that allows it to pivot.
  5. Remove the power steering belt.
To install:
  1. Install the power steering belt on pulleys.
  3. Install the air conditioning compressor/alternator belt.
  4. Install the belt splash shield and right front wheel.
  5. Lower vehicle.
Oct 27, 2011 | Cars & Trucks
Need diagram to put timingbelt on 2001 kia sportage
prev.gif next.gif Timing Belt Removal & Installation SOHC To Remove:
  1. Disconnect battery negative cable.
  2. Remove fresh air duct.
  3. Drain engine coolant into an appropriate container and retighten radiator drain plug.
  4. Remove upper radiator hose.
  5. Remove fan clutch assembly bolts.
  6. Remove 5 cooling fan shroud bolts.
  7. Remove fan shroud and fan as an assembly.
  8. Loosen alternator mounting bolts and remove drive belt from pulley.
  9. Remove fan pulley.
  10. Remove 4 cooling fan assembly bolts.
  11. Remove cooling fan assembly.
  12. Remove 4 bolts and upper timing belt cover.
  13. Remove 2 lower bolts and lower timing belt cover.
  14. Loosen adjusting bolt and remove A/C belt.
  15. Remove alternator belt.
  16. Loosen power steering pump lock bolt and mounting bolt.
  17. Remove drive belt from crankshaft damper. Camshaft timing marks kia-03-20-7032.gif
  18. Turn crankshaft until timing mark on front housing and the arrow "2" on the camshaft pulley align.
  19. Remove 5 bolts and remove damper.
  20. Remove timing belt guide from timing belt pulley.
  21. Loosen tensioner lock bolt.
  22. Pry tensioner away from timing belt and tighten lock bolt to relieve tension on the timing belt. NOTE: Mark the direction of timing belt rotation on the belt if it is being reused.
  23. Remove timing belt.
To Install:
NOTE: Timing belt pulley timing mark and timing mark must be aligned.
NOTE: The arrow at "2" on camshaft pulley must be aligned with timing mark on front housing.
  1. Install timing belt with minimal slack from timing belt pulley to water pump and from water pump to camshaft pulley.
  2. Loosen tensioner lock bolt until tension is applied to timing belt. CAUTION
    Do not turn crankshaft counterclockwise.
  3. Turn crankshaft pulley 2 full turns clockwise and ensure timing marks are properly aligned.
  4. Tighten tensioner lock bolt to 33 ft lb (45 Nm).
  5. Apply a force of 21 lb to timing belt midway between idler pulley and camshaft pulley.
    • Deflection should measure 0.43-0.51 inch (11-13 mm)
    NOTE: if timing belt deflection is incorrect remove timing belt and install NEW tensioner spring.
  6. Install timing belt guide.
  7. Install crankshaft damper pulley.
  8. Install 5 crankshaft damper pulley bolts. Tighten bolts to 132 in lb (15 Nm).
  9. Install power steering pump drive belt.
  10. Adjust power steering pump drive belt tension and tighten lock bolt and mounting bolt.
  11. Install alternator drive belt.
  12. Install A/C drive belt.
  13. Install lower timing belt cover and bolts. Tighten bolts to 84 in lb (10 Nm).
  14. Install upper timing belt cover and bolts. Tighten bolts to 84 in lb (10 Nm).
  15. Install cooling fan assembly and 4 bolts. Tighten bolts to 27 ft lb (37 Nm).
  16. Install fan pulley.
  17. Install fan clutch and shroud as an assembly. Tighten bolts to 74 in lb (8 Nm).
  18. Tighten 4 cooling fan nuts to 16 ft lb (22 Nm).
  19. Adjust alternator belt tension and tighten alternator mounting bolts.
  20. Install upper radiator hose.
  21. Install fresh air duct.
  22. Connect battery negative cable.
  23. Refill/bleed cooling system.
DOHC To Remove:
  3. Remove 5 cooling fan shroud bolts and 4 thermo-modulated fan nuts.
  4. Remove 4 thermo-modulated fan shroud fasteners.
  5. Remove generator drive belt.
  6. Remove fan pulley (located above crankshaft pulley).
  7. Remove 4 bolts and splash shield (located under front of vehicle).
  8. Remove A/C drive belt and power steering drive belt. Timing Belt Removal kia-03-20-7097.gif
  9. Remove 5 bolts and upper timing belt cover.
  10. Remove 2 bolts and lower timing belt cover.
  11. Loosen tensioner lock bolt and pivot tensioner pulley outboard.
  12. Retighten tensioner lock bolt. NOTE: Mark timing belt for rotation if it is being reused.
  13. Remove timing belt.
To Install:
  1. Align marks on timing belt pulley and pump body. Camshaft pulley alignment marks 79245g28.gif
  2. Align marks on camshaft pulleys with alignment marks on seal plate.
  3. Install timing belt. NOTE: No looseness should exist on the tension side and at the camshaft pulleys.
  4. Loosen tensioner lock bolt.
  5. Turn crankshaft 2 revolutions in direction of rotation and check that timing marks are still in alignment.
  6. Tighten timing belt tension lock bolt to 27-38 ft lb (32-52 Nm).
  7. Apply a force of 22 lbs to timing belt between camshaft sprockets.
    • Belt deflection should measure 0.30-0.33 in (7.5-8.5 mm)
  8. Install lower timing belt cover.
  9. Install upper timing belt cover.
  10. Install power steering drive belt and adjust belt tension.
  11. Install fan pulley.
  12. Install generator drive belt and adjust belt tension.
  13. Install A/C drive belt and adjust belt tension.
  14. Install splash guard.
  15. Install fan and fan shroud.
  16. Install 4 fan bolts. Tighten to 24 ft lb (33 Nm).
  17. Install fan shroud mounting bolts.
  18. Install fresh air duct.
  19. Connect hose to resonance chamber.
  20. Connect battery negative cable.
Aug 02, 2010 | 2001 Kia Sportage
How do I change a water pump on a 2004 kia sorento?
Kia Sorento 2003-05
Water Pump - Removal & Installation
  1. Before servicing the vehicle, refer to the precautions at the beginning of this section.
  2. Drain the cooling system.
  3. Disconnect the negative battery cable.
  4. Remove the drive belt and the water pump pulley.
  5. Remove the timing belt cover, timing belt, auto tensioner and idler pulley.
  6. Remove the water outlet fitting, the thermostat case and the water pump fitting.
  7. Remove the water pump mounting bolts.
  8. Remove the water pump.
    Fig. Water pump and timing belt assembly-exploded view
To install:
Fig. Water pump bolt locations
  1. Clean the gasket surfaces of the water pump body and the cylinder block.
  2. Install the new water pump gasket and pump assembly. Tighten the bolts to 12-16 ft. lbs. (17-22 Nm).
  3. Install the water pump fitting, the thermostat case and the water outlet fitting.
  4. Install the auto tensioner and timing belt. Adjust the timing belt tension, then install the timing belt cover.
  5. Install the drive belt, water pump pulley and then adjust the auto tensioner.
  6. Refill the coolant.
  7. Run the engine and check for leaks.
To install:
Fig. Water pump O-ring installation
  6. To adjust the drive belt tension, hang the belt on the pulley of the tensioner and install the tensioner.
    NOTE If the tensioner is already installed, loosen its mounting bolts to allow belt installation
  7. Install the drive belt.
  8. Adjust the belt tension to specification by turning the adjusting bolt clockwise or counterclockwise.
  9. Air conditioning belt tension should be 0.28-0.039 inch. Alternator belt tension should be 0.39-0.051 inch. Power steering belt tension should be 0.31-0.051 inch.
  10. Torque the tensioner assembly bolt to 33-36 ft. lbs. (45-50 Nm).
  11. Refill the coolant.
  12. Run the engine and check for leaks.
TY for using Fixya; remember comment and rated this.
Apr 01, 2010 | 2004 Kia Sorento
How do i loosen the belt to get the alternater off
.whtbtnshow{font-family:;font-size:10pt;font-style:;font-weight:;text-decoration:;color:;}
Accessory Drive Belt Tensioner
Removal & Installation To Remove:
  1. Rotate the accessory drive belt tensioner clockwise.
  2. Remove the accessory drive belt.
  3. Remove the accessory drive belt tensioner bolts.
  4. Remove the accessory drive belt tensioner.
To Install:
  1. Install the accessory drive belt tensioner.
  2. Install the accessory drive belt tensioner bolts. Tighten to 18 ft-lb (25 Nm).
  3. Install the accessory drive belt.
  4. Rotate the accessory drive belt tensioner counterclockwise.
Oct 26, 2009 | 1998 Lincoln Navigator
Serpentine belt diagram for 1996 audi a4 quattro v6. I can't find a proper diamgram and install procedure, can you help?
Ribbed Belt: Service and Repair
Ribbed Belt, Removing and Installing
Ribbed belt, removing and installing
CAUTION: Mark the direction of belt travel before removing, using a crayon or marker. Reinstalling a used belt in the opposite direction
could damage the belt
Note:
There are two different types of ribbed belt, identified as versions A and B.
Ribbed belt versions, identifying, refer to Application and ID
Removing
Old version A
- Remove ribbed belt guard.
- Loosen ribbed belt tensioner using 15 mm wrench and drift 3204.
- Remove ribbed belt.
New version B
- Using 10 mm hex socket wrench, turn downward in direction of arrow to loosen ribbed belt.
Installing
Install in reverse order of removal, noting the following:
- Place ribbed belt over drive pulleys and idler roller first, and onto tensioning roller last.
- Remove drift 3204.
- Install ribbed belt guard.
Sep 24, 2009 | 1996 Audi A4
1999 kia sportage timing marks
dfd3ea1.gif Crankshaft match marks
  8. NOTE: Replace tensioner spring if timing belt deflection is excessive.
Jul 26, 2009 | 1999 Kia Sportage
Cant find 97 ford taurus serpentine belt diagram
Drive Belt Replacement ani_caut.gif WARNING: IF EQUIPPED, DO NOT ALLOW DRIVE BELT TENSIONER (6B209) TO SNAP BACK AS DAMAGE TO DRIVE BELT TENSIONER OR PERSONAL INJURY COULD RESULT.
NOTE: Minor cracks in the V-grooved portion of the serpentine drive belt (8620) are considered normal and acceptable. If the drive belt has chunks missing from the ribs, the drive belt should be replaced.
NOTE: Conditions requiring drive belt replacement are excessive wear, rib chunk-out, severe glazing, frayed cords or other conditions. Replace any drive belt exhibiting any of these conditions.
NOTE: When installing drive belt on pulley, make sure that all V-grooves make proper contact with pulleys.
Drive Belt, Serpentine—Except SHO
Removal
  1. ani_caut.gif WARNING: USE CAUTION WHEN REMOVING OR INSTALLING DRIVE BELT TO MAKE SURE THAT TOOL DOES NOT SLIP FROM DRIVE BELT TENSIONER OR PERSONAL INJURY AND/OR DAMAGE TO DRIVE BELT TENSIONER AND DRIVE BELT MAY OCCUR.
    Using a 15 mm socket or wrench on bolt attaching drive belt tensioner pulley, rotate drive belt tensioner clockwise on 3.0L (2V) and 3.0L (2V) FF, rotate the drive belt tensioner counter clockwise on 3.0L (4V) to remove drive belt from pulleys. Make sure spring keeper engages into slot.
    Drive Belt Tensioner—3.0L (4V)
Installation
  1. Install drive belt over all pulleys (except drive belt tensioner).
  1. Rotate drive belt tensioner as described under the removal procedure and install drive belt over drive belt tensioner pulley. Make sure that all V-grooves make proper contact with pulleys. Make sure spring keeper releases or improper belt tension will occur.
    Pulley, Routing—Accessory Drive Belt 3.0L (2V)/3.0L (2V) FF Engine
    Item Part Number Description 1 10300 Generator 2 6C348 Idler Pulley 3 3A674 Power Steering Pump 4 19703 A/C Compressor 5 6312 Crankshaft Pulley 6 6B209 Drive Belt Tensioner 7 8501 Water Pump 8 8620 Drive Belt
    Pulley, Routing—Accessory Drive Belt 3.0L (4V)
    Item Part Number Description 1 3A674 Power Steering Pump 2 8501 Water Pump 3 19703 A/C Compressor 4 8620 Drive Belt 5 6312 Crankshaft Pulley 6 6B209 Drive Belt Tensioner 7 10300 Generator
3.4L SHO Engine
Removal
  1. Remove the right front wheel and tire assembly. For additional information, refer to Section 04-04.
  1. Remove the inner fender splash shield.
  1. Remove the alternator shield.
  1. ani_caut.gif WARNING: USE CAUTION WHEN REMOVING OR INSTALLING DRIVE BELT TO MAKE SURE WRENCH DOES NOT SLIP FROMDRIVE BELT TENSIONER OR POSSIBLE PERSONAL INJURY AND/OR DAMAGE TO DRIVE BELT TENSIONER AND DRIVE BELT MAY OCCUR.
    Using a 3/8 inch ratchet on the lifting lug, rotate drive belt tensioner counterclockwise (upward) and engage spring keeper. Remove drive belt from drive belt tensioner.
  1. Lower vehicle.
  1. Remove drive belt.
Installation
  1. Install drive belt over all pulleys (except drive belt tensioner ).
  1. Raise vehicle on hoist.
  1. Rotate drive belt tensioner , as described under Removal procedure and install drive belt over drive belt tensioner pulley. Make sure all V-grooves make proper contact with pulleys. Make sure the spring keeper is released or improper belt tension will occur.
  1. Install the alternator shield.
  1. Install the inner fender splash shield.
  1. Install the wheel and tire assembly. For additional information, refer to Section 04-04.
    Pulley Routing—Accessory Drive Belt, 3.4L SHO
    Item Part Number Description 1 3A733 Power Steering Pump Pulley 2 6B217 (RH) Idler Pulley 3 19703 A/C Compressor 4 8620 Drive Belt 5 6312 Crankshaft Pulley 6 6B209 Drive Belt Tensioner 7 10346 Generator 8 6B217 (LH) Idler Pulley 9 6B217 (Center) Idler Pulley
Drive Belt, Water Pump
Removal
  1. NOTE: If removal of the water pump drive pulley is required, refer to Section 03-03.
    Rotate drive belt tensioner clockwise by hand and remove drive belt from drive belt tensioner .
  1. Remove drive belt from water pump drive pulley and water pump pulley.
Installation
  1. Position drive belt onto water pump drive pulley and water pump pulley.
  1. Rotate drive belt tensioner clockwise by hand and install drive belt over top of drive belt tensioner pulley. Make sure all V-grooves make proper contact with pulleys.
    Pulley Routing—Water Pump Drive Belt
    Item Part Number Description 1 6B209 Drive Belt Tensioner 2 6A312 Crankshaft Pulley 3 8501 Water Pump 4 8620 Drive Belt
Jun 01, 2009 | 1997 Ford Taurus
Dryers Logo
47 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
