Question about Sony VAIO VGN-FS742/W Notebook
Replacing keyboard from VAIO FS-742/W sony laptop
I took off bottom but do not see the keyboard yet.  Does it come out the top?  Doesn't seem too.  Usually keyboards are as simple as ram replacements.  Which way do I access this one?
  • 4,889 Answers
Yes it does come out at the top. I have seen this article and thought it might help you. The first 7 steps show how to remove the keyboard..
http://www.mikeshardware.com/howtos/sonyhdswap/
Posted on Nov 25, 2008
CMOS battery Sony Vaio PCG-4G1L
Instructions
    • 1 Open the Vaio screen until you can easily access the keyboard.
    • 2 Locate the plastic bar that borders the top of the keyboard. Insert the flat head screwdriver at one end of the bar and gently pry it up until you can grip the edge with your fingers.
    • 3 Pry the other side of the bar up with the screwdriver and pull out the entire bar, being careful to mind the ribbon cord that connects the keyboard to the computer.
    • 4 Remove the two screws on either side of the keyboard that secure it to the computer. Slide the keyboard up and place it to the side.
    • 5 Remove the four screws on the exposed metal plate that covers the motherboard and remove it. You should now see the CMOS battery in the bottom-right-hand corner of the motherboard.
    • 6 Remove the battery by gently pulling it up and off the motherboard. Replace it with the same model battery (available at any computer store or online). Reassemble the computer the same way you took it apart.
Jan 12, 2014 | Sony VAIO FX150K Notebook
Remove keyboard 646125-001
  1. Prior to replacing your replacement keyboard for sony vaio vgn-fe880e/h, make sure to remove the keyboard and disconnect the ac adapter from your laptop.
  2. The first step to replacing your laptop keyboard is to remove the screws from the back of your vaio vgn-fe880e/h. Sometimes your laptop will have a picture of a keyboard next to the screws that need to be removed. Otherwise, see your laptop manual for details.
  3. Above the laptop keyboard for sony vaio vgn-fe880e/h, you have a cover panel. If required, remove this part to easily access your keyboard. If you have screws above your keyboard, remove those screws.
  4. Now that you have removed all the screws, you are ready to remove and then replace your new laptop keyboard.
  5. To remove the vaio vgn-fe880e/h Keyboard, take a thin object and pry the keyboard out between the keyboard and motherboard. Be careful when removing the keyboard.
  6. Now that your keyboard is loose, simply disconnect your keyboard. In order to disconnect the keyboard, pay attention to the keyboard connector and connector cable. Unlock the connector cable device and remove your laptop keyboard. Your sony vaio vgn-fe880e/h connector cable should be easy to remove by simply sliding it out.
  7. Now that your keyboard has been removed, get ready to install your new laptop keyboard. Look at the back of the keyboard. If you see any screw holes, you will have a good idea of where to place the screws back in at the bottom of the laptop.
  8. Connect your laptop keyboard for sony vaio vgn-fe880e/h to the motherboard keyboard connection slot. Secure the keyboard cable. Now turn your keyboard in place, and align the grooves on the bottom of your keyboard with your palmrest or plastic bezel. Secure your laptop keyboard in place, make sure it fits properly and is snug. Now simply place the screws back in place.
Nov 30, 2012 | HP 646125-001 - Keyboard Tm - Us
Vgn-nw150j keyboard Sony Vaio many keys stopped working all of a sudden need help?
Laptop keyboards do deteriorate from time to time. Once any key stops working, it is time for a replacement. Doing so is not difficult. Simply undo the case screws and gently separate the case to expose the keyboard. The keyboard floats inside and lays in the main board. Lift gently and pull out the small flat wire connection. The keyboard slides out and replace with a new board. Place flat cable in port on the main board, lay keyboard on top of chassis, close the top/bottom of case, tighten screws and all done. Go on line for Keyboards.
Feb 04, 2018 | Sony VAIO VGN-NW150J/S Notebook
How to replace keyboard on sony vgn-nr498e, broken left hand shift key, i need to replace entire keyboard
If you have the new keyboard, look at the bottom and locate the screw sockets. On the laptop at the bottom, match and locate the approximate location of where each screws are mounted. Remove only those screw. On some laptops, you might need to remove the keyboard top frame - if they are mounted with screws, remove them as well. Some laptops have a small picture or symbol of a keyboard for each screw that needs to be removed on the bottom of the laptop.
Dec 09, 2010 | Sony VAIO VGN-NR498E/S Notebook PC
How to insall keyboard on sony vaio fs 635b
Here is the link to your service manual, the keyboard removal procedure starts on page 7. It is in full color pictures and detailed.
http://tim.id.au/laptops/sony/vgn-fs.pdf
Dec 08, 2009 | Sony VAIO Notebook
Remove and inspect non working keyboard VGN-T37GP
Sony makes getting a keyboard off it laptop like trying to launch a shuttle craft. Take the three screws out on the bottom, Push in the two detent tabs at the top of the keyboard, the hold it in place when on the palmrest. They are located at F5 and Num Lock keys. Now take a thin skewer or wire and push through where the screws were, this will release the keyboard. Now slide the keyboard toward the screen and that releases the lower detents that hold it at the lower part of the palmrest....nor unplug the cable and you are good to go. Oh, by the way below is the link to the service manual for your laptop....it has it fully illustrated.....
http://tim.id.au/laptops/sony/vgn-t.pdf
Oct 19, 2009 | Sony VAIO VGN-T370P/L Notebook
I have a Sony vaio vgn fs 742/w notebook which has startup problem.When switched ON -Vaio &subsiquently Window XP appears
I did not understand real problem Please make more specific for the problem. what happens Win XP appears? then stays rigth there? Does not boot? Thank you
JMC
Aug 04, 2009 | Sony VAIO VGN-FS742/W Notebook
Replace keyboard Sony
Hi..
I will provide you a solution this solution are very useful with you. You can do it with your self to follow this instructions. There are some image on how to replace the keyboard.
These instructions will help you to remove and replace keyboards on various laptops. I will not be able to cover all models but you’ll get the idea. Steps for removing and replacing the keyboard are similar for most laptops.
Warning!
- if your laptop is still covered by the manufacturer’s warranty, do not open the case or you can loose the warranty
- always remove the battery and unplug the AC adapter before you open the laptop case
- if you damage the keyboard connector on the motherboard you’ll have to replace the whole motherboard
- proceed on your own risk
Sony laptop
I took these pictures from a Sony Vaio PCG-K33 (model PCG-9S1L) notebook. Should be similar for some other Sony notebooks too.
sony-keyboard-1.jpg Insert a small flathead screwdriver under the keyboard bezel and carefully lift it up. Continue releasing plastic latches and removing the keyboard bezel with your fingers.
Be careful, on some models the bezel might be connected to the motherboard as it shown on the picture above. If you accidentally pulled the cable, connect it back. It is not necessary to disconnect the keyboard bezel from the motherboard in order to remove and replace the keyboard, just put it aside so you can access the keyboard screws.
sony-keyboard-3.jpg Remove three (or more) screws from the top of the keyboard. Carefully lift up the keyboard from the laptop case.
sony-keyboard-4.jpg The keyboard connects to the motherboard via a flat ribbon cable. Before you pull the cable from the connector, you’ll have to unlock the connector.
sony-keyboard-5.jpg The image above illustrates how to unlock the keyboard connector. Carefully move the connector lock 2-3 millimeters up and after that pull the keyboard cable. To install the keyboard, follow the above mentioned steps in the reverse order.
Toshiba laptop
The following pictures were taken from a Toshiba Satellite A135 laptop. The keyboard removal instructions will be almost the same for most modern Toshiba laptops.
toshiba-keyboard-1.jpg The keyboard bezel removal procedure is similar to the above mentioned Sony Vaio laptop. Lift it up with a small screwdriver and remove using fingers. On most Toshiba laptops the keyboard bezel doesn’t have any circuit board underneath, it’s just a piece of plastic and you don’t have to worry about cables.
toshiba-keyboard-2.jpg After the bezel is removed you get an access to the keyboard screws. Remove two (or more) screws. Release the plastic latch pointed with the red arrow and lift up the keyboard. Carefully put the keyboard aside so you can access the connector underneath the keyboard. Do not forget that the keyboard is still connected to the motherboard.
toshiba-keyboard-3.jpg Before you remove the keyboard, you’ll have to open the connector and release the flat ribbon cable.
toshiba-keyboard-4.jpg Here’s a closeup picture of the keyboard connector on the motherboard. Be careful, this type of connector is fragile. On the left image the connector is closed. On the right image the connector is opened. Unlock the connector by moving the lock up as it shown on the right image and after that release the ribbon cable. Remove and replace the keyboard. For assembly instructions follow all the steps in the reverse order.
Hope it is helpful for you!
Thanks for using Fixya
Regards
ICmanServer
Aug 02, 2009 | Sony VAIO VGN-BX543B Notebook
Vaio drivers
the drivers are available on the sony web site. under service and support at the top right side of the site. type in the model number and search for them
Jul 21, 2009 | Sony VAIO VGN-FS742/W Notebook
Problem with vaio fs 630 w
For free sony support go the link choose the produce and chat for free
http://esupport.sony.com/US/perl/support-contacts.pl
Thanks for using fixya. Hope this solution may have helped you.
Jun 11, 2008 | Sony VAIO VGN-N130G/W Notebook
Sony VAIO VGN-FS742/W Notebook Logo
281 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
