Question about Cameras
My camera's display is black when I try to take a picture, and all the pictures I take are all black. How do I fix this problem?
  • dthomascycle Apr 08, 2009
    how much to repair a stuck shutter? thanks
  • 30 Answers
Your digital signal processor is bad or your lense shutter is stuck on the inside. A stuck lense can be fixed by replacing the lense barrel. Check out Camera Shy Anna on Ebay stores. They can fix your digital camera.
Posted on Nov 25, 2008
My canon powershot sx110 is is only taking black pictures. any suggestions on how to fix this?
Have you downloaded pictures to your computer to see if the pictures are ok, and it's just the display? If not, worth testing. If pix are ok, then it's just the display that's bad. If the pix are bad, get new camera.
Jun 24, 2014 | Canon PowerShot SX110 IS Digital Camera
When I take a picture, the display and picture are black.
The shutter is jammed shut, lens unit needs to be serviced.
Jun 10, 2010 | Canon PowerShot SD850 IS Digital Camera
My LCD screen is black. The camera seems to take
its actually probably the display. there is 3 different displays. 1. shows picture with icons 2. shows just the picture and 3. is a solid black screen. just hit the display button to cycle through until your desired display is present
Feb 07, 2010 | Canon PowerShot A620 Digital Camera
My Canon Sd1000 will not take pictures. You can
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Note that your camera does not have shutter priority mode (Tv) as listed in the link. Instead, put the camera in manual mode and turn off the flash, and also turn off the LCD display (press the DISP button). With these settings, try the fix in a darkened room, opening the battery door immediately after taking the picture. Give it several tries, if no luck consider also trying step 5a described in the link.
Dec 29, 2009 | Canon PowerShot SD1000 Digital Camera
Dear experts! i have a G9 powershot camera, and yesterday i have encounterd a problem.....the screen is not showing any image and i have checked and it is not the display button...it's like trying to take...
If it takes normal pictures even with the black display, your LCD display is likely shot. If photos come out black, chances are that your shutter is stuck in the closed position. Sorry, but there is no safe DIY fix for either problem The camera will require professional repair.
Nov 15, 2009 | Canon PowerShot G9 Digital Camera
Screen is black....will not display whats being taken a picture of nor is taking pictures.
Am assuming that you've already tried pressing the DISP button on the back of your camera. Is it not taking pictures, or are the pictures it is taking also black like the LCD? If black pictures, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
Oct 10, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
No lcd display and no pictures
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jun 27, 2009 | Canon PowerShot G5 Digital Camera
Camera will take picture, but the picture is coming out black!!!! Help Please!!!
Dear vera11:
The symptoms you're describing sound like a classic case of having a faiiled CCD image sensor.
First try pressing the display (DISP) button on the back of your camera several times to see if your image returns at any time. One of the three display modes is "off" to preserve battery life. Your problem may be as simple as inadvertently pressing this button into the off mode.
If that doesn't work, try doing a reset and then removing your batteries from the camera for a few minutes, reinstalling them and turning the camera on to test the LCD screen.
If your screen is still black, but you can clearly see pictures taken previous to the problem, and you can clearly see the menu system when you press the MENU button, then you likely have a CCD sensor problem. Contact Canon Tech Support at 1-800-828-4040 to have the camera repaired.
Hope this helps.
Sincerely,
HeavyDLB
Jun 01, 2008 | Canon PowerShot A520 Digital Camera
Camera does not display the pictures
Have you checked to see if there are picture files when you click the shutter. If so, do the resulting picture files show black images? If so, this would be a defective CCD imager. Canon would also fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Mar 23, 2008 | Canon PowerShot A75 Digital Camera
Cameras Logo
371 people viewed this question
Top Cameras Experts
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
