Operating System Not Found, Can't Use CD Drive
I have a Sony Vaio laptop (PCG-K15). When I turn it on, I get an error that says ''SMART Failure Predicted on Hard Disk 0: TOSHIBA MK6021GAS-(PM) Warning: Immediately back-up your data an replace your hard disk drive. A failure may be imminent. Press F1 to continue.'' When I press F1, it says ''Operating System Not Found'' Unfortunately my CD drive hasn't been working for a while, so I do not have access to any of the recovery disks. I tried to use the F10 function, but nothing happens, I also cannot access the menu by pressing F8. The only thing that I can access (that I know of) is the BIOS menu (F2). I would love to try to recover the data on my computer if possible, but if not, is there at least some way that I can do a system recovery?
I looked through the BIOS and I was unable to find anything with SMART that I could disable. However, by trying different options in the BIOS I am able to get a different error message...I just have no idea what it means! By going through the Advanced Menu and into the Parallel Port Menu, I can disable the parallel port. Then when I restart I get the same SMART failure error, but after I press F1 I get a new message. ''For Realtek RTL8139(X)/8130/810X PCI Fast Ethernet Controller v2.12 (010817). PXE-E61: Media test failure, check cable, PXE-M0F: Exiting PXE ROM. Intel UNDI, PXE-2.0 (build 082). Does anyone know what this means, or if its better or worse? Again, the main problem is I DO NOT have access to my CD drive on the laptop. I do however have an external CD drive which I attempted to install, however at the end of the installation, when I had to restart, this happened. So I don't know if it is properly installed on the computer. Is there any way to access this external hardrive to run the recovery disks. I tried to attach it through the USB ports, but to no success. I don't have too much experience with these kind of computer problems....Any help or suggestions would be great! Thanks!!
  • 1 more comment
  • bazball9 Nov 26, 2008
    I installed it as a CD drive
  • bazball9 Nov 27, 2008
    Well I was afraid you might tell me that, but I appreciate your help! Maybe I'll get lucky and I will be able to recover the data.....thanks again!
  • Debs
    Debs May 11, 2010
    When you installed your external CDrom did you install it as a cd drive or as a harddrive?
  • 32,281 Answers
I'm afraid you have a hard disk problem, it has probably failed.
If you have entered your BIOS and the hard disk has been set to auto (detect) and when you boot up and you press F1 to continue and get a message "Operating System not found" then you have most likely a dead hard drive.
There is a slight chance you may be able to recover data from this hard drive. (A lot of users make a mistake of not backing up their data and eventually they learn from this mistake).
To try to recover your data, you need a USB adapter that you can attach it to your faulty drive and then you need to connect this USB device to a working computer. When you connect it to the computer, anf if you are lucky you will be able to see your hard as an external hard disc, if not then you are out of luck. There are companies that can recover data from dead hard drives, but it will cost you an arm and a leg for their service.
It sounds like you also have a faulty CD drive, without a working CD drive you will not be able to install Windows on a new hard drive in your Toshiba. Looks like you also need to by a new CD drive. This CD drive or your external CD drive has to be able to boot up as a first device to install the Windows CD.
Posted on Nov 26, 2008
Operating system not found
It seems that either the OS is corrupt on your system or the Hard Disk Drive is not getting detected.
To confirm if the hard disk drive is detected you need to go into the BIOS and check if it shows the Drive present.
Just check if the Drive is present in BIOS. If you find the Drive in BIOS You can try to re-install the Operating system using the OS disk.
For any clarification or assistance feel to revert
Sep 27, 2012 | Sony Vaio PCG-71318L
My sony notebook PCG V 505 AX stopped booting with message "operating system not found". I took the help of the 3 system recovery CDs which came along the machine.While the first CD runs...
The problem seems to be in your cds. In this case, especially if the product is still in warranty, you can ask from Sony website if they will send you a new set of cds.
Aug 21, 2011 | Sony VAIO PCG-V505EX Notebook
NOTEBOOK PCG 4A1L DONT HAVE SYSTEM OPERATION
Sorry, your question doesn't make sense. Try it again with more details like error messages.
Nov 27, 2009 | Sony VAIO PCG-TR3AP1 Notebook
Sony vaio operating system not found when computer is first turned on... what can I do to fix this and have I lost all info on my comp? I have a Sony Vaio PCG-394L notebook with Windows Vista operating...
You can try running the installation/recovery disc that came with the computer or the built-in recovery system (if it has one) to try and repair the windows installation. The problem is if the computer is saying that the operating system is not found then critical files got deleted from something like a virus or the hard disc drive has stopped working. You may have to do a format and re-install of the windows OS.
Nov 14, 2009 | Sony VAIO PCG-K23 Notebook
I have a Sony PCG-FRV37 ''error loading operating system''
Look at the bios and see if the hard drive is detected
if not suspect a virus , faulty hard disk or motherboard
Aug 26, 2009 | Sony VAIO FRV37 Notebook
OPERATING SYSTEM NOT FOUND....NO ACCESS TO CD DRIVE
Connect your external CDROM to the laptop. I think it is a USB CDROM. Enter your bios setup. In the boot device section, try to find any option which says First Boot Device -> USB CDROM. If you can set this things then the computer will be able to boot from your external cdrom.
Nov 26, 2008 | Sony VAIO GRX550 Notebook
hiiiiiiiiii ther
how r u ??
1st u need to reinstal the OS
so u could repair the OS from teh original windows CD
by copying the file sys again
or by going to repair consol in the CD
but if this didn't work
than u could reinstal the OS BUT WITHOUT FORMATING the sys partition
than u can back up ur data and than make a clean instlation
and if u need any further assistance email me
u take care and have fun
salammmmmm {bye in arabic }
p.s rate me thanks
Nov 25, 2008 | Sony VAIO GRX550 Notebook
Operating system not found? I have got Windows Boot Genius to fix problem safely!
Jan 08, 2008 | Sony VAIO PCG-K25 Notebook
Computers & Internet Logo
1,118 people viewed this question
David Payne
David Payne
