Question about Whirlpool ED5FHEXMQ Side by Side Refrigerator
Fridge and freezer not cooling top shelves
I have a side by side Whirlpool ED5FHEXNL and was cleaning it the other day. Yesterday I noticed the top section of the freezer wasn't cold (specifically on the door). Made sure it was closed properly and later in the day noticed that it still wasn't cold. This morning I noticed that the refridgerator had the same issue - didn't seem cold on the top 1/2. I also noticed that my ice was melting now so I dumped that but again the stuff in the bottom of the freezer is still frozen. I took the back cardboard off and see the white fan is running and sounds like the black round box is running. I took the panel off inside the freezer and there was some frost but not anything overwhelming and it definitely seems cold. I also unplugged the fridge for a few minutes and plugged it back in. Any ideas what's going on or what I can do? Thanks in advance, Kim Yardis
  • Kimberly Yardis Jan 05, 2007
    Forget it - figured out the problem myself - thanks anyway!
    I found a huge chunk of ice in the back that had fallen on top of the fan. Once I lifted the ice the fan started right up and it's back to normal now. Guess I didn't need to take all the covers off but at least I had a better view of everything.
  • 237 Answers
What was the problem?
Posted on Jan 05, 2007
I have a GE Profile model # TPX2451YEBS side by side fridge. Both sides are not cold on upper part. The food in fridge on top 2 shelves and door shelves is just cool. The frozen food in door...
Sorry to hear about your problem.
Sounds like you have a defrost issue. Hence your unit is not defrosting. All of this apply's if your freezer side has ice . If not. you have other issues, this does sound funny, but this is why your refrigerator side is warm, or not cooling.
Here is a list of some things that can go wrong.
1. Defective heat coil
2. Defective defrost timer
3. Defective defrost sensor
4. Defective Fan
5. Defective compartment inlet damper (on some models)
You should call a service company to resolve your issue.
Since I tried to help you, Please help me and Rate/Vote on the response. Thanks
Jan 02, 2011 | GE 23.1 Cu. Ft. Side-by-Side Refrigerator...
8 year old Whirlpool Gold refrigerator: Freezer icing up. Found ice on shelves and on the bottom under the vegetable hydrators. The shelves and drawers constantly have a humid film on them. Last week,...
for no frost type;cleaning of freezer cub underneat is a must...cloggged drain outlet buildup thick frost on your freezer cub..
.ie..for frost type;you must set your thermostat setting to normal,replace it with new one
Oct 20, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Freezer won't stay consistently cold
replace temp sensors in fridge and freezer (easier to do together) should work fine...
Feb 04, 2010 | Amana ARS266ZBS Side by Side Refrigerator
Cold air not getting from Freezer to Fridge
I actually know nothing about refrigerators, but was able to fix the same exact problem where cold air was not getting to the fridge side of the side by side. The freezer was working just fine. I unplugged the fridge and freezer and tore all the shelving out to get behind a panel in the back of the inside of the freezer. There is a pass-through between the freezer and the refrigerator at the top back of the freezer on the side-by-side refrigerator. The passthrough was totally frozen over and blocking air from passing through and cooling the refrigerator side. I let it all de-thaw and then was able to pull the chunks of ice out, and all seems to be working great now. Be careful getting the ice chunks out as there are some controls there - it's probably best to just let it all thaw and melt by itself - which wouldn't require tearing all the shelving out. One could simply let the freezer dethaw for a day and then plug back in and both sides should work just fine.
Aug 15, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Fridge and freezer warm at top, colder but not normal on lower shelves
How old is this frig? If it is older that 12-15 years, get a new one. Make sure there is not blockage to keep the air from circulating properly. The vent from the freezer to the cooler should also be free from blockage as well.
Aug 24, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
Fridge and Freezer losing cooling
thermostat control to deice the freezer is malfunctioning need a service tech to replace it so it doesn't keep the deicer on . Its exactly that, a warmer to deice the coils.
May 27, 2008 | Fisher and Paykel Active Smart E522B...
The refrigerator side is not cooling.
ALMOST DEFINATELY YOU WILL HAVE AN ELECTRONIC CONTROLLED AUGER(MOTOR)CONTROLLING THE AMOUNT OF CHILL ENTERING THE FRIDGE COMPARTMENT. IF YOU SET THE FRIDGE TO MINIMUM AND LISTEN CAREFULLY, THERE SHOULD BE A SOUND INDICATING THE AUGER IS WORKING.( OPENING AND CLOSING THE FLAP). SET TEMP. TO MAX AND LISTEN. IF NOTHING, IT COULS BE A DEFECTIVE MOTOR OR FAULTY THERMISTOR(TEMP. PROBE).
Aug 08, 2007 | Samsung RS2556 Side by Side Refrigerator
Whirlpool ED5FHEXMQ Side by Side Refrigerator Logo
170 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
