Question about Asrock P4145GL Motherboard
Hi,i have a pc with windows Xp installed in it with an asrock p4145gl and intel processor and i am getting error message that the registry file is corruputed when ever i try to turn on the system,but when i install the same hard drive on another mother board it is working fine ..i thought it is the issue with the windows Xp and tried to do system recover but didnt work..any help
P4145gl is my mother board.ihave a problem in my audio part is missing
Posted on Dec 06, 2008
  • 94 Answers
You going to repair or reformat your hardrive using windows xp installer disk just skip to recovery console
Posted on Nov 26, 2008
I have no sound driver
Please use the below link
For all drivers.
select the operating system then
select DRIVERS in select download type.
then download the sound drivers. and install.
For Audio drivers: Click on download
AUD_Vista_Win7_6.0.1.6201_PV.exe for vista or win7 AUD_XP_5.10.0.6201_PV.exe for xp. If you satisfy with my solution please rate/vote for me.
Rating/Voting will encourage me to help others
Jul 02, 2011 | Intel D945GCCR Motherboard
First download Realtek* ALC Audio Driver .
How to Install
1. Download this file to a folder on your PC.
2. Double-click the filename to launch the installation
IMPORTANT: Audio drivers may fail to install in Windows* XP 64-Bit Edition. Symptoms may include error messages, such as "Error in installation" or "Unknown error". Microsoft's Update for Windows XP x64 Edition (KB901105) fixes this issue. After installing this update, the audio drivers for Windows XP 64-Bit Edition will successfully install.
Dec 03, 2010 | Intel D945GCLF Motherboard
Computer clicking inside...display flashes on and then just restarts on its own. Very unstable. Have ran the disk error option off Windows Explorer (Windows XP) as well as the file check...
open the case and see if a wire is touching a fan...
if the fans cant spin they cant cool the system and it will shut itself down to protect the processor and other systems.
Jun 11, 2010 | Compaq Presario S5140WM (DM198B#ABA) PC...
Keep getting this message <window
  • "Windows could not start because the following file is missing or corrupt:
    <Windows root>\system32\hal.dll.
    Please re-install a copy of the above file."
  • "<Winnt_root>\System32\Hal.dll missing or corrupt:
  • "Cannot find \Windows\System32\hal.dll"
  • "Cannot find hal.dll"
The "missing or corrupt hal.dll" error displays shortly after the computer is first started. Windows XP has not yet fully loaded when this error message appears. CauseCauses of the "missing or corrupt hal.dll" error include, naturally, a damaged hal.dll DLL file or a hal.dll file that has been deleted or moved from its intended location.Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged hard drive.
    Please let me know you have any further questions or concerns.
May 08, 2010 | HP Compaq 6720s Notebook
The file <windows root>\system32\hal.dll.
Restart the PC. The hal.dll error could be a fluke.
Check for proper boot order in BIOS. You might see the hal.dll error if the boot order in BIOS is first looking at a hard drive other than your main hard drive.
Note: If you've recently changed your boot order or recently flashed your BIOS, this may be what's causing your problem.
Run Windows XP System Restore from a command prompt. If this doesn't work or you're receiving the hal.dll error message before you're able to complete this process, move on to the next step.
Repair or replace the boot.ini file. This will work if the cause of the problem is actually Windows XP's boot.ini file and not the hal.dll file, which is often times the case.
Note: If repairing the boot.ini does correct the hal.dll issue but the problem reappears after a reboot and you've recently installed Internet Explorer 8 in Windows XP, uninstall IE8. In this specific situation, IE8 could be the root cause of your hal.dll problem.
Write a new partition boot sector to the Windows XP system partition. If the partition boot sector has become corrupt or isn't properly configured, you may receive the hal.dll error.
Recover data from any bad sectors on your hard drive. If the physical part of your hard drive that stores any part of the hal.dll file has been damaged, you're likely to see errors like this.
Restore the hal.dll file from the Windows XP CD. If the hal.dll file is truly the cause of the problem, restoring it from the original Windows XP CD may do the trick.
Perform a repair installation of Windows XP. This type of installation should replace any missing or corrupt files. Continue troubleshooting if this does not resolve the issue.
Perform a clean installation of Windows XP. This type of installation will completely remove Windows XP from your PC and install it again from scratch.
Note: While this will almost certainly resolve any hal.dll errors, it is a time consuming process due to the fact that all of your data must be backed up and then later restored.
Feb 15, 2010 | Dell Latitude E5500 Laptop
STOP C0000221 erro de hardware desconhecido systemroot system32 ntdll.dll
You may receive one of the following stop error messages while working on your Windows XP computer.
STOP: C0000221 unknown hard error
Path\File_nameSTOP: 0xC0000221 unknown hard error
C:\Winnt\System32\Ntdll.dll (or another specific file or driver)
Note: The error message may be discussed in many different formats-blue screen or message box. It depends on when the corrupt file was detected.
Similarly, you may receive the following STOP messages when a critical system file fails to load on your Windows NT and Windows 2000 computer.
<path>\<file_name>STOP: 0xC0000221 unknown hard error
Note: Some other drive may also be given in the message.
On Windows 2000 the following error message may display:
You usually face this problem when an incorrect driver for one or more hardware is installed on your system. For instance, the error messages described above are displayed when you install a millions of instructions per second (MIPS) driver on a x86 system.
Cause of the Error
This error occurs if the file given in the error message is damaged.
Your Windows XP operating system checks the following files for integrity during system startup:
  • All driver files, excluding the files that loaded using the system loader to start your system .
  • All DLL (Dynamic Link Libraries) on the system. These include, Graphics Driver Interface (GDI), User, Ntdll, Crtdll, Shell, Kernel and several other DLL files on the system.
  • On Windows NT and 2000 computers, all DLLs loaded in the Window server address space are also checked.
The problem may also occur if an Iomega Zip drive is connected to the same cable as your hard disk drive.
Resolution Method
You can resolve this issue by removing the corrupt driver from your computer and then reinstalling a fresh and healthy copy of the driver. You may need to use the Device Manager utility to remove the driver. It is recommended that you clean your registry with the help of a reliable tool, such as RegGenie to ensure that all entries related to the uninstalled driver are removed from the system. After you have completely removed the corrupt driver, restart your system and install a fresh copy of the driver on the system.
If this step does not resolve the problem, you may have to reinstall Windows XP.
It is recommended that you regularly clean your registry with the help of a registry cleaner tool and perform antivirus and antispyware scan using tools, such as Antivirus Plus and StopZilla to prevent such errors from occurring on your system.
Feb 03, 2010 | Intel Computers & Internet
Error 112 when attempting to install Adobe Photoshop LE
Error 112 is a standard Win32 error code and represents an out of disk space error.
Photoshop 5 Requirements
* Windows:
* Intel Pentium processor
* Microsoft Windows 98, NT 4.0, 2000, Me, or XP
* Internet Explorer 5.0, 5.5 or 6.0 (updated with applicable service packs)
* 128 MB of RAM
* 150 MB of available hard disk space
* Color monitor capable of displaying thousands of colors at a resolution of 800 x 600 or higher
* CD-ROM drive
May 02, 2009 | Computers & Internet
Audio Problem
Intel Desktop Board D945GCNL HD Audio Controller 5605 Windows Vista(32/64)/XP(32/64)/2000
Installs the Realtek audio driver version 5605 for Intel® Desktop Boards.
Apr 23, 2009 | Intel D945GCL Motherboard
I am trying restore windows vista on my ACER Aspire 5100 but a message keep coming up saying that Windows cannot open the required file D:SourcesInstall.wim. It also says the file does not exist and to...
This error is due to....
  • The default security provider in Windows XP, or
  • the System drive letter
  • To solve dis issue.. try one of the methods
    1)Reset Windows XP Default Security Provider
    1. Open Start menu, select Run, type regedit and then press Enter.
    2. In the Registry Editor window, locate and delete the following registry keys:
      HKEY_USERS\.DEFAULT\Software\Microsoft\Cryptograp hy\Providers
      HKEY_USERS\S-1-5-20\Software\Microsoft\Cryptograp hy\Providers
    3. Exit the Registry Editor and restart your PC
    2)Reset The System Drive Letter
    1. Start your computer in Safe Mode-turn on the PC, and press F8 during startup. Next, when the Windows Advanced Options menu is displayed, scroll down and select Safe Mode.
    2. Open Start menu, select Run, type regedit and then press Enter.
    3. In the Registry Editor window, locate the following registry keys:
    4. Edit this key to change the value of the system drive.
    5. Exit the Registry Editor and then restart your PC
    Mar 20, 2009 | Computers & Internet
    I can not boot my pc with intel MB845 chipset,error in first
    RAM, Processor and Motherboard could cause the same problem. check all these.
    some time virus also not allowed to install windows.
    Nov 29, 2008 | Intel Desktop Board D845WN Motherboard
    Computers & Internet Logo
    188 people viewed this question
    Top Asrock Computers & Internet Experts
    Computer Links
    Iqbal Husain
    Iqbal Husain
    Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
