Question about Maytag PAV2300 Top Load Washer
My daughters maytag has water leaking from the bottom.
The maytag has water leaking from the bottom of the washer. Iam thinking the pump, a hose to the pump. Is there a way you can lift the shell up and expose everything at the bottom?
    Sergeant:
  • 217 Answers
Check the easy stuff first, fill hoses tight?- drain hose cracked?
Failing those checks, cut a piece of cardboard slightly smaller than the size of your washer. Slip the cardboard under the washer and run a short load. Look carefully at the water mark on the cardboard. The mark on the cardboard the water leak will leave, will help you tell from which side or front to back the leak is common from. This will help point you in the correct direction to look for the trouble maker.
Posted on Nov 29, 2008
Leaking water on the bottom of the washer while washing. Could you please tell me what`is wrong with my washer.
Water leakage
1. Inlet hose loosely connected to valve---tighten hose connection
2. Drain hoses not tight on pump----tighten hose clamps
3. Broken hose---replace hose
4. Leaky gasket---replace gasket
5. Cracked housing---replace part
Sep 22, 2011 | Maytag Neptune MAH5500B Front Load Washer
I have water leaking from the middle bottom of washer, not leaking from hoses or water outlet
sounds like the water pump, pull the housing and look at the bottom center for a oval shape with two hoses.I bet you find the leak there.......GOOD LUCK
Nov 15, 2010 | Maytag SAV5710 Top Load Washer
Leaking drum on maytag washer.
Go to www.repairclinic.com and enter MAV6000. With luck, you will be presented with a list of common replacement parts and may be able to view a generic Maytag video showing disassembly and replacement.
May 23, 2017 | Maytag Atlantis MAV6000 Top Load Washer
Leak
You have 3 areas to check. Drain hose, water pump and hot/cold water valves. Any of those 3 areas can be the cause. Most often leaks are caused by loose hoses, but neptunes use a plastic water pump that can clog and lose bearing water seals as well. Try the easy options first, then if those solutions don't point to the cause, remove the front cover and check the water pump for moisture.
Mar 12, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag atlantis washer got water leaking from
I have an Atlantis myself. There can be several problems. Did you check that the fill hoses in the back are not leaking? Are they tight? There are hoses inside the washer and a pump near the front. I replaced my pump last year and I,m getting ready to replace the thrust bearing assembly (spin issues). Does the washer leak with every load? make sure water is not splashing over the tub when filling. The front panel comes off if you can and leave off and watch to see where water is coming from.
Feb 17, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Maytag washer leaking between cycles or if stopped during fill
lift the top up on the washer and see if the fill hose is crack or broke,hose on right side
Jun 18, 2009 | Whirlpool LSN1000LW Top Load Washer
Washing machine is leaking from bottom of machine
Wow, this washer is very old. im sure the drainage hoses will need to be inspected or replaced asap. i would also check the pump housing for cracks as well. make sure the water inlet valve assembly ins in good condition as well. Replace any hose or valve that is leaking or, damaged.
Jun 05, 2009 | Maytag Washing Machines
Water leak from bottom
then you may be leaking from the water pump. maybe is worn out, only way to find it is to remove the cabinet an do a load test an see if it comes from there, if the hoses are fine then check the pump.
May 13, 2009 | Maytag LAT3600A Top Load Washer
Washer leaking water on floor
Need to check drain pump and its hose connections. If its not from the drum seal then that's usually where the leaks occur.
Mar 30, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Maytag PAV2300 Top Load Washer Logo
248 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
