Question about Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher
Soap cup still has soap at end of cycle, but cup is open
My detergent is still in the cup at end of cycle. The cover is open but soap in cup is wet block of soap. It happens every other time i run the unit. Every opposite cycle, dishwasher runs correctly.
  • skovatch Dec 17, 2008
    Is the soap cup completely open or partially open? I'm inclined to agree with this discussion that says the entire soap dispenser needs to be replaced.
  • skovatch May 11, 2010
    I have this dishwasher as well, and we thought it was switching from liquid to powdered soap, but lately we have been using all powder and still have the same problem.
  • Bosch Master
  • 43,501 Answers
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Posted on Sep 30, 2010
Soap dispenser does not open during washing
Dishwashers have a soap dispenser located on the inside of the door. When the timer cycle calls for the soap to be emptied into the dishwasher, it either sends electricity to a bi-metal switch that opens it, or it mechanically opens the soap dish. On many dishwashers, a plastic actuator arm mechanically links the timer to the detergent cup. When the timer reaches the proper time in the cycle, the timer activates a lever that opens the detergent cup. If the linkage is broken or defective, the cup stays closed after you've closed it. Check the link and repair or replace it, as necessary.
The detergent cup itself can become clogged with old dried detergent that prevents it from opening. Sometimes just cleaning the cup takes care of the problem. If not, you probably need to replace the entire cup assembly.
Dec 07, 2017 | Dishwashers
The soap dispenser only closes after several tries. At the end of the cycle, the soap is wet and stuck in the open dispenser
May want to try liquid detergent instead. Sometimes using too much detergent will prevent the dispenser from opening and then the soap turns into a wet glob in the dispenser.
Mar 15, 2016 | Dishwashers
I have a whirlpool gu2400 dishwasher. The spring loaded soap dispenser door does not open during the wash cycle to release the soap.
Whirlpool dishwashers use a wax motor or a solinoid to release the door at a specific time during the cycle. So for proper cleaning the soap cup is nessesary . The part isn't that expensive and fairly simple repair.
Dec 30, 2014 | Whirlpool GU2400XTP Built-in Dishwasher
Model GSD2100R00BB - the soap dispenser opens and the arm extends but the dishes do not get clean, just wet and does not leave soap residue on the dishes.
heatman101
Aug 28, 2011 | GE Dishwashers
Soap still in dispenster at end of cycle and spinner on bottom will not turn
heatman101
Sep 19, 2010 | Maytag MDB6650A Built-in Dishwasher
The soap container will not open during the wash cycle. The soap is still there after the whole cycle including drying is done.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There are three common problems that cause the Soap Dispenser or Cup not to open. I have a tip that will explain these problems in detail....
heatman101
Sep 07, 2010 | Asko 24 in. D3112 Free-Standing Dishwasher
Soap does not dispense from cup.
heatman101
Sep 07, 2009 | KitchenAid KUDK03ITBK Built-in Dishwasher
Small door where soap goes does not open during cycle.
Most detergent cups are spring loaded and released by either a mechanical trip or by a bi-metal strip latch. If your model is a simple dial timer type, look for a mechanical linkage between the timer and detergent cover. If it is a touch panel control, look for the other type. The bi-metal strip type has a heating wire wraped around it that can open electrically or burn out physically.
Mechanical types can be checked by rotating the timer knob 360 degrees while watching the detergent cover linkage. Electrical types require use of an ohm meter to check the resistance of the heating element on the bi-metal strip.
If you are using powder type detergent, make sure it is not caked when added to the cup or it can jam the rotating type covers.
Feb 15, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Soap dispenser cover won't close
It sounds like it may be stuck between cycle steps.(this sometimes happens if the washer is open during a cycle)Try and run it through one full wash cycle as it is.Then check to see if the soap door will close.If not,the lack may be broken
Jan 09, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher soap cup lid will not open during a wash cycle
heatman101
jj
Dec 31, 2008 | Maytag 24 in. MDB5651A Built-in Dishwasher
Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher Logo
204 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
