Question about Brother IntelliFax-2820 Laser Fax
How do I change the printout on the receiving end of the fax as it relates to who the fax is from?
I'm getting an error code comm.err 20.01 please help me with this problem.
Posted on Nov 25, 2008
The fax is received by the other party but we receive an error code J72. There is no jam
Dear
If you are sending the fax using ADF, there may be the document jam, Open the ADF cover check the path for any foreign objects.
Also you can send from platen glass without document jam.
Also this may happen to the other end fax machine, better you do a test copy from ADF and Platen glass. and confirm your fax machine is ok.
Thanks.
Mar 05, 2015 | Panasonic PanaFax UF-8000 Laser Fax
Daily report/printout
At the end of the each day,press funcktion and then report,select activity report and press "ok"
This is the only way the activaty report can be printed at a spesific time.If you switch the report on in the report settings it will only print when the memory is near full.The other way is to switch TX report to on in report settings,but the you will get a report after every fax that you sent.
Mar 02, 2009 | Canon L220 Plain Paper Laser Fax
Have dial tone, but can't fax
It sounds like the modem is bad a possible electric serge
Jan 08, 2009 | Brother IntelliFAX 4100 Laser Fax
Poor fax printout quality
I would say you have a bad drum / toner cartridge.
Stuff you receive with vertical lines is probably the sender's dirty scanner.
Nov 04, 2008 | Canon LaserClass 2060P Plain Paper Fax
Lexmark x5150 all-in-one inkjet printer. trying to get the fax to work. i have dsl.
You may have to experiment to get the fax to work on DSL. Try these suggestions: press MENU, then scroll to:PRINT REPORTS. Scroll to HELP LIST and press SET BUTTON. Press START button to print HELP LIST. On the HELP LIST printout, locate the FAX MENU. Using a cell phone, call your fax and see if the fax answers. If not, try changing the following settings (change one setting, then call the fax with the cell and see if it answers, Make sure you set each changed setting back to what it was, until you find the right one.) try changing: RING DELAY, F/T RING TIME, EASY RECEIVE, OVERSEAS MODE. Also on the HELP LIST, find the INITIAL SETUP MENU. Select RECEIVE MODE, and try each option, again calling the fax with your cell until it answers.After you get the fax to answer calls from your cell, try sending and receiving with another fax, or use Brothers AUTOMATIC FAX-BACK SYSTEM, which will automatically send your fax a test printout when you call it. Just call 1-800-521-2846 from your fax machine, IT MAY BE ALREADY PROGRAMMED INTO YOUR MACHINES AUTO DIAL LIST, AUTO DIAL NUMBER 001..
Aug 16, 2008 | Lexmark Office Equipment & Supplies
Error 0495 - Receiving Faxes
Might be a problem with speed of the fax. See related question.
Jul 11, 2008 | Epson Stylus CX9400 Photo Printer
Recieving fax no printout, all other printing processes ok
When you say all other printing processes are ok, I am assuming you can make copies and print from the computer. If so...then are the blank faxes coming from several different fax machines or are they coming from one particular fax machine. If one particular fax machine, then the problem is probably on their end. I need to go backwards a second....when you receive a fax does the machine spit out a blank page or no paper is fed at all..it just receives the fax? Is the machine programmed to just receive faxes to memory to be printed out later? It doesn't make sense for it to print or copy but not to print a fax. If problem persist try a different fax modem.
May 08, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
Panfax uf 885
If it happens on all printouts, and not just from one sender, then replace the toner cartridge. That will clear up most image related issues.
Jan 18, 2008 | Panasonic Panafax UF-885 Plain Paper Laser...
Fax history
Depending on your model, You need to press the MENU button, or check if there is a REPORTS button. For either case, scroll through the display until you come to the PRINT REPORTS mode. It may be worded differently on your machine, but what you are looking for is the FAX ACTIVITY report. You can also get printouts of TRANSMISSON OR RECEIVE ACTIVITY, and also CALLER ID, iIf you encounter a command called PROTOCAL DUMP, this also is a printout of fax activity.. Whether your activity report goes back to july 2007 is unknown. Normally an activity report shows a certain number of activities per printout, say the last 50 fax operations. It is not based on a certain timefrane.
Jan 09, 2008 | HP 920 Plain Paper Fax
Document sent is blank for recipient
Hi there check the machine scanner light by putting the original in the feeder and doing a copy. If the printout comes out OK then it either could be the other fax machine you are trying to send it to or you have a intermittent fault with your scanning lamp (Section).
You also must make sure that the original is text face down.
Hope this helps you
Thanks J
Jan 08, 2008 | Panasonic KX-FP121 Plain Paper Thermal Fax
Brother IntelliFax-2820 Laser Fax Logo
290 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
