Question about Home
No water coming out from the shawer head
Water comes out of a little plastic pipe that is beneath the electric shawer but not from the shoer head. Water all splashes from beneath the electric shower body
  • 4 Answers
No water usually means that the solenoid coil needs replacing. You can get them here: www.dublinshowerrepair.com/showerparts/
Posted on Aug 30, 2013
  • 101 Answers
Welcome to Fixya.com
If I understand you correctly your not getting any water out of your shower head .It could be your shower head is clogged,
or your diverter is bad. Diverter takes the water up to the shower head.
Posted on Dec 17, 2008
The sprinkler system is shut off but there is still little water coming out of the sprinkler head. What is the cause of this problem?
Water will continue to run back down the hills to the lowest Heads and Some water will come out.It will stop once the water in the lines has Drained out.
Oct 02, 2014 | Garden
Water will not come through the brewing head. I have tried priming it by passing water through the steam pipe as described in the manual and although water comes through the steam pipe it still will not...
Either the screen is blocked or the valve seat is clogged. Remove the screw and screen make sure you can see light through every hole in the screen. Now try to run the head if water flows, screen was dirty if no water, remove 2 allen wrench screws and diffuser and spring and valve(DO NOT LOSE SPRING AND VALVE), run the head, if water flows the blockage is clear re assemble and you are back in business. Here is a little pic to help you on the way.
Jan 16, 2011 | Gaggia Classic Espresso Machine
Hot water is spraying out the plastic coupler that comes out of the water heater up to the pipe. Want to know if there is any way to fix this problem in expensively.
First thing to do is wrap rag or towel around spraying joint to localize water.
Next, turn off power to water heater.
If gas, rotate knob to pilot so pilot light stays lit but burner does not come on
If electric, turn off circuit breaker.
Close cold-water shut off valve above tank.
Open tub valve to release pressure on water heater.
Wait for water to cool before working on water heater to avoid high pressure scalding water.
When finished, make sure tank is full of water and water comes out of tub valve before turning on power.
Water heater should not have plastic couplings.
I can't see your problem exactly, but water heaters have 3/4" nipples coming out of top.
Easiest solution is use flexible connectors from Lowes or Home depot.
Flexible connectors are 24" or 30" long and have 3/4" nut on each end, so disassemble existing pipes using pipe wrench.
Lowes and Home depot can help you select appropriate pipe >> take several phone-photos of your pipes to home center so they can see your problem precisely.
Attach 3/4" male adapter on end of pipe.
Attach flexible connectors between pipe and water heater nipple.
Cold water line has shut off ... make sure this attached to nipple marked cold.
Make sure hot pipe is attached to nipple marked hot.
Use teflon tape on threads.
Add a comment if you need more help.
Dec 09, 2010 | Rheem Water Heaters
No water from shower
Remove the shower head and try flushing out the pipes by turning faucet wide open on each side, Then chk shoer head for any sign of scale being in the water. If there is, Your water heater needs draining, cleaning, descaling. good luck, Ned
Oct 18, 2009 | Home
Same problem with my classic gaggia.
Hi Marc
Just bought one this week with exactly the same problem. As a last resort I opened it up to find the pump had come off the rubber support kinking the pipes beneath so no water could get in.
Undo the 2 philips screws on the top, take off the lid and water filler spout and take look. Looking down from the front of the machine, the pump is at the back to the left. If it's just floating in space as mine was, simply push it gently back into the rubber support beneath making sure you don't kink the pipes.
Mine came by DHL from Italy with no right side up marked on the box, so no wonder it came loose!
Hope this fixes it.
Matt
Aug 25, 2009 | Gaggia Classic Espresso Machine
Water does not come from the shower head
If your showre head has an external adjustment (usually on the face of the head) make sure that it is opened. Shower saver type valves have a push button on the pipe from the wall to the showerhead, usually close to or are a part of the showerhead. Make sure that it is opened, if you have one. Once done, remove the shower head and turn the water on. If you get water, look into the shower head. Most come with a water restrictor and it can come out of position and block the passage of water. The restrictors can vary in appearance, but usually they consist of a rubber washer and plastic disc, and are in the back of the showerhead where it unscrews from the piping from the wall. If you can get water without the shower head on, but no water through the showerhead, you can take it apart and look for restrictions or just replace it. If you cannot get water after all that, the problem is in your faucet or piping. Most Delta single handled faucets that I'm familiar with have a spring and cup washer valving arrangement. Those equipped with scald gard are somewhat more difficult to work on. Parts are available from H/Depot, Lowe's and similar. Hopefully the problem is in the showerhead proper, and not in the valve.
Best 'o luck, --W/D--
Jul 24, 2009 | Delta & Single Handle Shower Faucet
Inside rhe house unit is leaking water from around the pvc pipe.
cant understand what you are describing. is the drain pipe clear. water coming out end into french drain or pump. if not clear out by mechanical means or by blowing.
Jan 15, 2009 | Ruud Heating & Cooling
Water Leaks from beneath my washing machine
Our WM2077CW just started the water leaking from underneath. We unplugged the electrical cord and disconnected the hoses (water, drain). We then removed the inspection plate from the back and checked for wet hoses. The big black hose on the bottom was a little wet. On careful examination we found a small hole that looked like a material fatigue failure at the point where the accordion part of the hose met with the solid part of the hose near the main drum connection. I suspect this is may occur in other LG washers of the same design. Unless your floor is perfectly level it's hard to tell whether coming from the left or right side really indicates where underneath the water is coming from.
Nov 26, 2007 | LG WM-2277HW Front Load Washer
Home Logo
361 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
