Question about Nintendo DS Lite Console
Ds lite possible fuse problem
My ds lite has the symptoms of the blown f1 fuse, im not really good at taking things apart and soldering them, any ideas of where i can get this repair relatively cheap? nintendo charges 80 dollars post warranty. the ds doesnt turn on or charge, just bought new battery, when i plug in charge light flashes orange moment, then all lights go black
  • 88 Answers
  • 103 Answers
This probleem look indeed like a Fuse problem. If you can't repair it youreself, use google to find a repair service in your neighbourhood.
I know it could not be easy to find some but they out there.
What you could do is go to eBay and find some resellers of DS Lite parts and send them a personal message and aske them if they can help you replace the fuse.
Posted on Nov 27, 2008
When i put my ds charger in it gose red for one second
Sounds like your F1 fuse has blown. This fuse is located inside the DS lite and is very small (the longest side being less than 2mm long).
I would suggest that if you have a warranty that you send it off.
If you don't have one then there are plenty of repair services avaliable on the internet such as ebay.
If you have the skill and time to replace the F1 fuse yourself then there are a few items you will need:
A soldering iron ad solder,
A replacement SMD 0603 1A fuse (ebay have these, search F1 or F2 fuse),
A triwing screwdriver (found on ebay, search DS lite triwing screwdriver).
A precision crosshead screwdriver.
If you would like a guide on how to dismantle the DS lite and the location of the F1 fuse then click on my name and you will find the relevant guideson my profile page.
If you need any further help or advice please feel free to contact me.
Regards,
SOD69
Apr 11, 2010 | Nintendo DS Lite Console
Nintendo DS Lite won't turn on although battery fully charged
If the green light doesn't come on at all then the chances are the F2 fuse has blown.
If you have a warranty then I would suggest that you send it off for repair, if not you can either take it/send it off to a repair specialist or if you are willing to you can repair it yourself.
If you do decide to repair it yourself you will need a few things:
Soldering iron & solder (preferabliy with a 1mm or thinner tip)
1x SMD 0603 1a fuse (ebay search for F1 or F2 fuse)
A triwing screwdriver (also avaliable on ebay)
The fuse is very small (the longest side being less than 2mm)
If you need any help with taking the DS lite apart and locating the F2 fuse I have a few guides written up... click on my name and you should find them on my profile page.
If you need any further help or have anymore questions feel free to contact me.
Regards,
SOD69
Apr 09, 2010 | Nintendo DS Lite Console
Unit won't turn on !
This could be due to several things, the main ones being:
1) One of the screens is either not correctly connected or has devlouped a fault... If one of the screens flickers after you switch it on and just before the green light goes out then the screen that doesn't flicker is causing the problem, firstly try reconnecting it and if that doesn't work you will have to replace it, both screens are avaliable for a reasonable fee on ebay, search for either "DS lite top screen" or DS lite bottom screen".
2) Locate the inductor labled "L2" if this is missing then you will need to either solder it back on if you can find it or else you can buy another one again on ebay for a reasonable fee, search for "DS lite L2".
3) If both the above fail then chances are you have blown a fuse, if you can charge the DS then it is not your "F1" fuse in which case you will only need to replace the "F2" fuse, firstly desolder the old fuse and then solder on the replacement fuse, this should solve the issue. If however the charging light stays on for a very brief time (i.e 1-2secs) then you will have to replace the "F1" fuse, locate the "F1" fuse and follow the sames steps stated for the "F2" fuse. These fuses are also found on ebay, search for "ds lite fuse" and buy the quantity you require.
If you don't have access to soldering equipment or are unable to solder these very small parts (i.e fuse dimensions - 1.5 mm x 0.8 mm and the "L2" inductor dimensions - 2.5mm x 1.8mm x 1.8mm) The is a product called wire glue which is avaliable from ebay (located in the USA) which is fantastic as it is a glue with conductive properties.
You may find guides that tell you to "bridge" the fuses and "L2" inductor but I would strongly advise against this, afterall they are there for a reason and just think what damage would have happend if that fuse hadn't have blown.
Here is an image for the location of the fuses, also if you look just under the power switch you will see the "L2" inductor:
http://www.xdupe.com/assets/images/nintendo_ds/tutorials/ds_lite_fuse/usg-cpu-x3_fuses.jpg
I hope this helps and have to say that I accept no responsability for any damage that may occur to your DS lite when following these tips.
Regards,
SOD69
Feb 07, 2010 | Nintendo DS Lite Console
Nintendo DS Lite - trying to recharge it, been plugged in most of the day. I have noticed that the red LED is flashing when the DS is connected to the mains, is this normal?
This is down to a number of possabilities:
1) Give the Battery terminals a bit of a clean up by either using an alcohol solution such as white spirit or scratch them clean with a small sharp knife or scalpel.
2) Try another battery - Rather than going ahead and buying a new one first see if you can borrow one off a friend or family member for a few seconds.
3) Try a different charger - Again, rather than going ahead and buying a new one first see if you can borrow one off a friend or family member for a few seconds.
4) Your fuse/s may have blown - You need to have fairly good soldering skills as the fuse you will be replacing is tiny (1.6mm x 0.8mm). You can buy the fuse you need from ebay (do a search for ds lite fuse). Take your ds lite apart and locate the "f1" fuse (here is a link to the pic of the fuse location: http://m3wiki.com/index.php/Image:Usgcpu01fuses.jpg ). Remove the blown fuse by de soldering it and replace it with the new fuse and solder it into place, once this is done you can put your ds back together and test if the charger now works... if it does work but the ds will not switch on you will have to also replace f2 (also shown on the picture).
If you want a more detailed explaination for the replacement of the fuses do a google search for "ds lite fuse replacement2 and you should get plenty of guides show up.
Some people say just to bridge this fuse if its blown but i'm strongly against this, the fuse is there for a reason and if you bypass it more serious damage can occur and that will be far more costly and dangerous.
Hope this helps and like to say I accept no responsibility for any damage that may occur whilst using my advice.
Regards,
SOD69
Feb 06, 2010 | Nintendo DS Lite Console
When on charge only lasts a few seconds and then cuts out
Your charging fuse has blown. If you have a warranty i'd suggest using it to get it repaired, if not you can either take it to a local repair shop or try replacing it yourself.
You need to have fairly good soldering skills as the fuse you will be replacing is tiny (1.6mm x 0.8mm). You can buy the fuse you need from ebay (do a search for ds lite fuse). Taky your ds lite apart and locate the "f1" fuse (here is a link to the pic of the fuse location: http://m3wiki.com/index.php/Image:Usgcpu01fuses.jpg ). Remove the blown fuse by de soldering it and replace it with the new fuse and solder it into place, once this is done you can put your ds back together and test if the charger now works... if it does but the ds will not switch on you will have to also replace f2 (also shown on the picture).
Regards,
SOD69
Feb 04, 2010 | Nintendo DS Lite Console
I turn My nintendo DS lite on and it shuts off instantly.
This sounds like the fuses on the logicboard have blown, you will have to take the back cover off to to have a look at the logicboard, the fuses are very small, you will need good soldering skills to replace them. here is a diagram of the logicboard and where the fuses are situated, they are marked F1 and F2:f898906.gif
Could you post back and tell me if the screens come on at all, if they do it might be your battery.
Feb 02, 2010 | Nintendo DS Lite
My ds wont charge the orange lite wot turn on and the charger slot on my ds is wied looking
my ds lite wont charge i get a flash of the orange light then nothing can you help me please
Jan 05, 2010 | Nintendo DS Lite Console
DS Lite will not power on
blowin F1 or F2 fuse or both inside your nds. can be fixed by runnung a bead of solder the blown fuse so it bridges the fuse (idealy you would replace fuse but its very tricky) first of all if you have a multi meter check the fuses before soldering them. anyway i advise not to use the homebrew card especially on your nds when you bridge the fuses as once the fuses have been bridged there is no saftey shut off to stop more sever damage. oh by the way just youtube F1 and F2 fuse location to find out where they are. oh and use a 15watt solder iron to be on safe side (less chance of overheating any components near fuses when soldering). its not that hard to do really (i did 2 of them with a gas solder iron due to me not having a 15watt iron) also replaced cracked screens. my next job to do is replace a L2 inductor on a friends nds (symptom for this fault is nds charges but will not power up, not even a blink of green light) for anyone who has this symptom its the L2 inductor thats broken away
Mar 28, 2009 | Nintendo DS Lite Console
What is wrong with my ds i put a homebrew card in and it kill everthing it wont turn on or no lights then on then try putting it in my daughter ds and the same kill every thing only when i plug it in with...
dont exactly no why your homebrew card is doing this but i read that R4 software developers are making there firmware capable of bricking nds consoles if the R4 card isnt genuine. so is your homebrew card a R4? anyway sounds to me like your home brew card is some how blowing the F1 or F2 fuse or both inside your nds. can be fixed by runnung a bead of solder the blown fuse so it bridges the fuse (idealy you would replace fuse but its very tricky) first of all if you have a multi meter check the fuses before soldering them. anyway i advise not to use the homebrew card especially on your nds when you bridge the fuses as once the fuses have been bridged there is no saftey shut off to stop more sever damage. oh by the way just youtube F1 and F2 fuse location to find out where they are. oh and use a 15watt solder iron to be on safe side (less chance of overheating any components near fuses when soldering). its not that hard to do really (i did 2 of them with a gas solder iron due to me not having a 15watt iron) also replaced cracked screens. my next job to do is replace a L2 inductor on a friends nds (syptom for this fault is nds charges but will not power up, not even a blink of green light) for anyone who has this symptom its the L2 inductor thats broken away
Mar 27, 2009 | Nintendo DS Lite Console
Ds lite green light flshing pulse sound from speaker
Check if "L2" is in place. Ususally drop from its position in the circuit board near the power switch, is a little black piece with solder in 2 sides. And the symptoms are almost the same as the blown F1 and F2 fuses.
If you opened your DS and didnt found it or wasnt aware and lost it you'll need a parts circuit board to take it from and solder it to your board, as theres no known part specification or schematics for the DS, at least as I know the only way is using a Henry meter to get the L2 value.
And you might have a water damaged board or broken top screen ribbon cable too as for the tick sound from the speaker is new for me.
Dec 19, 2008 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
281 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
