Question about Sharp AL 1631 Copier
Blotches of toner on edge of paper PLUS faint copies
First - After the copier has been turned on for a short period of time
blotches of toner appear on the full length of the sheet of paper. I have
changed the cartridge and this does not correct the problem.
Second - Regardless as to when I begin making copies, they are
becoming extremely faint even when I make the setting at the darkest
location.
I would like to have a technician come to my home in Dublin, Calif. OR take the copier to a repair shop if need be. Be advise who I should
contact.
My home phone is 925-828-5299
My cell phone is 925-200-5299
Thank you, Bonnie Powers
copier to
    Genius:
  • 1,011 Answers
Dear,
contact with the nearest shop at your place...
the outer source will not suitable for you...
take a look around
regards,
Posted on Nov 25, 2008
    Brigadier General:
  • 3,614 Answers
Contact one near on your PLACE
Prints blotches and marks down the left edge
Hi
That sounds like classic wear and tear issues. All those rollers and gears have very close tolerances and any variation out of the rang and the paper grabing and jamming starts. And that could be cause of the toner leaking. You must have a lot of miles on that ol girl and you got your moneys worth out of her. They dont make them like that anymore and I dont think you could find the parts even though that was back when they supplied parts. I asked an engineer once "couldn't they make that one gear out of metal like the rest of them?" He replied "well sure, but there wouldn't be any money in that..." You beat the system on that one. Time to start your research on a replacement I'm afraid.
Jun 18, 2017 | OKIPAGE 12i Led Printer
Blotches on left edge of paper
Try a new toner cartridge first, but worst case scenario you will need a new fuser.
Mar 01, 2011 | Brother MFC-9840CDW Laser Printer
Black lines on copies and on drum
There are a few things you can do to troubleshoot this problem.
  1. Be sure you are using new, clean paper
  2. Clean the copier's paper rollers, the marks may result from a dirty roller mechanism.
  3. Clean the copier bed's glass plate, smudges manifest themselves in the final copies.
  4. Clear any excess toner that has spilled in the toner cartridge chamber. Remove the cartridge, set it aside, then clean the compartment.
  5. Check for low toner levels. Low toner levels can actually contribute to unsightly lines and blotches on a photocopy
If all else fails, try turning down the darkness of the copies in the settings, this can occasionally lead to lines and marks.
Feb 28, 2011 | Brother MFC-8460N All-In-One Printer
Blue streaks and faint blue blotches on screen
The Optical Block / Light Engine is the problem. Very expensive repair / over $1000
Aug 08, 2009 | Sony KDF-42WE655 Television
Laserjet 4L printer has a streak on the left side of paper with ink blotches in the streak
look at the toner cartridge it is be coming from there,replace. check to see if there is something stuck on hte drum causing the blotches, clean w/alcohol or replace
Sep 17, 2008 | HP Office Equipment & Supplies
Blotches
you may need to replace the drum,
Aug 21, 2008 | Office Equipment & Supplies
Laser copy blotches, XD120f
Its your drum or fuser rollers
Jun 23, 2008 | Xerox WorkCentre XD120f Copier
Toner Dumping in machine
Do you have a shop vac with a hose on it? Turn the copier OFF and UNPLUG it from the WALL and use the vac to do all the lose toner & use a brush to get into the cracks and hard to reach areas. The blotches are most likely coming from the paper path, make sure you clean the whole paper path and run some blanks pages in the copier to clear up any left over... Good Luck
Jun 04, 2008 | Sharp AL-1642CS Copier
Dirty Edges
I'm sorry to tell you, this is likely a drum issue.
You probably need to have a certified engineer examine the machine.
Have you tried speaking with the local service center to see if they have experienced similar issues? It might be free information.
Erik.
May 13, 2008 | Xerox WorkCentre XD120F Laser Printer
Oki C5300 toner "leaking" on to surface
1 - take out all consumables
2 - use canned air to clean interior (do it outdoors)
3 - spray toner cartridges to remove stray toner (keep them connected to the drums, do not separate)
4 - make sure toner carts are properly installed and locked down
Oct 25, 2007 | OKI C5300n Led Printer
Sharp AL 1631 Copier Logo
24 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
