Question about Microsoft Windows XP Home Edition
All files turned to exe - Microsoft Windows XP Home Edition
  • 4,889 Answers
Your computer is infected with a worm called Gaobot. It turns every file on your HDD into exe. All the files will return to the normal state once you remove it.Here is the removal tool.
http://www.securitystronghold.com/download/gates/TrueSword4.exe
Posted on Nov 25, 2008
Disconnectivity within 1 minute I install a fresh
ftp://ftp.hp.com/pub/softpaq/sp47501-48000/sp47845.exe
A lot of Windows Update Issues are linked to this Intel Storage Technology Driver being out of date. Hope this helps!
Aug 16, 2013 | Computers & Internet
My all .exe files have turned into utorrent and are not opening they are only opening with u torrent...........
I think you accidentally used Default Programs or the Open With dialog to associate .exe file types with utorrent application, causing every program to open in utorrent.
To fix it, you will have make some changes in registry. I highly recommend you to backup the registry before applying the solution.
To fix it, just download this file, right click on it and select merge. This should fix it.
Mar 02, 2011 | Computers & Internet
Only my desktop picture is there when turned on nothing else
Hi.
Based on the information you have provided, it seems that the issue might be due to the "Explorer.exe" System file.
This is the file which loads the Windows Explorer.
The Windows Explorer in-turn loads all the required Startup Applications.
As the Applications are loaded and the icons are not displayed, you may run the "Explorer.exe" file manually.
By doing this, all the Startup Applications should be loaded.
Steps to run the "Explorer.exe" manually:
1) Press the "Alt, Ctrl and Delete" keys simultaneously. 2) Then, check if you are able to view the "Task Manager". 3) Click on the "File" tab and select the "New Task" option. 4) In the Run command window, type "explorer.exe" and press Enter. 5) This command should execute the "Explorer.exe" System File. 6) By executing this System file, all the Desktop icons should be restored.
Hope this helps.
Please feel free to contact for further information and assistance.
Jan 01, 2011 | MSI Wind U100-016US Laptop
How i can download for me free game please help me with this
I will help you to download free games for you here are a few games and their download links :
1.
Farm Frenzy :
http://files.myplaycity.com/files/farmfrenzy2_setup.exe
2.
Air Force Mission :
http://files.myplaycity.com/files/afmissions_setup.exe
3.
Around the world in 80 days :
http://files.myplaycity.com/files/aroundtheworld_setup.exe
4.
Amusive Chess :
http://files.myplaycity.com/files/achess_setup.exe
5.
Billiards :
http://files.myplaycity.com/files/billiardart_setup.exe
If you are looking for any particular game please reply back with the name.
Oct 30, 2010 | Computers & Internet
Worm.autoit virus(mgy.exe) make folder and all of my data files add extension .exe.exe.exe(example: desktop.ini.exe.exe.exe, mydata.xls.exe.exe, after cleaning and delete this all, my data and same file...
Boot from a Linux Live-CD and recover your files - Linux ignores the extensions so if your files are still there then they will be clearly visible.
Jul 05, 2010 | Computers & Internet
Net6work drivers
This computer has Ethernet 10/100 LAN Supplier, you can find the drivers here:
Also, those drivers are designed only for Windows XP
Aug 24, 2009 | Compaq Network adapter
Trojans wont go away. Hijackthis SCAN help
I am of the mind to do a complete reinstall of the operating system including flash the BIOS even if it is the same version. I worked many hours tracking down and thinking you found every part of the problem on to hit an .EXE and it all starts over again....I just clean out everything and start fresh.
If you tell us what make and model of computer along with the operating system it is we can direct you to the drivers for the reinstall. Some off those programs - for example AOL seem to be virus magnets. (if it is a dell it is really simple if you just put in your service code- it give you your particular driver of your computer.)
That is what I would do...Or you can keep hunting.
please leave rating,,,thank you
May 11, 2009 | Microsoft Windows XP Media Center Edition...
Hijack taskmanag and hijack regedit removing
to repair it you need to install autorun eater.
download here: http://www.softpedia.com/get/Security/Secure-cleaning/Autorun-Eater.shtml
install and it will scan.
also suggested to install avira, bitdefender or mcafee(trial also work).
after install.
restart: press f8 you will enter safe mood. in the safe mood you will see a icon on your taskbar name by mcdonald(the autorun eater software. right click and selct repair task manager, right click again selecr repair regedit and do the same thing select repair folder option.
after that wait untill about 30 minutes(autorun eater to finish scan)
to repair other like no desktop icon download the repair utilities here:
http://www.kellys-korner-xp.com/taskbarplus!.htm
Jan 27, 2009 | Dell Latitude D600 Notebook
Zone Alarm will not start up when I turn on my computer?
You can ADD the "Zone alarm" executable to your windows startup.
This can be done in 1 simple way.
1. Locate the "Zonealarm.exe" in your "Program files" folder. Usually your Program Files folder will be here "C:\Program Files". Just run a search for "Zonealarm.exe" inside this folder.
2. After locating the "Zonealarm.exe" file, right-click on that file. And select "Create Shortcut".
3. After that you'll find a "Zonealarm.exe" Shortcut file or icon inside the same folder.
4. Just COPY or CUT the shortcut file.
5. Now Right click on the "START" button.
6. Select "Open all users".
7. This will open a windows explorer window. Locate "Programs" folder and Enter it.
8. Inside you should locate "Startup" folder and enter it.
9. Once u ar inside the "Startup" folder, paste the already copied "Zonealarm.exe" shortcut file.
10. That's it. Now try re-starting the system.
Thanks
Dec 18, 2008 | Microsoft Windows XP Home Edition
",.exe" (comma.exe) causing a problem
Its your OS affected by virus..
Mar 04, 2008 | Computers & Internet
Microsoft Windows XP Home Edition Logo
43 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
