Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Sears 19 hp twin 42 inch tractor, won't start if hot
I have a 10 year old sears 42 inch 19 hp twin Briggs Craftsman sears tractor. It will start fine if cold and run for hours, then I shut it off for a few minutes and it will not start again until cold, maybe one hour later. I rebuilt the carb, fuel pump, changed coil and 2 of the 3 interlock switches, ( clutch and blade switches). i believe I am not getting spark. Why does it work cold and then for hours then it won't start. It turns the engine over, fine just won't start running. ??????
  • 1 more comment
  • bigmike396 Nov 30, 2008
    I don't believe I changed the plugs yet. I did also change the Ignition key switch. When this problem occurs, I believe I am getting very little to no spark at the plugs on either plug. Again once the engine and tracotr sit for about 45 minutes it will start fine.
  • bigmike396 Dec 09, 2008
    I did actually change the Plugs when I did all the other items listed above, any ideas would be helpful.
  • Antonio Boscia
    Antonio Boscia May 11, 2010
    have you tried changing out the spark plugs?
  • 3 Answers
Hi
Two things come to mind. First it could be not getting enough fuel when hot due to carb adjustment being too lean. That could be that the float level in the carb is set too low or the low speed jet is set too lean. When cold the choke circuit in the carb supplies the extra fuel required.
Second in some enjines that have low compression they start cold but when hot the compression drops below 60 psi and makes starting very difficult until engine cools down.
I suspect a fuel problem.
Posted on Dec 31, 2008
Tip
2008 Craftsman lawn tractor
Tip for 2008 Craftsman lawn tractor that runs for about 30 minutes then starts to cut out and dies, and will not restart. These tractors have a defective gas cap that will not vent. Simply remove gas cap and reinstall loosely. The best fix is replace gas cap. If your tractor is less than two years old Sears will replace it free. preview_graphic.jpg
on Jul 30, 2010 | Craftsman 42" Briggs Stratton 20 hp Gas...
Where can I find the model number on my Sears riding lawn mower? It is about 6 or so years old.
Sears puts the model numbers under the seat on most machines since 1990. They are in the format
xxx.xxxxxx
example 538.678567
Good luck
Mar 28, 2011 | Craftsman 42" Briggs Stratton 20 hp Gas...
I have A craftsman riding mower 18 1/2 hp 42 inch deck have changed spark plugfuel filter took off tank and blowed it out but the mower still cute off after about 10 minutes like it has no gas what else...
Do you have a Briggs or kohler engine.I am having the same problem.I have changed the fuel filte, fuel pump, and cleaned the carb.Sears has been no help at all.The reason I ask about the engine you have is that people are having the same problem no matter what engine they have.So therefore it probably is not the engine so it is something else on the mower.My mower runs fine for about 10-15 then starts to stutter and backfire.I am continuing to pursue this problem and I will post back here if I come up with anything.
Jul 06, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
10 A Fuse blows each time I shut off engine. Short somewhere? Suggestions? Craftsman 19 hp Briggs & Stratton 42 inch deck. Probably 10 years old. Thanks! Mike
Yes, probably a short, and I think you should look at the ignition switch as the first suspect. It has two switches inside - one to send battery power to the various components, and a separate one to ground out the magneto when the mower is turned off. Could be a short between the two parts of the switch. Test it if you have the tools, otherwise try replacing it. Good luck! If this is helpful, please take a moment to rate my solutions, thanks!
Jun 10, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Mower cutting off when the engine heats up (Sears Craftsman)
sounds like you have magneto getting hot,,, next time it do it,, let it cool off for about 2 hours see if crank and run again till shut off,, if if does replace magneto,, hope this help,, good luck
Aug 11, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman snow blade install instructions
Go to sears.com and click on the PartsDirect link at the top. Enter the model number of the blade and you will see a parts diagram of blade. Hope this helps.
Dec 14, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Need help to reinstall the under mower 42'' unit that out
I have that manual. If you want, give me a postal address and I'll mail you a copy. Mac
Nov 13, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
1,244 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
