Question about Aiwa XH-A1000 Shelf System
Aiwa XH-A1000 - Compatible Speakers
Hi I was wondering if anyone knew of any good, floor standing speakers that are compatible with the XH-A1000? The original speakers have a built-in subwoofer which has a seperate feed from the main unit. Does anyone know of any hi-end speakers that have this setup? Many thanks Steve
2 Suggested Answers
  • 752 Answers
SOURCE: No sound from stereo
If you can hear a hiss then the spkrs and amp are OK. It sounds like you're not on whichever source you're wanting to hear or it is on mute. Make sure ther is no function enabled that turns the sound off or over-rides it (like a tape monitor or AUX in...).
Posted on Sep 22, 2007
  • 28 Answers
SOURCE: Aiwa Stereo XR EM 50 the cassette deck does not
Posted on Mar 01, 2011
0 characters
1 Points
AIWA XH-a1000. Won't turn on. Any time I try to turn it on I hear a click in the back and that is it. Any solution to my problem ?
This is the unit going into Protect mode. This is usually common when the audio chip goes bad or a power transistor. Need a schmatic to check voltages and pcb lines.
May 23, 2014 | Audio Shelf Systems
Need a new stereo to work with the old speakers
Any 5.1 surround system will work with this. It is better to be high in impedence than too low.
Feb 13, 2014 | Sony MHC-M300AV CD Shelf System
Aiwa cxna115 - trying to jack-in Belkin stereo cable for Apple IPhone so I can play through stereo speakers. Should I be jacking into video aux on aiwa or the jack next to it? Neither seems like a good...
You can play audio equipment like turntable, MD player, mobil phone ( headphone output). You must connect the equipment to the Video/AUX jack, Press Video/AUX then play the connected equipment.
Jan 01, 2013 | Audio Shelf Systems
I want to buy aiwa XH-A1000 but dont know from where i can buy this system and how much i have to pay for that please tell me thanks
me gustaria comprar partes del cerebro del aiwa xh a1000 para cualquiera que tenga inventario de partes me puede avisar necesito lector de discos o si se puede la targeta completa por que el audio tambien no funciona.
espero me puedan ayudar saludos...
May 26, 2010 | Aiwa XH-A1000 Shelf System
Hi i have a set of 203 JPW floor standing hifi
remove grill and approximately 6 to 8 screws hold speaker to box. Follow appropiate wiring in removal as replacement. Check crossover while you have it appart
Mar 08, 2010 | Sony MHC-RV888D Shelf System
Aiwa cx na555u
Dear shelnaaqua,
Please connect the headphone to your system and check the sound quality,If it sound good then the connection of the speakers are not ok. This system has HI & low frequency output. Connect woofer to LOW frequency output and tweaters to HI frequency.
please take trouble to vote for me if this solve your problems
Jun 07, 2008 | Aiwa NSX-A505 CD Shelf System
Just a question on specs for Aiwa NSX-5200 system
Hello I have had a look on the internet and found this for you it should let you download the user manual for free, good luck you should find out your specs - 49k -
Feb 18, 2008 | Audio Shelf Systems
Aiwa XH-A1000 Shelf System Logo
48 people viewed this question
Top Aiwa Audio Shelf Systems Experts
Are you an Aiwa Audio Shelf System Expert? Answer questions, earn points and help others
