Question about Sony Playstation 3 (PS3) Console
Display skips, blinks and pauses
I have an HDTV with 2 HDMI ports.  I had my ps3 connected through the first HDMI port and it would skip, the screen would go blank in the middle of the game.  Also, during any sort of change in phases (i.e. ejecting a disc manually or starting/stopping a program in game) the screen will go blank and be accompanied by a loud popping of my speakers, like when you pull your finger across the needle of a record player.  I can't recreate any of these problems and they aren't regular.  I can't pin down what the problem is.  I changed to the second hdmi input and the problem stopped for a while, but it seems to be starting up again.  Is it a bad signal from the PS3?  Is it a bad HDMI cable?  Is it the HDMI ports?  Please help!
  • horne_andrew Nov 26, 2008
    Be more specific when you say "wrong".
  • horne_andrew Jan 04, 2009
    My HDMI cable is not loose.  I don't know what you mean by my display settings are wrong.  This seems to be happening more and more at the start of games or movies when the PS3 is deciding which viewing mode (720p or 1080i) is best.  My ps3 is set to automatically set the display and this happens even when there is no change in display resolution (from 1080i ps3 display to playing a movie in 1080i).  The display settings on my TV aren't wrong, they are mandated by the input coming through the HDMI.  Please help.
  • 35 Answers
The Hdmi cable is either loose or your ps3 dispay settings are wrong
Posted on Nov 25, 2008
How do i get my hdmi to work for my ps3 system
Note: How to reset video output settings
If you are attempting to change to an HDMI cable from a different video cable or if the video output settings do not match those required for the display in use, the screen may stay black. If the screen stays black for more than 30 seconds, you may need to reset the video output settings of the PS3.
To reset video output settings:
  1. Turn the PS3 system off by holding the Power button on the front of the console till you see the power light turn red.
  2. Then hold the power button on the front of the console for at least five seconds until you hear a second beep to turn the system on again. The video output settings will automatically be reset to the standard resolution.
[TOP]
HDMI Cable Installation
Interactive Video Tutorial
Click below for an interactive video walkthrough on connecting your PS3 to your television or display device (including HDMI).
alt="Click to play tutorial">
[TOP]
Minimum Requirements
  • PlayStation®3 computer entertainment system
  • SIXAXISTM wireless controller (and USB cable)
  • AC power cord
  • HDMI cable1 (sold separately)
  • TV or display monitor with HDMI port and capable of displaying picture in HD resolution
  • Updated system software installed on your PS3
    Visit PS3 System Software Update to download and install the most recent version.
  • TV "Input" or "Video" channel for the HDMI port
    You need to know the TV "Input" or "Video" channel for the HDMI port on your TV. For instance, if your TV has multiple "Input" or "Video" channels, (i.e., "Input 1", "Input 2", "Input 3", etc.), you will need to toggle through each "Input" channel on your TV until you find the correct channel that displays the HDMI picture. This is important to remember, especially if you do not see the HDMI picture after you connect the cable and configure the PS3 settings. Please refer to the TV instruction manual for more information.
[TOP]
Instructions
  1. Before you begin installation:
    • Turn OFF the PS3TM system using the [MAIN POWER] switch (in the back)
    • Unplug the AC power cord from the electrical outlet
    • Turn OFF and unplug the TV
  2. Connect one end of the HDMI cable into the [HDMI OUT] port on the back of the PS3 system. Connect the other end of the HDMI cable into the [HDMI Input] port of the TV or display monitor.
    alt="line drawing of HDMI connection">
  3. Plug in the AC power cord by connecting one end of the AC power cord into the [AC IN] port on the back of the PS3 system and the other end into an electrical outlet.
    alt="line drawing of AC power cord">
  4. Press the [MAIN POWER] switch on the rear of the system. A red light should appear on the front of the system indicating power is available.
  5. Turn on the PS3 by pressing the touch-sensitive [On/Off button] on the system front. The red light will turn green, indicating the PS3 is now turned on.
    Note: The blue light will also appear on the front of the system if you have a disc inserted.
  6. Plug in the TV and turn the power on. The PS3 should detect the HDMI display device automatically. When prompted, "Do you want to output video and audio using HDMI?", select YES and press the alt="X button icon">button. (You may need to press the PS button on the center of the SIXAXISTMcontroller to enable the controller first).
  7. The next screen will ask, "Do you want to automatically switch to the optimal setting?" Select YES and press the alt="X button icon">button.
  8. On the next screen, the PS3 will display the maximum resolution capable on the display (i.e., 1080p). The screen will display, "Do you accept the setting?" You will have 30 seconds to confirm your answer.2 Select YES and press the alt="X button icon">button to save your settings. You have now completed the HDMI installation.
[TOP]
Feb 15, 2015 | Video Game Consoles & Games
My coby lcd tv won't work for my ps3 what wires would I need to make it work
You will need an HDMI cable. Please follow the below instructions.
Instructions
  2. Connect one end of the HDMI cable into the [HDMI OUT] port on the back of the PS3 system. Connect the other end of the HDMI cable into the [HDMI Input] port of the TV or display monitor. ps3_8_hdmiconnecttv.gif
  3. Plug in the AC power cord by connecting one end of the AC power cord into the [AC IN] port on the back of the PS3 system and the other end into an electrical outlet. ps3_11_connectacpower.gif
  6. Plug in the TV and turn the power on. The PS3 should detect the HDMI display device automatically. When prompted, "Do you want to output video and audio using HDMI?", select YES and press the icn_btnx_color.gifbutton. (You may need to press the PS button on the center of the SIXAXISTM controller to enable the controller first).
  7. The next screen will ask, "Do you want to automatically switch to the optimal setting?" Select YES and press the icn_btnx_color.gifbutton.
  8. On the next screen, the PS3 will display the maximum resolution capable on the display (i.e., 1080p). The screen will display, "Do you accept the setting?" You will have 30 seconds to confirm your answer.2 Select YES and press the icn_btnx_color.gifbutton to save your settings. You have now completed the HDMI installation.
Dec 01, 2014 | Televison & Video
How do I hook up Xbox 360 to the HDTV
Step 1:
Connect the audio/video input of the component cable into the "A/V" port located on the back of the xbox 360
Step 2:
Match the red, blue and green cables on the other end of the component cable to the corresponding component ports on your HDTV. If your HDTV has more than one set of component inputs, make note of which one you use.
Step 3:
Slide the switch on the component cable to "HDTV."
Step 4:
Turn on your HDTV. Set the video mode to the component port that will be used. HDTVs with multiple component ports will usually be labeled "Component 1," "Component 2" and so on
Step 5:
Turn on the Xbox 360. Go to "My Xbox." Select "System Settings" then "Console Settings" then "Display" and then "HDTV Settings." Choose the display setting (720p, 1080i and 1080p) that is best compatible with your HDTV. If you're not sure, try them all until you find the one that looks best.
Step 6:
Disconnect any previously connected A/V or component cables.
Step 7:
Connect the HDMI AV cable connector to the "HDMI AV" port on the Xbox 360.
Step 8:
Connect the other end to an available HDMI port on your HDTV. If your HDTV has more than one HDMI input, make note of which one you use.
Step 9:
Turn on your HDTV. Set the video mode to the HDMI port that will be used. HDTVs with multiple component ports will usually label them "HDMI 1," "HDMI 2" and so on.
Step 10:
Turn on the Xbox 360. Go to "My Xbox." Select "System Settings" then "Console Settings" then "Display" and then "HDTV Settings." Pick the display setting (720p, 1080i and 1080p) that looks best on your HDTV.
Dec 26, 2012 | Video Game Consoles & Games
Show error
E indicates an Error condition.
1.Without turning off the product, disconnect the USB cable from the rear of the product.
NOTE:The USB cable connects to the port on the rear of the product. The port is labeled with the USB icon ( ). If your printer has a network or wireless connection, ignore this step.
Figure 1: Example USB connection (your product might not look exactly the same as this example)
2.Remove the cartridges from the product.
3.Wait until a message to insert the cartridges displays. If you do not see a message within a few minutes, skip to the next step.
NOTE:If your printer does not have a display, wait until the cartridge lights blink. If the cartridge lights do not blink within a few minutes, skip to the next step.
4.Disconnect the power cord from the back of the product.
5.Wait 60 seconds.
6.Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
7.Reinsert the cartridges, and then close any open doors on the product.
8.If you receive a prompt to print a calibration page, do so.
9.If you disconnected the USB cable, reconnect it to the rear of the product.
10. Try printing again.
5.Wait 60 seconds.
If that doesn't work you can log on to HP.com/Support and Drivers.
Find your device and search the error codes listed.
You can also download a real good Utility, HP Print and Scan Doctor.
Apr 27, 2012 | HP DeskJet F380 All-In-One Printer
Hi, I have a samsung LE40B750. It is connected
Ur tv some how causes HDMI 1 and 2 port hubs link together so changes back and fourth 1 or 2 HDMI hubs will not a difference.Ur tv have 4 HDMI hub ports wright?Tries not to used HDMI hub ports as like HDMI ports like 1,2,3,4 to as in sequences.Tries used like 1 and 4,2 and 4,3 and 1 as skips sequences might work for ur tv.Tries to hook up the PS3 system as the old format hook up same hook as PS2 format like used the PS station old RCA AV cable hook up.Then that should not causes conflict at all because now tv have two difference kind of format hook up.
Sep 05, 2011 | Samsung Televison & Video
How to connect blu ray player hdmi to my laptop
1) Look at your laptop computer to see if you have an HDMI cable port. This port is roughly half an inch wide and provides both the HD audio and video signal. If you don't, you are going to use a DVI port on the laptop. This is the same port you use to connect monitors to your computer.
2) Plug the DVI-to-HDMI adapter into the DVI port on the laptop with the Blu-ray player. If you have an HDMI port on your laptop, you can skip this step.
3) Connect an HDMI cable to the HDMI end of the adapter. If you have an HDMI port, plug the cable directly into the HDMI port.
4) Plug the other end of the HDMI cable into the HDMI port on the HD television. Power on your television, press the "Input" button and select "HDMI." You can now see the contents from your Blu-ray player on the TV.
Thanks for rating
Good luck
Feb 11, 2011 | Televison & Video
I have sharp 37 inch LC-37D44U MY PS3 is not working with it it green lights keep blinking power light and OPC. BUT THE HDMi ports work beacause i checked it with other devices. so i dont know why its not...
Does this happen when you input certain signals to the HDMI2_bing.gif ports? Or all signals (e.g. 1080i, 720p, 1080p, etc.)? And which ports are affected - side HDMI, rear component, etc.?
I had this issue and Sharp sent out a local repair tech to install a new main circuit board, then two weeks later, a new side board (where the side inputs connect into the system)... their first visit allowed my TV to accept signals in the rear HDMI ports (all signals worked well), but then I couldn't get a signal processed via the side HDMI port. At first, just 1080p would not display (caused the OPC/power green light blinking), and after a few days, any signal hitting that port would cause the error lights to come on. But as I said, eventually, a new side board resolved that issue.
Sep 11, 2009 | Sharp Aquos LC-45GD4U 45 in. LCD HDTV
HDMI to DVI Picture problem
I found a user Manuel online http://www2.panasonic.com/consumer-electronics/support/Televisions/CRT-Projection-TVs/model.PT-47WXC43
went to page 24
found that a setting that would skip this port when going through the TV/Video button menu.
To solve follow these steps - Menu -> Channels -> Other Adj. -> Input Lable -> digital - IN -> If set to skip change to what ever you want.
Dec 12, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Getting the TV to play through the HDMI cord
First, you need to set the playstation to display on HDMI out.
Plug the HDMI cable into the TV and into the PS3.
Use the PS3 to setup the video settings to 720p which every HDTV can display. Then switch the TV-out to HDMI and it should display.
Also consult your televisions manual to set it up for HDMI input as well. Make sure that the TV allows sound through the HDMI port as some older HDTV's didn't have that ability.
If you still have a problem; please let me know! I hope it helps you out
Aug 08, 2008 | Samsung LN-T4061F 40 in. LCD HDTV
Sony Playstation 3 (PS3) Console Logo
127 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
