Question about Intuit Quicken® Rental Property Manager 2.0 Full Version for PC
How do i back date payments using Quicken property manager
I use Quicken property manager.
How do i back date payments from students?
I am having trouble making a payment on line
Trouble Paying? - FedLoan Servicing
https://myfedloan.org/make-a-payment/trouble-paying.shtml
If you can't afford your student loan payments, we offer options like changing ... IDR plans are a great long-term solution that can make managing your loans a ... Review your options and apply for a new plan online through Account Access.
Having trouble making an online payment? ' Buckeye Link ...
https://buckeyelink.osu.edu/having-trouble-making...
Ohio State UniversityIf you are having problems accessing items in your Student Center and are using a new or upgraded version of Internet Explorer, try turning on the Compatibility ...
Trouble making mortgage payments - Citibank
https://online.citi.com/US/JRS/.../template.do?...trouble_making_paymen...
Citi Official Site: Learn about your options if you are having trouble making mortgagepayments.
Jan 05, 2016 | Computers & Internet
How to re-reconcile an account after deleting a transaction from a previously reconciled account in Quicken 2002
You can't delete a transaction is your program .
Add the transaction back in and then add an opposite transaction to reverse it .
EG
Pay fred blogs for whatever from account XYZ = Debit Fred Blogs in Payment transaction
receive credit from fred blogs to account XYZ = Credit from Fred Blogs in Received Payments to account XYZ - comments paid in error credited back
This accounting practice is done by many companies when a mistake is made to reserve the mistake .
Jul 23, 2017 | Intuit Quicken 2002 Deluxe (78588)
How do you change VAT rate on Quicken 2002
You cannot do this on the normal account register, as you might have done in earlier versions of Quicken. You have to use two special registers, by creating a BUSINESS BILLS and a CUSTOMER INVOICES register. To do this tap the CREATE NEW ACCOUNT button, in the MY FINANCES screen, and select these registers from the dialogue box. When you receive a payment from a customer, open the CUSTOMER INVOICES register. Then... 1. Tap the TYPE box, and choose INVOICE from the drop down list. This will enter INVC into the box. 2. Look at the button under the BALANCE column. Instead of the usual SPLIT button, this is now labelled FORM. Click on this, and a Customer Invoice Form will appear. Fill in the details from the invoice you have received. Under AMOUNT enter the amount received, less VAT. In the V column, enter the symbol for the appropriate VAT RATE, and Quicken will calculate and enter the VAT amount. 3. When you have completed all the required boxes on the form, click the SAVE AND DONE button, and The form will close. 4. You will see that Quicken has entered the details in the correct Registers. I 5. When you produce your VAT REPORT your item will appear with its details in the correct places. The process for entering a payment is similar, but you will then be using the Business Bills register. Problem solved ! John Cunliffe
Feb 13, 2011 | Intuit Quicken 2002 Home and Business Full...
Have Quicken 2008 and HP J6400 printer. Can print reports but can not print checks
Check that the problem is not caused by mismatched paper size, in that case you may need to correct printer settings and adjust also settings on Quicken.
Quicken 2008 is also known for having several bugs that affect printing, if you are considering an update to 2009, that should fix the problem.
You can also check if a patch to fix the problem is available contacting quicken online, check the links below:
Quicken® Personal Finance Software: Chat
Get Help with Quicken | Quicken Help and Support Options
Regards.
Jul 27, 2009 | Computers & Internet
With the exception of one trans - none will memorize
May I suggest you remove this particular instance, save your work, shut down Quicken. Restart the program and put the transaction in again. Sometimes I have success toing it this way.
I hope it works for you.
a
Jan 22, 2009 | Intuit Quicken Deluxe 99 for Windows...
Quicken on line want to quit program
I tried Quicken on line some time ago and also quit and went back to regular Quicken. The only way I was able to quit and stop billing was to contact Intuit by phone and get a confirming e-mail that service was stopped.
If that does not work contact your credit card company by letter and have them block payments until the matter is resolved.
Nov 19, 2008 | Western Digital 500GB My Book World...
Backing up a Quicken file
This is probably due to an update. Quicken and quickbooks perform updates in the back ground on a frequent basis. The easiest way to take care of this problem would be to create a directory called backup on the flash drive and instruct quicken to backup to it.
Provided you're using windows XP, click on My Computer, select the icon for your flash drive, F: Right click and create a new folder and name it backup. In quicken when you go to backup, just change where it says F:\ to F:\backup
this should fix your problem. Please email back if you have any problems getting it to work.
Dave
Feb 28, 2008 | Computers & Internet
Quicken99 incorrect reconcile date
Boy oh boy ... I thought I was behind! Is this a current question or a very old one - I cannot tell.
Normally quicken will use the last date you recondiled as the start date.
I guess you dont use the download method of reconciling? If you have WWW access on the computer where your Quiocken resides, your financial institution probably offeres this kind of service. My bank does not charge to have Quicken get the info and reconcile. And I can be as up todate as "yesterday" with this method.
I hope I have answered your question
Jan 31, 2008 | Intuit Quicken Deluxe 99 for Windows...
How to move entries that are place in wrong chronological order in payments section
Most mature programs would do that as well as check to make sure the date format is consistent. Since I don't know what program you are using that's all the information I can give you.
Jan 20, 2008 | Computers & Internet
Open Questions:
Intuit Quicken® Rental Property Manager 2.0 Full Version for PC Logo
43 people viewed this question
Top Intuit Computers & Internet Experts
Alun Cox
Chris Larocque
Mike
Are you an Intuit Computer and Internet Expert? Answer questions, earn points and help others
