Question about Maytag Atlantis MAV6000 Top Load Washer
Admiral capacity plus too loud during spin cycle. This is not a normal sound EXTREMELY LOUD!! What could cause this??
  • 868 Answers
If its older then 10 years then its probably the tub bearing and seal.If you can do this tilt the machine back look under the bottom and turn the belt by hand and if you can isolate if the noise is not the water pump bearing. rate this !!
Posted on Dec 02, 2008
I have a Admiral Capacity Plus washer LNC6267B71. Washer makes loud grinding noise when agitating & spin cycles. Machine does fill, drain, agitate & spin. Only noise is concern.
Hello. Your symptom describes damaged bearings and/or a damaged transmission. This is a MAJOR, INVOLVED repair requiring special tools to prevent serious injury during dis-assembly and re-assembly. I strongly suggest acquiring outside service to repair this machine if cost effective. There are many parts that have to be removed and then replaced--if you've never done this--don't attempt it. There is a brake spring with 200lbs of torque on it that has to have a special tool mounted to relieve the tension during removal and then re-compress it during replacement for example. Sorry to be so dramatic but I don't want you to get hurt needlessly. I hope I helped you!
Nov 05, 2015 | Admiral Washing Machines
Washing machine making loud roaring sound during spin cycle
Very likely the main bearing and drum shaft-inner tub will need replace. Not worth repairing, easily can cost more than the washer. Buy a new whirlpool front load duet, super capacity or the top load whirlpool with and agitator. Good Luck, Appliance Specialists
Feb 16, 2010 | Washing Machines
Very loud rumbling noise during spinning
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.This will solve your problem.
Sep 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My Capacity Plus Admiral Washer will spin and agitate, but it makes a loud grinding noise.
Well, Sounds to me like the Bearings are going out, but it could make that noise a good while, before it goes completely out.. Replacement would possably be more cost effective, Kinda hard to beleive !!!!!!
Oct 26, 2008 | Washing Machines
My wash spins SO loudly
hiya
sounds like your drum bearings are in need of replacing.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
Aug 19, 2008 | Washing Machines
Very loud on spin cycle
yes ..bearing on upper side of gearcase has gone bad probably from a water leak from tub seal
Jul 20, 2008 | Amana 3.2 cu. ft. Top-Load Washer
Clanking, sparking sound coming from washer
Need to know a little more info. Need to know if this noise starts when you first turn it on (during the fill up cycle), once the actual washer starts (wash cycle) or when it goes into spin cycle.
Jun 11, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Loud noise on spin cycle
How did that answer get an 83% rating? It is absolutely useless. My washer has the exact same problem as described above.During the spin cycle it sounds like a jet engine. It kinda sounds like the belt hitting the drive wheel but may be bearings in the motor.
May 03, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
249 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
