Question about JVC GR-D250 Mini DV Digital Camcorder
PC can not regconize Camcorder
I used the cable to connect my camcorder to PC. The cable has the DV connector to plug in the camcorder, the another as USB connector to connect to PC. My PC can not recogize the camcorder. What should I do? I will install something or I have choose the wrong cable. Please tell me the detail solution to fix this issue. Thanks.
  • 3 Answers
Hi, Beside the dv cable, your PC must have a firewire card. USB connection is no good to transfer video to your PC. I have no problem with windows XP. See http://www.videohelp.com/. good luck
Posted on Mar 17, 2007
I have a GR-D295U camcorder. Can I get a cable that connects the mini USB connector on the camcorder to a regular USB connector on the computer? Thanks, Rene
The USB connection for this camcorder only allows still image transfers. To transfer video you will need a DV cable (JVC VC-VDV206U or VC-VDV204U depending on the type of DV connector on the PC - 4 or 6 pins)
Jul 13, 2011 | Video Cameras
Nothing pops out
You may have the cable that comes with the
camcorder has built in filters
and also
When connecting the camcorder to a PC
using a DV cable, make sure to
Connect the DV cable first to the PC, and then
to the camcorder.
Connect the DV cable (plugs) correctly
according to the shape of the DV connector.
p37 of manual
link to manual here:
http://www.retrevo.com/s/JVC-GR-D250US-Camcorders-review-manual/id/209ag624/t/1-2/
Dec 02, 2007 | JVC GR-D250 Mini DV Digital Camcorder
How do i load tape to computer?
The simplest solution is to use a FireWire cable connected between camera DV output and FireWire PC Input.
If your PC or laptop do not has a FireWire Input, you can use an USB capture device like EasyCap connected to your PC by USB interface and to your Camcorder by RCA connector or S-Video connector.
Nov 25, 2010 | Sharp Viewcam VL-Z3H Mini DV Digital...
How do i get video from my vx1000 to my compuiter
You will use the DV (firewire) jack on your camcorder. It is located on the back of the camcorder under the door for the battery. Depending on what type of connector your computer has, you will need to get a firewire cable (also known as IEEE-1394a cable). The connector on your camcorder is a 4-pin connector. You will either have that same looking connector on your computer (some laptops now have the 4-pin connector) or a 6-pin connector (D shaped). 884068d.jpg This pic is of a 4-pin to 6-pin cable. These are available at many electronic stores and online. To be safe, have your camcorder powered off when connecting to the computer. Once you have connected the cables, turn your camcorder on and insert the tape that you would like to transfer. Your computer should recognize it and install the appropriate driver. Most computers have some sort of free video editing program (like Windows Movie Maker). Depending on the software, you may have the option to import the entire video tape or only parts.
Hope this has helped you.
www.austintelstarservices.com
Oct 05, 2010 | Sony Handycam DCR-VX1000 Mini DV Digital...
How do i download a video into my computer from the Sony Handycam DCR-HC21 Mini DV Digital Camcorder
There are two way to upload your picture's or video's to your pc:
  1. You can upload video to the use of your camcorder connector. Connect your USB cable to your camcorder and plug it to your computer. You need to turn on your camcorder so that it will be recognized by the computer.
  2. You can upload also your video's with the use of memory card reader. Remove your memory card from your camcorder and insert it to the card reader. Plug the card reader to the computer. The computer will recognized the card. Now you can upload your photo's or video's.
May 25, 2010 | Sony Handycam DCR-HC21 Mini DV Digital...
After connecting camcorder to PC thro S Video cable , the sound card of camcorder is not working
Have you connected the 3.5mm stereo jack plug into the audio in on the PC the S Video cable only sends the component video signals {C Color (Chrominance) and Y Intensity (Luminance)} the audio is a separate connector
Jan 08, 2010 | JVC GR-D350 Mini DV Digital Camcorder
Connect to Pc
You will need a firewire cable.
It has 2 different connectors on it. On small 6 pin plug for the camera end, and a larger (almost like a USB but with tapers at one end and slightly thicker) plug at the other.
Your computer will also need to have firewire either built onboard, or via an addin card that you can purchase at any PC shop.
The connector for the camera side plugs into the side of the camera near the battery.
Hope that helps =)
Apr 13, 2008 | Panasonic NV-DS60 Mini DV Digital...
My Panasonic Palmcorder PV-GS19 does not connect to my pc
if you want to transfer the video to the computer, I use a firewire cable that I had to buy separately, make sure ur computer has a firewire port. The usb cable is only good for downloading pictures.
Dec 17, 2007 | Panasonic Palmcorder PV-GS9 Mini DV...
Canon ZR800 MimiDV Camcorder
You cannot connect a DV cable to a USB port. These are two incompatible standards. DV is also called Firewire, iLink or IEEE1394. You PC must have that kind of port for you to transfer your video from the ZR800 and you will need a DV (iLink/Firewire) cable. You cannot use USB cable they will not work. Check www.MyCableMart.com if you want an example. Most new PC come with 1 or 2 iLink/Firewire/1394 port. If you PC does not have an iLink/Firewire/1394 port then you will need to install a iLink/Firewire/1394 card (see http://www.usbfirewire.com/Parts/rr-fw-byt.html) for more information.
Aug 13, 2007 | Canon ZR800 Mini DV Digital Camcorder
Connection
Only DV connections (IEEE1394 connections) are possible when connecting your camcorder to a computer. DV connections (IEEE1394 connections) Your camcorder can be connected to a computer equipped with an IEEE1394 (DV) terminal or OHCI-compliant IEEE1394 capture board. You can transfer taped recordings (digital video signals) to the computer by connecting the camcorder to the computer. Use the editing software supplied with your computer/capture board to transfer video recordings from tape to the computer. If you are using a computer running Windows XP, you can also record the video simultaneously on your computer's hard disk and on the tape using DV-PC Recorder Software. You can download the DV-PC Recorder Software from Canon's DV-PC Recorder Web site. Making the connection Connect the camcorder to the computer as shown in the figure below. The computer's IEEE1394 (DV) terminal is either a 4-pin or a 6-pin type, depending on the computer used. Use either the CV-150F (4-pin - 4-pin) or the CV-250F (4-pin - 6-pin) DV cable (sold separately), whichever fits your computer's terminal. Precautions (1) There are cases where the connection may not work correctly, depending on your system specifications/settings. (2) If the computer freezes while you have the camcorder connected to it , disconnect and reconnect the DV cable. If the problem persists, take the following actions. (2-1) Disconnect the DV cable from the camcorder and the computer, and then turn off the camcorder and the computer. (2-2) Turn the camcorder and the computer back on and then reconnect them with the DV cable. (3) Your camera cannot be used with DV NETWORK SOFTWARE (DV Messenger).
Sep 04, 2005 | Canon XL2 Mini DV Digital Camcorder
Open Questions:
Audio drop out and/or static sound Thanks to anyone who has taken a look at my issue with audio cutting out. JVC has always been a brand I have confidence in, and I believe I picked this camera up when those recording to an internal hard drive were out of my range. Last summer, I received a fantastic deal on some JVC Evarios, so GR-D250 duo would be used only as back-up, BUT, I have a ton of old Mini DV tapes -- never recorded over anything. I would find the heads needing cleaning solution highly unlikely. The first 250 recorded the bulk of those 150 or Mini DV's and worked like a champ. Because of legal depositions for lawyers and like, who may not want for me to call time-out in a deposition to switch tapes and the fact that eventually my first was going to give out, having a back-up and eventually multiple seemed like the thing to do. Having a couple of friends film some sports events I could my mix radio play-by-play I could with dual camera angles was cool. This same-year model second buy had sat in storage; The original tape the who sold it to me with 10 minutes of footage came with it. I could tell the battery was so much stronger after a full charge than my old one, but this newer D250 has maybe had 1/10 the recording time as my original. Whether listening to the camera speakers, piping the sound from the rear A/V jack or importing via firewire, it's the same. The video may not be perfect and may "spark" or "flicker" in unison with the audio that drops out,but not always. At times, the video seems just fine but the audio drop-out is akin to a loop and I could probably time it, which was what I termed as cyclical. Could one of my friends have dropped it or tipped over a tripod and not told me? Sure, but I would think they would have told me. One night, follow some high school hoops I was importing, excited at the prospects of some two camera angles mixing. Thought I may have had a bad tape, but ruled that out right away through trying multiple tapes in bother cameras. Apologies for my loquacious follow-up; I suppose if worse comes to worse, I could check eBay for a secondhand model. I've "misplaced" my original, but it will turn up; it's simply a matter of desiring to import all that footage, since 2008, with superior editing software and skill than what I possessed when doing so initially. Thanks so much!
Apr 13, 2014 | JVC GR-D250 Mini DV Digital Camcorder
See all JVC GR-D250 Mini DV Digital Camcorder Questions
JVC GR-D250 Mini DV Digital Camcorder Logo
208 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Steven Wander
Steven Wander
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
