Question about Dyna-Glo D-E37 Wall Mounted Panel Heater
Thermostate control is to short, has burnt back over time.
I want to know what part I need to order, I have a Model . RMI-80LPT wallmount heater. Serial NO. 03102. It is a Propane heater. I need to know what part no. to order. The tip of the control has shortened over a period of time and the flame does not hit the tip end of the control. I have three of these stoves I bought at the same time and they have all progressed to this stage. I bent the tip just enough to make them work as I did not see an adjustment on it. On heater also shots out the piolet further than it is supposed to is there some way to adjust it.
This says Free Service, I read the contract almost went to sleep.
Thank you kindly,
Phillip
  • Dyna-Glo Master
  • 3,328 Answers
I would get them serviced and repaired at the same time sound like they need it ,
Posted on Dec 16, 2008
Kolpak walk in freezer . the door heater will not work
Suggest replace the element.
Since this is an electrical/safety issue also suggest have qualified personnel attend to it.
Nov 02, 2017 | Kolpak Refrigerators
Dyna glo model rmi 80lpt parts
A thermocouple/Pilot Generator is pretty generic in its operation. If you can get one that will physically fit where the pilot flame is, positioned safely & securely, then any generic one will operate.
Jan 21, 2014 | Pool & Spa
My pool heater temp control will go off if i raise temp and seems to be not working properley
If its old just order a new one, they wear out with time. Waiting on one to arrive for a hot tub at work. This will be it's 2nd in 3 years (heaters are undersized).
Apr 14, 2013 | Pool & Spa
Ge refer model psc25mstass fresh food section not cold enough freezer cooling fine
I realize this is an old post but information is always helpful if it is correct. I have a GE Model TFX22ZRB, Main tools needed are a refridgerator thermometer, a cheap multimeter, 1/4" hex driver, phillip screwdriver and regular blade scewdriver, above all, alow time for tempeture change when measuring tempeture. The freezer is running at -8 degrees C or aproximately 28 degrees F. I don't care about 1 or 2 degrees at this point in the freezer, the defrost system is working ok, The freezer is cold enough. The fresh food section is running at 48 degrees F, the damper is wide open between the freezer and cold food section, I manually removed the damper door and controls since I am only interested in seeing if I can drive the fresh food section colder. Looks like the fresh food thermostate controls the compressor and not the damper to shut off the cooling process when the tempeture gets cold enough. Since the fresh food section does not get cold enough (this should be in the uppers 30s F) there is no need to move the fresh food thermostate out of the normal range setting (mid point in my case) with the operator control. Defrost heaters ok, this unit uses 2 heaters hooked in series with a evaporator coil thermostate also in series with the heaters. Heaters aproximately 25 ohms total risistance, coil thermostate open at room temp and closed when below 32 degrees. Only other item in circuit is the defrost timer, this can be manually advance to open and close the defrost circuit, in my case, when in the defrost mode, the evaporator fan stops and the heaters heat up. The defrost timer in my case has a 12-16 hour cycle time and a 30 min defrost time, so in a 24 hour period I may get only one defrost cycle. One item of importance. make sure something has not fallen in the lower back or the fresh food section of the refridgerator to block the air flow return, this will effect the coo;ing process. Now with the damper wide open, the defrost circuit working ok I am going to look at the evaporator fan itself for speed, shifted blades or the air circulation between the freezer and the fresh food section, I have cleaned the condenser coils but I am leaving the condensor and compressor out of the equation since the freezer is cold enough but at this point I am considering the possibility, I may need to replace the fridge if the compressor is not working to par.
Jul 18, 2012 | Refrigerators
I have a Dyna Glo model RMI-80LPT and the aluminum Gas Line going from the lower Regulator up to the Pilot switch / temperature control switch has a crack in it and I need to know what that part # is and...
If this aluminum tube has nuts on each end, I would bet that if you called your local plumbing supply house & described the part, they would have one in stock. Do you feel capable of removing the part?
Dec 21, 2010 | Dyna Glo "" Natural Gas Heater Mn200tba
I had purchased this unit RMO-80LPT heater several years back, I never installed unitl this week. the sales en at the time told me it was gas/propane. Now seeing the -80LPT on the side is it propane...
The orifices for a propane heater are much smaller so you will not be able to get the natural gas to flow properly with the current orifices.
The both the natural gas and propane valve are 1/2 psi so the valve can be used but the regulator for propane is typically 8-11 inches on the wc table and the natural gas is typically 3 lbs on the wc.
You may be able to drill out the orifices in the burner and in the pilot ods and get the unit to work.
Oct 13, 2010 | Dyna-Glo D-E37 Wall Mounted Panel Heater
Need Dyn-Glo Model RMI-70 ODS (Oxygen Depletion Sensor
Most of the time all you need do is blow out the sensor.
They don't wear out.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 22, 2009 | Dyna-Glo RMC-8001SS Heater
Need to know how to wire a thermostate to a hanging emerson heate
If this is an electric heater without a relay, you'll need a high voltage (electric heater) thermostat.
Is this a new installation? Give me some more info and we can get this job done...
Charlie
Aug 21, 2009 | Heating & Cooling
The pilot light won't stay lite
Flame is way too high on pilot . blocked injector or hole on injector is too big . Being sucked off by main burner .
Jul 04, 2017 | Dyna-Glo (PPH16-LP) Utility Heater
Dyna-Glo D-E37 Wall Mounted Panel Heater Logo
198 people viewed this question
Top Dyna-Glo Heating & Cooling Experts
Paul Carew
Ronny Bennett Sr.
Ronny Bennett Sr.
fordexpert
Are you a Dyna-Glo Heating and Cooling Expert? Answer questions, earn points and help others
