I cannot get the router to work.
It has worked fine for months until I started the pc a couple of days ago. the power light works, the status and adsl lights will not work, my lan connection light works and another lan light is on that is not connected. The other user connected is a gamer but we've not had any problems yet. I have tried default and it will not work. Is there a command that will 'wake it up'? Thanks
  • Frank
    Frank May 11, 2010
    who is your Internet Service Provider?
    what make and model is the Modem?
    New Friend:
  • 14 Answers
I think there isn't.
try to do something that mught sound kinda stupied but it worked for me.
Try pressing again the the back of the device for a few seconds ( I guess u haven't done this but I ve doing default witht the router's interface) and than set all the values again
Posted on Nov 25, 2008
We have a couple of computers that will not connect properly if at all through my dir 815 router... up until a few days ago they worked relatively fine, and we have a few other computers and an xbox that...
Hi! have you check your wireless encryption methods does every machine support ex.wpa2? how about signal status is it fine? you can allso try to give ip addresses manually to make sure they are correct
Mar 10, 2011 | D-Link DIR-815 Xtreme N Wireless 802.11N...
It worked well when I left Florida for Michigan in April. I disconnected the computer, modem, and router when I left and restarted them when I came down a few days ago. Bypassing the router I can connect...
Make the connection back again...
Comcast modem to the yellow slot in router, and your PC to any one of the gray slot in the router....
Now check for the light status in router and tell me what are the light lit up in green and what light are lit up in amber....
Jan 03, 2011 | Belkin F5D7234-4 Router
Worked great until a couple of months ago. Have
You can see network key by logging in to router settings. Some routers are 192.168.1.1 and some are 192.168.0.1. All you have to do is type it in to address bar on any browser and log in and under wireless tab it will give you field where it says wep or wpa encryption and this is what you need. Hope this helps.
Feb 15, 2010 | Dell Inspiron 1501 Notebook
I have an ADSL D-Link modem (DSL-300G)that works fine. I hooked a D Link wired router, EBR-2310 and can't get to the internet. It use to work until one day recently the kid moved wires arround because no...
First: Connect your computer directly to the ADSL modem. It has an Ethernet port.
If you can't get to the Internet while your computer is connected directly to the modem, then ytour router never will either. Call ISP if you can't connect to the Internet when directly conencted to the modem.
Next: Check your router wires again, The modem must be connected to the "special" port on the router. Look at the router. There is one port separated from the rest. Connect the modem to that port. Conenct to the Internet.
Still no Internet?
Reset your router by pushing a stylus (straightened-out paperclip) into the reset "hole" on the router (with router powered ON).
Push & hold for 30 seconds or until the lights do their reset dance. Connect to the INternet.
Oct 07, 2009 | D-Link 4-Port Ethernet Broadband Router...
Wireless signal stops working after some period of time
The final solution is a factory reset of your router. You can do a factory reset by logging into the router using you browser. Go to the settings and perform a factory reset
If you forgot the router password, you ill have to do a factory reset by locating a small hold on the back of the router and insert the tip of of paper clip for about 10 seconds while the power is on. The router will be reset to out of box status and then you can set-up form scratch.
Sep 26, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
No Display on my Samsung 204B monitor
If you know how to open it up and get to the power supply you will find three capacitors 2-820uf and 1-330 @ 25vdc 105o.they will have puffed up tops replace them. FYI the monitor has a 3 year warranty.
Dec 12, 2008 | Samsung SyncMaster 204B 20.1" LCD Monitor
No status light
On your connection LAN icon that normally sits at the bottem right hand corner, Right Click on it and select "Repair"
That should do the trick.
Jun 13, 2008 | Paradyne 6381 ADSL2+/ReachDSL Router...
ADSL Router DSL-G604T
all ADSL routers are very fussy when it comes to power fluctuations, even the tiniest can set them into error, first thing to try, is pull the power cord out of the back of the modem, wait a couple of minuteds, then plug it back it, give it a few moments to re-connect and see how it is, if no luck with that, check the DSL, or ADSL light is on and solid.. if so look on the bottom of the modem for an ip address, open internet explorer browser, type that ip address into the address bar and hit enter, it should prompt you for a username and password.. usually ADMIN for both user and pass.. then go to "status" or "diagnostics" depending on the modem, and it will give you a run down on any potential problem..
PPP error: username and password are wrong (Authentication Failure)
Jun 01, 2008 | D-Link DSL-G604T Wireless Router
Power and status lights off
Sounds like you may have been hit with a power surge. If you've unplugged it and let it sit for a while unpowered, and you've hit the reset button most likely the unit is broken.
Sep 30, 2007 | D-Link AirPlus Xtreme G DI-624S Wireless...
Computers & Internet Logo
Alun Cox
David Payne
David Payne
