Works fine thenafter a few seconds a loudsound and announces an unpardonable error and is inoperable.
Dear Sir/Madam,
Try to re-formatted my SD card. check the below link
http://www.fixya.com/support/t249593-fatal_error_message
Thanks
Good Luck
Your SD card/program is faulty. Unfortunately, the website does not offer any map downloads.
Best contact Customer Service to determine if a return is necessary. If repair service is required, you will be issued a Return Authorization Number. Contact Customer Service via email or call toll-free at 866-346-3344, 7 a.m. to 5 p.m. Pacific Standard Time, Monday through Friday. Please be prepared to provide the following information:
Unit's serial number
Your name
Street address
City
State
Zip/postal code
Country
Daytime phone number
Proof of Purchase
Problem you are experiencing
If it becomes necessary to send a product for repair or replacement, you must first receive a Return Authorization Number from Customer Service. Fine Digital USA is located at 3003 N. First St ., San Jose , CA 95134 , USA .
Or you can purchase a new SD card for $25 HERE.
Hope that helps!
I would suggest call finedrive tech support, if the problem is not resolved after the reset of the equipment. It may need a software reload.
toll-free Customer Service line at (866)-346-3344. Technicians and representatives are available to help you Monday through Friday from 8 a.m. to 5 p.m
When contacting us, please provide the following information:
Your name
Street address
City
State
Zip/postal code
Country
Proof of Purchase
Thanks
proton
Apologise for the inconvenience, but that the only number they have listed on there website. The other way to contact them is by email, you can send them a email at
[email protected]
Thanks
proton
Just wanted to know, were you able to resolve the issue.
Thanks
proton
You can purchase the SD map from here
http://www.finedrive-acc.com/shop.cart?action=ITEM∏_id=6
Try to reset the device otherwise needs to be replaced.
Might be a corrupted firmware causing that error, try and find an updated firmware for it or software that is. if you cant find it let me know and i'll look for it myself. Thanks
I found a couple of thing you can try:
Resetting the GPS
The GPS reset function is helpful when the device doesnt
recognize your current location properly. If the device doesnt
recognize the current location for a while, please try the
following procedure before returning it to the retailer.
Park your vehicle at a safe place free of
obstructions
Select the Setting on the Home Screen.
Select the GPS Reset icon.
Tap the GPS Reset icon.
Allow up to 5 minutes for the Finedrive 400 to
locate a GPS signal
Contact Technical Support if your current position
is repeatedly not detectable
Setting Touchpad Calibration
In very rare cases, if the Finedrive 400 stops moving completely
and you cannot activate any of the buttons, it could be a
touchpad calibration issue. Use the touch calibration function
when touch pad is not working at all. Try the following
If you need access to the user guide you can find it here: http://www.finedigitalusa.com/2006/support/FD400_UserGuide.pdf
I hope this helps as I couldnt find any other info related to your error issue.
Its probably a bad SD card, if a firmware upgrade doesn't work, then try a different card, if that doesn't work, then we can look into other possible causes but the SD card is the best bet
Please try to reset to the factory settings and then try to reconfigure.
It is a frimware problem. the same happened to me. there is an easy procedure to reinstall the firmware from the fine digital site. this is a common problem and you will have it fixed in a jiffy.
you can find the site mentioned here
Setting a Personal Security Code (PIN)
If you want to be able to play your messages from a remote location, you need to enter a two-digit Personal
Identification Number (PIN) code (01-99).
To select a PIN, perform the following steps:
1) With the phone in standby, press [menu/clock] twice.
The system announces "Security code," and the current PIN code is announced as it is displayed on the base.
Then the system announces the instructions for setting the PIN code.
2) Press [volume/select/ ] or [volume/select/ ] until the desired number appears.
3) Press [set] to select the PIN code. You hear a confirmation tone, then the announcement "Security code"
followed by the new PIN code is announced. After a few seconds, the system announces "To set ring time, press
menu again."
Note: The PIN code is set to "80" at the factory.
After receiving the"fatal Error" notification I then unplug and then replug the GPS unit and it operates normally for 1-2 minutes before it recurrs.
Where do I find a Firmware upgrade? Where do I purchase a new SD card?
The questions posted on Nov. 26 have not been addressed.
Fine Drive Version 1.01.04
Fatal Application Error
Program IntelliNav.exe
Exception Oxcoooooo5
Address 01029EB8
Gps reset did not help
How do I reset it, Wiz?
No help so far. The first expewrt said he encountered the same problem. Let's get him back, please.
Proton's advice sounds good, but 866-346-3344 is a non working phone.
I down loaded the FD 400 to my PC. How do I put it into my Fine Drive?
