Question about GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile Side by Side Ref fix for Heath
Yes sir I did 4 stars thanks again for the help.
  • MIKE major May 11, 2010
    ONCE AGAIN GOOD JOB TROUBLE SHOOTING,MIKE
catriver
  • 878 Answers
SOURCE: GE ARTIC PROFILE REFRIGERATOR....INTERMITTENT HEATING
Sarct, the question is, was the freezer side ok, if it was, I would suspect the damper not opening. If the freezer side was warm too, then I would suspect the evaporator thermistor not sending the signal to the board to terminate the defrost. Have the tech first check the continuity at connector J3. He should have 400ohms at J3-1 to J3-2 and the same at J3-3 to j3-4. If he doesn't get those readings have him check at the damper motor itself. If he doesn't have it there, replace the damper motor. If the damper motor passes all the checks then it's on to the evaporator thermistor. Have him check the resistance. At 5 degrees it should ohm at approx 36K ohms. The evap thermostat is redundant to the defrost operation. It's there as a back up in the event the evap thermistor fails to terminate the defrost. It's normally closed and will open at 140 degrees.
Posted on Dec 20, 2007
MNTECH
  • 1543 Answers
SOURCE: GE Profile Artica Refrigerator
OK, it sounds like you have a defrost problem. When left unplugged for a few days the frost melted off the evaporator (the cooling coils behind the freezer wall) but after you ran it again, the coils blocked the air flow again, usually happens after a week or so, depending on # of door openings, humidity in home, etc. Most likely you have a burnt out defrost heater.
Posted on Aug 28, 2008
cactus bob
  • 267 Answers
SOURCE: Need your opinion on buying a new GE Profile refrigerator.
no dont do it GE is just bad news . if you must by ge make suer you buy the extended warr .and keep it current YOU WILL NEED IT ! ....... what one should buy? it does not matter , there all the same refrig inside ,just just STYLE you pick DONT FORGET EXTENDED SERVICE PLAN !
Posted on Jan 16, 2009
  • 219 Answers
SOURCE: ge profile water/ice fridge side under bottom drawer
take out the back panel in frzzer side use a steamer to clean out your drain hole
Posted on Mar 19, 2009
SOURCE: Not cold enough
I opened the bottom panel at the back of the fridge and cleaned the coil because it was completely covered with dust and lints and less than an hour later the fridge side temp started going down and the freezer took five hours for the temp to start going down when we didn't open it for that much time. It's back to factory setting now and thanks for the blogs that I read that I was able to try different possibilities. Your site is very helpful.
Posted on Mar 21, 2009
GE side by side refrigerator 220 volts. Model #
Hi again,
Yes, 2HP compressor is what suitable for this model of refrigerator sir.
Thank you for visiting FixYa!
May 12, 2011 | GE Refrigerators
My refrigerator is getting too cold and freezing the products inside. I've lowered the temperature to 3 but it is still freezing. The water in the door is also not dispensing.
yes try the other knob make freezer colder it will make ref warmer.. what that knob does is lessen or makes more cold air come from freezer. less cold air should warm ref up. ok try that. later gator
Feb 18, 2011 | GE Profile PSW26P Stainless Steel Side by...
PSS25S side by side is freezing vegetables. We
Sir, To solve this problem, you must open the compressor area at the back bottom of the refrigerator and chek the temperature of the pressure line. If the temperature is between 55celcius to 60 than its ok. Or else you need to change the refrigerant. I suggest you to contact the service authority.
Thanks for contacting Fixya.
Sep 12, 2009 | GE Profile¿ Arctica® Energy...
Water dispenser starts dispensing by its self
I love GE Profile Units! This sounds like the switch may have a short in it. I would replace that switch asap and make sure your insurance policy is paid up just in case it does start flooding while you're away or during the night while you are sleeping. Hope this helps you! Ella
Aug 19, 2009 | GE Profile¿ Arctica® Energy...
I have a GE Profile Arctica. Refrigerator side stays at 29-31 degrees no matter how high I set the temp. Modle PSC23NG. Can you please Help? Is this an expensive repair?
HI,
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks,
Mar 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Drips at water dispenser GE PSC23MGSA BB
If it's a constant drip then you need a new water valve.
Jan 03, 2009 | GE Profile Energy Star PSC25MGS Side by...
No water, no ice comes out from the dispenser.
ge has changed the part and part # the part should work fine
Dec 14, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Profile side by side refrigerator
did you leave me a fixya rating?thanks-mike
Nov 24, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
