Question about AOpen EZ65 (ez65white) Barebone
UX4SG-1394-2 Motherboard Please tell me, where the hell is the bios-battery on this mainboard ?
  • 320 Answers
Bios batteries don't usually have a specific place on boards. I have seen the same boards with the batteries in different locations. The best thing to look for is a nickel size silver circle. This is the battery. It can either be standing up on end or laying flat on the board. You can tell further its the battery because it looks like a large watch battery.
From the images I can find online it may be next to the IDE ports and the power port near the front of the board. Back of the board being where all the hookups are for audio and video.
Posted on Dec 11, 2008
Asus desktop bios pass
Hello a bios password is fairly easy to come buy.
Open the case, and locate the cmos battery on the mainboard:
Remove the battery for like 20 min, and insert the battery again.
This will clear the bios password.
But you have to setup the whole bios, boot setings, clock, date, etc, before the pc can run again.
Visit asus here:!Downloads/c1wax
And enter the mainboard number, or use auto detect to find the mainboard.
This is for downloading the manual, if in doubt setting up the bios.
Good luck
Mar 18, 2013 | ASUS Computers & Internet
Reset or Recharge the bois
Hello the homepage is here:
Download the manual, for detailed setup instuctions.
The bios can set to reset by removing the cmos battery on the mainboard and insert it the same way again.
But you have to setup the bios settings, clock, date, boot settings.
The battery can also be renewed, it sometimes rans out of power.
The battery is a cr 2032 3 volts watch type.
Try not to upgrade the bios, unless you 100% sure it`s the right mainboard !!!!!!!!
Flashing the bios with a wrong one, will destroy the mainboard.
Good luck
Jan 22, 2013 | Asrock P4I45GV...
I want to install a new bios for my memory but I don't find the update, my actually version is the v6.0 (7/19/06). It's a phoenix awards bios please help me :'(
Correction the bios update is for the Mainboard or motherboard for a PC. It not for the "memory"? To update your Bios you have to to know the precisely the model/brand of your mainboard before you can download the new bios file needed for the update from the manufacturer site.
There are precautions you need to heed before doing a bios update for the mainboard. In case of any eventualities or mistakes you made may render the mainboard useless!! If you are not 100% sure how to do it, get some professional help.
If you Mainboard is running ie with no errors!, it is advisable not to do the bios update unless recommended by the OEM manufacturer or you need to run a new function from the mainboard which is not included in the old bios.
Hope this helps.
Oct 05, 2010 | Computers & Internet
Forgot bios password
Remove the bios battery, regular battery and power cable. This will cut all power to the mainboard and reset the bios password. The bios battery is a small circular battery somewhere on the motherboad. some modern laptops will have a little flap you can unscrew on the bottom, without having to take the whole case off.
May 15, 2009 | Acer Aspire 3624WXMi Notebook
P4s533 mainboard
Reset BIOS back to default
1) remove M/board battery for 5 to 10 minutes
while booting press the DEL or F2 or ctrl+esc
or check lower part of screen during boot will tell you hoe to fet into BIOS
Once BIOS reset to default boot computer if OK.
you can change BIOS to suite CPU etc
Oct 29, 2008 | ASUS P4S533-MX Motherboard
When i tried reseting my computer to its original factory setting i needed a password so i clicked on password hint and it said you will never know and i didnt even set a password HELP???
Do you mean BIOS settings or WIndows was re-installed?
If BIOS setting then there is a jumper on the mainboard - obtain manual (or tell us what mainboard it is) and then use the jumper (link) on mainboard to reset CMOS.
The other way is to disconnect all power and then remove small button cell battery from the computer, then press power button.
Then wait for 1 HOUR before re-inserting battery and powering up again.
If you switch on before 1 hour then you will have to wait 1 hour again. If 1 hour is not long enough wait 2 hours or overnight. (usually it takes 20-40 mins to discharge capacitors).
Aug 10, 2008 | Computers & Internet
CMOS Battery
yes ..the batery removal will erase your bios settings and will set them to default attention to disconect the computer from the energy supply and take out the back energy cable from the computer when doing this.
second..after you changed it,with the computer always off make  abios reset by switching the jumper on the mainboard according to the instructions provided in the user manual...after that connect and get on the computer and remake the changes and bios..
good luck
Feb 03, 2008 | Computers & Internet
Forgot password for bios setup utility
Well i can tell you what to do but it is difficlt and you should get professional help
Take out the top cover (including keboard) from the laptop
Remove laptop battery as well as mainboard battery
wait 1 minute
replace mainboard battery followed by laptop battery
thats it bios is reset and set to defaults..
just enter the bios after and load fail safe or optamised defaults and you are done
Jan 10, 2008 | IBM ThinkPad T40 2373 Notebook
AOpen EZ65 (ez65white) Barebone Logo
2,654 people viewed this question
Top AOpen Computers & Internet Experts
Michael Galve
Michael Galve
Alun Cox
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
