Question about HP Photosmart C3180 All-In-One InkJet Printer
Changing ink cartridge on the HP Photosmart C3180 all in one
We lost the booklet and this will be the first time I need to change the ink cartridge on the printer. When I open up the front panel I can't figure it out. It doesn't look like a regular cartridge. Can you help me?
  • Anonymous May 05, 2009
    lost instruction manual for photosmart c3180 and I wanted to open the printer.
    Problem Solver:
  • 10 Answers
The Basics manual from HP:
http://h10032.www1.hp.com/ctg/Manual/c00694908.pdf
Check out page 17 of the Basics manual for detailed instruction on replacing the cartridges.
Make sure the HP All-in-One is on.
Caution If the HP All-in-One is off when you open the print cartridge door
to access the print cartridges, the HP All-in-One will not release the
cartridges for changing. You might damage the HP All-in-One if the print
cartridges are not docked safely when you try to remove them.
2. Make sure you have letter or A4 unused plain white paper loaded in the input tray.
3. Open the print cartridge door.
The print carriage moves to the far right side of the HP All-in-One.
4. Wait until the print carriage is idle and silent, and then lightly press down on a
print cartridge to release it.
If you are replacing the tri-color print cartridge, remove the print cartridge from the
slot on the left.
If you are replacing the black or photo print cartridge, remove the print cartridge
from the slot on the right.
1 Print cartridge slot for the tri-color print cartridge
2 Print cartridge slot for the black and photo print cartridges
5. Pull the print cartridge toward you out of its slot.
6. If you are removing the black print cartridge in order to install the photo print
cartridge, store the black print cartridge in the print cartridge protector or an
airtight plastic container.
If you are removing the print cartridge because it is low or out of ink, recycle the
print cartridge.
7. Remove the new print cartridge from its packaging and, being careful to touch
only the black plastic, gently remove the plastic tape by using the pink pull tab.
1 Copper-colored contacts
2 Plastic tape with pink pull tab (must be removed before installing)
3 Ink nozzles under tape
Caution Do not touch the copper-colored contacts or ink nozzles.
Touching these parts can result in clogs, ink failure, and bad electrical
connections.
8. Slide the new print cartridge forward into the empty slot. Then gently push on the
upper part of the print cartridge forward until it clicks into the socket.
If you are installing the tri-color print cartridge, slide it into the left slot.
If you are installing a black or photo print cartridge, slide it into the right slot.
9. Close the print cartridge door.
If you installed a new print cartridge, the HP All-in-One prints a print cartridge
alignment sheet.
Note If you have colored paper loaded in the input tray when you align
the print cartridges, the alignment will fail. Load unused plain white paper
into the input tray, and then try the alignment again.
If the alignment fails again, you might have a defective sensor or print
cartridge. Contact HP Support. Go to www.hp.com/support. If prompted,
choose your country/region, and then click Contact HP for information on
calling for technical support.
Posted on Nov 25, 2008
  • 903 Answers
How do i change cartridge safely on photsmart 2610
Here is a good animation and details showing replacement of your ink cartridges:
C3180 Ink Replacement
You may also bookmark this site:
C3180 Support
There are links for many different things.
Thanks for using Fixya.
Oct 19, 2009 | HP Photosmart C3180 All-In-One InkJet...
Will HP Photo copy with only one cartridge?
No.
You need to have both cartridges for it to operate properly.
Mark
Mar 27, 2009 | HP Photosmart C3180 All-In-One InkJet...
Want to know where u put the photosmart ink in printer
Open the print cartridge door. Make sure the print carriage moves to the right. If it does not move to the right, turn the device off, then turn it back on again. IMPORTANT: The device must be turned on to insert cartridges.
You can see the location and proceedure to change the ink cartridges on page 14 of the manual (found here: http://h10032.www1.hp.com/ctg/Manual/c00694908.pdf). Sometimes a picture is worth a thousand words <grin>.
Hope this helps,
Chris
Mar 23, 2009 | HP Photosmart C3180 All-In-One InkJet...
Ink cartridge
Black HP 92
Color HP 93
Photo HP 99
Jan 11, 2009 | HP Photosmart C3180 All-In-One InkJet...
How do I install ink HP photosmart c3180
Hey DDD,
It looks like HP put together an animation to help with replacing the ink cartridges. I know you are just trying to install them for the first time, but it might be helpful:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00652671&cc=us&lc=en&dlc=en&product=1146331
Also, since you are just setting up the new product, double check that you've removed all the packing material and tape from the cartridges. I've made that mistake before ;-)
Cheers,
_K
Jan 08, 2009 | HP Photosmart C3180 All-In-One InkJet...
After changing the ink cartridge, my printer wouldn't print.
change cartridge from 60 to 60l and printer wouldn't recognize cartridges
Dec 21, 2008 | HP Photosmart C3180 All-In-One InkJet...
Need a #92 ink cartridge in Tokyo
go to hp.com oder the cartridge and have them ship it to you.
or have them suggest what is the best replacement cartridge.
Nov 29, 2008 | HP Photosmart C3180 All-In-One InkJet...
I have an HP C3180 Photosmart Printer, we lost the instruction booklet. How do I install new ink cartridges.
Here's the manual for your HP C3180 and it includes instructions on how to properly remove and install a print cartridge.
HP C3180 User Manual
Nov 05, 2008 | HP Office Equipment & Supplies
Ink cartridge
Go to www.hp.com
Click on Support and Troubleshooting
Type C3180 for Product press Enter
click on Set up and Install
Click on install the Print Cartridges
Mar 04, 2008 | HP Photosmart C3180 All-In-One InkJet...
HP Photosmart C3180 All-In-One InkJet Printer Logo
2,326 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
