Question about RCA 20F420T 20" TV
My RCA 20F420T TV is used only for video inputs and they were shut off when someone touched the volume buttons. I have no remote and the video mode doesn't appear to be accessable from the front panel. Additionally, I put it in "FPA locked" mode in trying different settings. So now it does nothing but show a blue screen or snow. The online manual says video mode is only accessible via the remote. I see that I can buy a remote from RCA's website, but is there a better way.
    Sergeant:
  • 291 Answers
The best way WITHOUT buying a R/C[remote control] is to disconnect the tv from the a/c power (unplug it enterly) place a screw driver or any metal between the blades of the a/c plug. leave it there for at lease 2-3 days (SERIOUSLLY!!)
attention:: the a/c plug will be OFF the electrical socket and REMAIN UNPLUGED for the duration of 2-3 days. [DON'T TAKE A SHORT CUT and say 3 hours is enought]
take the SHUNT or SHORT from between the blades and replug into a/c socket.
p.s. sorry that I am so specific and deliberate and I don't want to insult your integellance, but you will be suprised of how people don't listen, pay attention, or don't think with common sense..
Posted on Nov 30, 2008
How do you switch to video mode with no remote
hi,
you cant.
your going to have to get a mid priced universal with extended features. read the packaging. thrift stores sometimes have a bag wall with old remotes so if you have someone who goes to the thrift store sometimes tell them to start looking for either a vcr or tv remote that says emerson on it for you. directv and dish network universals have video input buttons, if you have eith of those providers go to their website, download or find the chapter where it shows how to set up your viseo input. it is shut off by default..
jm
Apr 14, 2011 | Emerson EWF2004 20" TV
Hi how to open fpa
The front panel lock can only be unlocked with the remote. Press Menu, then Ch+ or Ch - to select Preferences. Press Ok then use the Ch+ or Ch- buttons to highlight FPA (front panel) lock. Then use the Vol+ and Vol - buttons to select On or Off. Then press Menu repeatedly to exit the menu system. With the FPA lock disabled, you can turn it on from the front panel of the TV by pressing the Menu button. However, with the lock enabled, you can only power off the TV from the front panel.
Since the Input button is also only on the remote, if you look for a universal remote, choose one with both Menu and Input or Source functions. Then try all the RCA codes until you find one that makes all of the remote functions work. The original remote is: RCR130TA1 . A substitute remote that should match all of the functions is available here: http://remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=20F420T&uuid=13004957447460 .
The manual for the RCA 20F420T is available here: http://support.ttetech.com/RCATV/NewTV/Templates/SupportDownloads.aspx?NRMODE=Published&NRORIGINALURL=%2fen-us%2fproductdownloads.html&NRNODEGUID={35D79B02-4AAE-4834-BFD0-1124EA501FA2}&NRCACHEHINT=NoModifyGuest . If the direct link doesn't work, start here: http://support.ttetech.com/en-us/productdownloads.html . Select a 20" TV and then your model number in the drop down menus and press Go.
I hope this helps.
Mar 19, 2011 | RCA 20F420T 20" TV
20FP420T FP lock on and can't select input no remote?
Do you mean the 20F420T? RCA doesn't have a 20FP420T as far as I can tell.
Unfortunately, you can't turn off the Front Panel (child lock) without a remote. All of the front panel Power button to turn off the set but not to turn it on. You need a remote that matches the Menu function. Press Menu, then use the Ch+/Ch- buttons to select Preferences. Press OK then press Ch+/Ch- to highlight FPA lock. Use the Vol+/Vol- buttons to toggle the lock function on or off. (Off lets the front panel work normally) Then press Menu repeatedly to exit the menus. A substitute remote can be obtained here: http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=20F420T&uuid=12994577706920 . This is guaranteed to work with the 20F420T . Most universal remotes should also work as long as they were programmed after 2006.
The manual for the 20F420T is available here: http://support.ttetech.com/RCATV/NewTV/Templates/SupportDownloads.aspx?NRMODE=Published&NRORIGINALURL=%2fen-us%2fproductdownloads.html&NRNODEGUID={35D79B02-4AAE-4834-BFD0-1124EA501FA2}&NRCACHEHINT=NoModifyGuest . Fill in the drop down menus for 20" and the model.
I hope this helps.
Mar 07, 2011 | RCA 20F420T 20" TV
I have a RCA Truflat tv model 20F420T and serial number H494E2526 and accidentally hit a button on my digital cable box remote which sent the tv into a mode showing FRNT. In trying to solve the issue, the...
Using the remote control hand unit that came with the TV turn on TV. Then go to the set up menu. Locate the entry for Front Panel Lock (FPL) and select no. Once you have done that exit the set up menu then on the same remote push the "input" button while watching the screen. Push button once wait a few seconds for a picture to appear, if not then push the button again, continue until you have selected the input that provides a picture. Right now you are in the Front inputs you should look for Video 1 or 2.
Feb 18, 2011 | RCA 20F420T 20" TV
How do i turnoff parental lock on a 20f420t rca tv. i just purchased a remote and don't know security code.thanks
Hello
Most RCA and GE TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
  1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
  4. Hold down Eject button on the friont of your TV set and MENU button on the remote at the same time for at least four seconds. Depending on the model, one of these methods should unlock the V-chip. Now, if desired, you can chang the setting on the V-Chip by going to the menu and going to "Parential controls" or on some sets going to MENU and then goint ot TV SETUP , then to V-CHIPSET.
OK.
Jan 02, 2011 | RCA 20F420T 20" TV
I can t hook u p my playstation 2
plug in the video and audio in the front, (rca hook ups) then with the remote goto video input( the input button on the remote) select video 1 or 2. you only have 2 inputs 1 is rca and 2 is s-video
Dec 12, 2010 | RCA 20F420T 20" TV
Lost orig remote/ fpa lock on
I have a 20f511t RCA Tru Flat with FPA lock on, using an universal GE remote press setup, then menu, channel down to preferences, press enter, channel down to FPA LOCK, volume up to change to on or off, press menu to remove, all shoud work now
Nov 23, 2008 | RCA 20F420T 20" TV
FPA lock
hi i have a universal remote and my granddaughter pressed a button on the tv and now i need to unlock the fpa can some one please help.
Mar 08, 2008 | RCA 20F420T 20" TV
RCA 20F420T FPA lock
Most RCA and GE TV sets use a four digit code to control the v-chip. The code reset procedure is different depending on the model. Try each method until you find one that works:
  1. Hold down MENU on the remote and VOLUME DOWN on the TV it’s self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  2. Hold down the 0 on the remote and the VOLUME DOWN buttons on the TV its self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  4. Hold down GO BACK on the remote and MENU on the front of the TV at the same time for at least 4 seconds.
  5. Hold down EJECT on the front of the TV and the MENU button on the remote at the same time for at least 4 seconds.
Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
Jan 21, 2008 | RCA 20F420T 20" TV
Rca 20F420T
if you can bring up the menu try using the volume up / down and channel up/down on the remote to change your selection. that might work
Sep 01, 2007 | RCA 20F420T 20" TV
RCA 20F420T 20" TV Logo
171 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
