The product is a Gas-Fired Pool and Spa Heater that fires up and stops after 30 seconds and the indicator lights flash for "Service" and "Air Flow". I can repair if I had an idea what and where the Air Flow control is. Thanks!
SOURCE: Pool Heater
You can light the pilot with a B.B.Q. lighter.
Nottoohandy. Backwash you filter, make sure it's really clean. If that doesn't work it could be the pressure switch. You can by-pass the switch with a piece of wire to see if it fires up. If it does, it's the switch. There is a picture of the switch in the manual.
C
SOURCE: i have an older reddy heater pro 100 kerosene space heater,
You Must set the pump pressure quickly! If allowed to run with the nose cone a "bright" cherry red the welds will deterioate to the point that the end will separate from the combustion chamber. Individual sheet metal parts of the chamber are not available.
Learn how to properly set the air pump pressure
SOURCE: Reddy Heater keeps shutting down
I tried to go to www.desatech.com and you cannot buy parts on that site anymore. I can get my Reddy Heater parts at www.masterparts.net.
SOURCE: Jandy pool heater model #LT400N-L service and ES1 light blinking
The heater won't fire up if there is no or inadequate water flow. Ck water pump and filters.
SOURCE: Have Dyna-Glo Unvented Gas-Fired Room Heater,
I had the same issue. Iwent to the local harware store and bought heay duty mirror hangers. They work great for only a few bucks.
I was hoping I could get some sort of 'exploded' diagram of a Jandy LX-250L heater that pointed out the part I needed to get.
