Question about Hitachi 53UDX10B 53" Rear Projection Television
50inch hitachi tv power will not come on
No power
  • winfordr Jan 10, 2009
    No power, no obvious damage on circuit boards. Gets ac to and past the fuse. Open resistance on power cord when unplugged.
    New Friend:
  • 14 Answers
Have you checked pluging the cables into other working slots?
Maybe the lamp should be replaced (which is the most common solution to your tv types).
If not there's a chance that the fuse is gone.
Few things you might wanna do before calling to someone - you may wanna check the cables.
Let me know if you have anything
Posted on Nov 25, 2008
I have a Hitachi Ultravisio 50inch plasma TV. I was watch it when all of the sudden the screen went black. The TV did not turn off. What is the problem and can I fix it reasonably?
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Mar 24, 2017 | Hitachi Televison & Video
Hello, I have a Hitachi 70VS810 that just started going out. I'll be watching TV and the picture will fade away, go out without sound too. The power button blinks fast the whole time its out. It stays...
This is more likely to be an issue with your power supply not being able to supply the correct voltage to a certain board all the time. Most likely bad/aging capacitors. You could probably find a new repalcement power supply board on line. Check with Shop Jimmy, they may have one fairly cheep.
Nov 10, 2014 | Hitachi 70VS810 70" Rear Projection HDTV
Could a wire have broke off inside the back of my older model 50inch hitachi tv,with the bigger backside,when the cable cord was pulled out of the back, instead of unsqrewing it fromits connection? th
No. No wire should come out. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Sep 05, 2014 | Televison & Video
What happens to a plasma tv when the power goes out and it won't turn back on? 50inch plasma Panasonic vieja
If you are lucky either a fuse is now bad or the event may have caused damage to the power supply board inside the TV set.
Jun 13, 2012 | Televison & Video
Can a cooling fan be fiited to my 50inch philips plasma tv
yes to your ? i asume you have had the back off of this tv...there are 6-7 modules inside. the power supply is where you need to focus some attention. and yes plasma sets do overheat.try to find a way to attach 2 120mm fans to the heatsinks. then try to find a 12 volt source with a volt meter. attach the fans to that source and you are good to go. be carefull not to short or overload the power supply. or you will be spending 3-4 hundo for a new 1... good luck..
Nov 23, 2009 | Cars & Trucks
Hi i have a 50inch sony bravia rear projection tv
I will forward a link to a page where you can get more information and troubleshooting steps for this issue.
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType
=kc&externalId=C399467
Jun 14, 2009 | Sony Televison & Video
No Picture or Sound, Blinking blue light
the bulb is blown, replace bulb prie 150.0 to 250.00 it is not a hard repaitr to do yourself.
Apr 17, 2009 | Hitachi Ultravision P50S601 50 in. Plasma...
50inch rear projection tv power will not come on
it was the fuse. I took it out cleaned it put back in and is working. Thanks.
Nov 25, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Projection TV red is drooping
Do an internet search on "Hitachi Convergence Circuit". This apparently happens all the time. TV repairmen charge about $400. Parts are less than $50 but you would have to be an expert at soldering electronics circuits to replace it yourself.
My TV had the Blue misalign instead of the Red. I ordered the kit #9 from http://www.bdent.com/search/part.jsp?partnum=KIT9
DO NOT ATTEMPT IF YOU DO NOT KNOW HOW TO SOLDER. YOU WILL PROBABLY RUIN YOUR TV.
Aug 15, 2008 | Hitachi 50GX30B 50". Rear Projection...
Turns off on own
Take to repair shop or replace (2) STK392-110s.
Oct 16, 2006 | Hitachi 50DX01B 50" Rear Projection...
Hitachi 53UDX10B 53" Rear Projection Television Logo
71 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
