Question about GE Microwave Ovens
Microwave is dead. wont lite up. Power source is fine.
Accidentaly reheated water for 10 minutes instead of 1 minute. Water was gone, machine shut down, everything blank. Followed owners manual troubleshoot, no help. Is there some sort of fuse, or reset, inside the back??? What do now? Machine just now out of warranty, (one year old) GE model JE 1460 BF 03 serial VL 900474 U Thank You ! !.
We have a similar situation where we were heating food, there is no power. The model #JVM1090 Serial # 912305S. Is there a fuse or reset button, we do have the owner's manual and would like to make the repair if it is simple.
Thank you for your help
Joe Spano
Posted on Nov 25, 2008
How do you use the kitchen timer and cook at the same time?
If you have the kitchen timer set for instance for 10 minutes and it is counting down, and then you want to reheat you coffee for 2 minutes. You would hit either time cook or reheat button and enter 2 minutes ten hit start. The microwave will heat your coffee and show the 2 minute countdown for that. When done it will revert back to what is left on the 10 minute kitchen timer without missing a beat on most microwaves.
Feb 26, 2015 | Microwave Ovens
What is the highest power setting? choices are low, defrost, medium, roast and reheat. no high???
Most microwaves run high at default, if roast and reheat are given that is your high setting, take one cup of water and run for 1 minute in each setting, the water that is the hottest is the high setting.
Mar 19, 2012 | Emerson MW8625W Microwave Oven
Microwave wont heat up food
If your microwave runs, but doesn'theat your food, verify that you have selected a cooking setting. You mayaccidentally set the timer. Test the magnetron by placing 1 cup of water in themicrowave and heating the water for three minutes. If the water doesn't heat,your magnetron is dead.
Mar 08, 2012 | Sanyo Microwave Ovens
Microwave now takes ~2x longer to heat up and is steaming up inside
Place a 1/2 litre of water in a plastic microwaveable container. Record its temperature and place it in the microwave. Microwave on full power for 1 minute. Leave for 30 seconds and measure the temperature again.
If the temperature rise is at least 10 degrees Centigrade, the magnetron is fine.
Mar 02, 2011 | Whirlpool Microwave Ovens
I have never used the power feature and now I need to and cant find manual. How does the power feature work. I need to operate the microwave on medium power for one minute.
1 Use the number buttons to set a cooking
time. You can set a time from one second to
99 minutes, 99 seconds. To set a time over
one minute, enter the seconds too. For
example, to set 20 minutes, enter 2, 0, 0, 0 .
2 If you want to set the power level to
something other than High, press the Power
Level button, then use the number buttons
to enter a power level.
Power Levels:
Level Cooking PL
1Warm10
2Low20
3 Defrost 30
4Medium Low40
5Medium50
6 Simmer 60
7 Medium High 70
8 Reheat 80
9 Saute 90
10 High Hi
Hope that helps.
Mar 01, 2011 | Emerson MW8107WA Microwave Oven
Monday evening I used it was for heating hamburger buns. I used sensor reheat and it worked perfectly. Tuesday evening I wanted to defrost a small beef roast. It worked for 1 minute then shut down...
try unplugging it. or the probe might be defective. another trick is slamming the door when shutting it, if this works it;s a micro switch thats gone bad or out of alignment
Jul 14, 2017 | Panasonic NN-H504WF Microwave Oven
Microwave is on when you shut the door
I tried all the things on your website. Holding the clear button , unplugging,...
So I went back to the last operation that I was doing when the problem started.
I was using "reheat" so I put a glass of water in the micro turned on reheat 1 serving.
It started and then I hit clear after a few minutes and the problem went away.
Dec 15, 2008 | GE Advantium 120 Convection/Microwave Oven
Bought a brand new whirlpool microwave/convection oven 2 months ago. Model GH7208XRS-1. Was using it to reheat food for 2 minutes. Food was not hot enough, so put it in for 1 more minute. When I closed the...
The first thing to try is a "hard reset". Unplug it from the power line for a minute, plug it back in, set the clock, then try again.
If it's still dead, since it's under warranty I would contact Whirlpool customer service for a free fix.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 12, 2008 | Whirlpool Microwave Ovens
Open Questions:
GE Microwave JVM1441BH04: Safe to reconnect replacement stirrer & turntable motors after accidentally burning out the turntable motor? GE JVM1441BH04 Over Stove Microwave: Tapping noise was coming from the 21v AC stirrer motor which sits atop the cooking chamber. I disconnected the two connecting leads, unfastened the single screw holding it on, placed in on my scanner glass to get a high rez photo of all the specifics listed on the motor label. Bad news: While waiting for the scan to finish, I warmed my coffee in the microwave on the highest heat for 30 seconds. I subsequently discovered the 21v AC turntable motor, which had been working just fine, was now no longer working, with infinite resistance across its terminals, and a burnt electrical smell. Both the stirrer and turntable motors are powered by a 24v tap off the magnetron fan. My theory: By running the microwave with the stirrer motor out of the circuit, I delivered excessive voltage to the turntable motor, which quickly fried. The 24v tap off the magnetron fan motor currently shows the correct 24v output. However, with both the stirrer motor and turntable motor disconnected, running the microwave for a few seconds shows approx 95v across the wire leads for both of the 21v motors. I have obtained replacement motors for both the noisy stirrer motor and the fried turntable motor. My question: Can I simply reconnect both motors in their proper locations, vow never again to run one without the other connected, and all will be well? Or will the newly installed motors simply be fried in a matter of seconds?
Jan 04, 2018 | GE Microwave Ovens
Microwave Ovens Logo
145 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
