Question about Wacom ArtZ II (UD2-0608S-PC) Graphic Tablet
Older ArtZ II with ADB cable won't talk to my laptop
I was given a UD-0608-A 6" X 8" ArtZ II tablet. It is apparently an older (late 90's) one with an ADB (Apple Desktop Bus) cable, not a USB or serial plug. I have the right ADB connector on my HP/Compaq NX9010 business laptop, but when plugged in and the driver/software (downloaded over internet) is run (setup) the 'on' light does not come on (won't work). Do I need an older software/driver since this one only has options for Serial and USB listed? Or will this only run on a MacIntosh computer?....Or is there a certain procedure or trick I need to follow ?
I'm thinking this is a Mac-only tablet. The ArtZ II for Windows came with an rs232 (old mouse) port at the end of the cable, in addition to a built-in spot where the power plug attaches.You didn't mention the power plug on yours, so the Mac version of the tablet must have the power routed in through the cable.
Short answer, the reason the light isn't coming on is because the tablet isn't receiving power. If you go get a cross-platform adapter card for plugging in Mac hardware on your HP, it *might* work.
Posted on Jan 24, 2009
Restart a tablet when it is locked
  • Connect the tablet with USB cable to the PC
  • Open the command prompt
  • Change directory to the android SDK platform tools (Type in cmd--> cd C:\Program Files\Android\android-sdk\platform-tools)
Type following commands in cmd
  • adb devices (verify device is identified by pc. If not reconnect device and try again)
  • adb shell
  • adb reboot
It will restart.
Feb 12, 2014 | Android 4.0 Tablet PC
Forgot pattern need to unlock
If you've already set up a Google Account on your tablet:
1. Try entering unlock patterns several times right in a row. It *should* ask you to enter your Google Account info as an alternative way of letting you in, after which you can turn off pattern locking or set a new pattern.
2. If you set up a Google Account and the tablet isn't asking you for that info you can try to unlock it from this page:
https://www.google.com/accounts/DisplayUnlockCaptcha (this might only work on hardware authorized by Google, I'm not sure)
Keep reading for more details.
3. BUTTONS! There is usually some combination of button presses on boot that can get you into a "reset" or "safe mode" where you can reset it. It varies from tablet to tablet, however. For example, on my Haipad M701-R when I flip the on/off switch off and then on, short press the "end/sleep/power" button and immediately press and hold the "Menu" button through the boot process I go into "Safe Mode."
Also, some APAD tablets have a small, unmarked hole on the side of them that you can stick a paper clip into and press a soft-reset button. No idea if that clears an unlock pattern though.
4. If those options don't work, or if you have not set up a Google Account (either because you bypassed it or you have a tablet without official Google apps on it) another option is to use ADB (Android Debug Bridge) to unlock it. Go to Google and download the Android SDK (if you haven't already) and install it. If you're on Windows you'll also need the USB drivers.
1. Plug the tablet into the computer via USB and turn it on/boot it up.
2. Open a Terminal/Console and change directories to your Android SDK /tools/ folder.
3. Enter ADB commands. On Windows these will be "adb.exe" and on Mac/Linux "./adb" - I'll just use "adb" below for simplicity:
Code:> adb devices
This will let you know if ADB can "see" and "talk to" the tablet. If you don't get any devices reported back check the USB cable, drivers (on Windows), and that the tablet didn't shut down on you. I should warn you, however, if the tablet didn't have "USB Debugging" turned on, this will not work. Assuming it reported back finding a device proceed:
Code:> adb -d shell # sqlite3 data/data/com.android.providers.settings/databases/settings.db sqlite> update system set value=0 where name='lock_pattern_autolock'; sqlite> .exit # exit > adb reboot
If all went well the tablet should now boot WITHOUT the pattern lock enabled!
It will probably ask you for account info again like the first time it was booted. You can bypass that by pressing in all four corners in sequence upper left, upper right, lower right, lower left (if I recall correctly). Once into the tablet perform an actual factory data reset or it will pester you for setup info EVERY time you boot it. Go to Privacy>Factory Data Reset>Reset
5. Last resort is to reflash the tablet. Without knowing SPECIFICALLY which tablet model you have, though, there's no way anyone could tell you how to flash it or where to get compatible firmware. Assuming you DO know what you have and where to get a compatible rom for it, check elsewhere on the forums for instructions on how to flash your specific tablet with that firmware. Once it is flashed the "drive" is wiped and reset so you'll have to
go through the "first run" setup again, but at least it won't have a pattern lock on it.
Jan 16, 2012 | Archos 70 Internet Tablet
WACOM GD-0608-U and Window 7
I had the same good results. Just clicked on Intros and Windows 7 to download the driver fro my model GD -0608-U tablet
Jan 17, 2010 | Wacom Intuos A4 Graphic Tablet
Can I connect my old Mac's ArtZ tablet to a new PC using ADB-to-USB adapter ?
You can try the Virtual Tablet Interface from Digitizer Technology: http://www.vtablet.com/
I haven't been able to get pressure sensitivity working in my drawing programs yet, but it does allow you to use the tablet in Windows 7.
Oct 06, 2009 | Wacom ArtZ II (UD2-0608S-PC) Graphic...
Using/Converting a serial/adb ArtPad II for PC?
Does the driver on the Wacom site work? I'm trying to do the same thing, but need administrative rights, so I haven't been able to attempt it. http://www.wacom.com/downloads/drivers.php
May 27, 2009 | Wacom ArtPad II (UD2-0405S-PC) Graphic...
Vista driver solution for Wacom ArtZ II Graphics Tablet?
Have you actually tried installing the XP driver in Vista? Sometimes that does work, so no harm in trying. Use the compatibility mode in Vista to install XP drivers to increase the chances of succeeding.
Apr 17, 2009 | Wacom ArtZ II (UD2-0608S-PC) Graphic...
Wacom artz II
maybe, go to manufacture web site see if they have a download for this model they may have discontuned the product..sorry..
Jul 08, 2008 | Wacom (PTZ930AC) Graphic Tablet
Im using a serial to usb connector to connect my artZ II tablet to my laptop..
Sorry, I figured it out, it was because the serial to usb adapter i was using needed a driver, and then my computer recognizes it as an extra serial port. So, during installation it needed to be searched for automatically from my serial ports.
May 12, 2008 | Wacom ArtZ II (UD2-0608S-PC) Graphic...
Open Questions:
Wacom ArtZ II (UD2-0608S-PC) Graphic Tablet Logo
758 people viewed this question
Top Wacom Computers & Internet Experts
toddmat
Level 1 Expert
jasbo
jasbo
William F. Bryant Jr
Level 1 Expert
Are you a Wacom Computer and Internet Expert? Answer questions, earn points and help others
