Question about Compaq Presario SR1810NX Sempron 3200+ 1.8 GHz Desktop PC ( Monitor Sold Separatley) (ER912AA)
No video i recently got a computer given to me its a Compact Sempron 3200+ the motherboard is a A8AE-LE i took it home messed with it a little bit and then hooked it up everything seems to run fine but there is no video so i figured the integrated was fried so then i dropped in a PCI video card expecting it to work and still nothing could it be my bios or even my motherboard and is there anyway to fix it i really like that motherboard :(
  • Debs
    Debs May 11, 2010
    when you say that you messed with it a little bit, before hooking it up, what did you mess about with?
  • Compaq Master
  • 2,158 Answers
Presario SR1810NX
what monitor.? name and model... vast exist... no all work.
test the monitor first on known good PC that is 1st 1st.
does the Monitor (its button) OSD screens work,, if not monitor is toasted (good power in) if monitor is 2001 relic, some have hidden inside, power saver clock (turn it off , using OSD screens)
no it's not your bios, like the www, myth loves to repeat, ad nausum
here is the correct mess order.
But BIOS screens are the 1st GOAL always,,,, your not there yet.
1: test the monitor first, on other PCs when sure its good move it to
the Presario SR1810NX (and a good known monitor)
2: turn the Presario SR1810NX , on, then see if all fans run
that means SKINS off, omg, the fans are packed in lint , omg2, the CPU fins on its heat sink are packed, bad. (a yearly event)
A CPU can overheat fast, if not able to stay cool.....
CPUs go slower or even halt if the they see massive heat rise.
(built in self preservation mode)
all fans must run and flow air, as the designer wanted. for sure.
then make sure the fan in the PSU runs, if yes, good. if not you lost 12vdc to the fan, bad PSU.
PC sounds to be working, yes?? what do you hear now? a key fact?
3:
push the CD/DVD eject button if it can not eject the PSU is dead.
there are more steps. lots more.
Even the HP service manual tells you how to test the PSU, read that?
http://pcdied.com/black-screen.html#DT-only
Posted on Jul 09, 2017
5 Suggested Answers
sandrew
  • 2961 Answers
SOURCE: graphic card
the pc you are using probably has onboard video and not a seperate dedicated AGP graphics card, which needs atleast 64MB of memory and T & L support, so check the card before you buy, if you already have an AGP card fitted it may not support T & L
Posted on Oct 01, 2007
Ownij
  • 67 Answers
SOURCE: Need to find the drivers
try asus.com
and for the realtek drivers..
http://www.majorgeeks.com/Realtek_AC97_Drivers_d4400.html
Posted on Apr 24, 2008
TampaNative
  • 778 Answers
SOURCE: compaq s6300nx no video output changed ram,powersupply, graphic c
Try a different monitor, or that monitor on a different PC.
Posted on Feb 12, 2009
joecoolvette
  • 5660 Answers
SOURCE: Compaq EVO 510 2.4GZ Motherboard Question
Motherboard was tested before shipping? Good.
Want you to know I wasn't trying to be a smart aleck with my statement.
I was trying to find out if the motherboard was removed from a computer, and the state of the motherboard was not known.
When a problem is stated on here, you never know the expertise of the person you're dealing with, most of the time.
I see I am dealing with someone who has intelligence, and knows their way around a computer. Good!
About Anti-Static Guidelines;
Your body carries Static electricity. Static will fry out computer hardware components. You may not even see it, or feel it.
It is suggested to work on a table, and if the table is sitting on a carpeted floor, to refrain from swinging your feet back, and forth.
After unplugging the computer from power, and opening the computer case, Touch the metal frame.
This will relieve Static from your body. If you get up for any reason, leave, then return, Touch the metal frame again.
Touch the metal frame before you handle any computer hardware parts, and especially the Processor.
(Refrain from touching the Processor's pins on bottom. Handle the Processor by the case. Refrain from touching the gold plated contact pins, on the bottom of a ram stick. Anywhere else is fine. The body of the ram stick is coated with a see-through plastic)
Minimal wires connected?
1) Meaning only the Power On wires to the Front Panel header, on the motherboard? Excellent.
2) 20/24-pin ATX Power cable to motherboard? Excellent.
3) 4-pin ATX power cable to motherboard? Excellent.
(The 4-pin ATX square shaped connector. This power cable is the power for a Pentium 4 processor. Must be hooked up)
No harddrive power cable, nor interface cable attached
No CD/DVD drive/s power cable, nor interface cable attached.
No USB front panel cables attached.
Computer case fans, and processor fan hooked to power? Okay.
What Wattage does you Pentium 4 use?
Only thing that Compaq Support lists, is that one of the processor options is an Intel Pentium 4 processor, that operates at a maximum frequency rate of 2.4GigaHertz.
Doesn't state what architecture, nor Core, the processor is based upon.
It IS a Pentium 4, that uses a Socket 478 processor socket.
I know this, because a Pentium 4 that operates at 2.4GHz, only uses a Socket 478.
There were Five different models, of the Pentium 4 2.4GHz processor made.
Three of them were brought out in 2002, the year your computer came out.
They use the Northwood Core, and the 130NanoMeter architecture. (130nm)
All three used a maximum of 59.8 Watts
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_4_microprocessors#Northwood_.28130.C2.A0nm.29
How much does the motherboard use, is the question about asking how much Onboard, (Integrated), graphics uses for power.
Around 50 Watts.
Add Ram Memory, about 80 Watts.
Total without harddrive about 140 Watts.
Ram Memory installed, and Processor. You should get the BIOS POST screen. You may have to restart the computer up to 4 times.
If you are using a harddrive from another computer, this won't work.
The Windows operating system, has already logged the hardware from the computer it was previously installed in.
The DDR Sdram ram memory at 333MHz, has to be,
1) Non-ECC
2) Unbuffered
3) 2.5 Volt
4) Cas Latency of 2.5, or 3. (CL 2.5, or CL3. Ram Timings)
Maximum Amount for EACH ram slot is 1GB
Maximum TOTAL Amount is 2GB for the computer.
Always install the largest ram amount in Slot 1.
(DIMM 1 on motherboard)
The Processor 'Sees' Slot 1 first.
You are absolutely sure those power supply's are good?
Do you have any bad Electrolytic Capacitors on the motherboard?
Especially the one's that surround the Processor?
Capacitors that are close to the Processor are Voltage Regulators for the Processor.
The Processor must have a Clean, Steady, supply of Voltage.
A Processor has a VERY narrow tolerance range.
Information on Visual Signs of Bad Capacitors,
http://www.capacitorlab.com/visible-failures/index.htm
Posted on Jan 09, 2010
Testimonial: "I actually ended up using another motherboard..I tried everything i could think of and then some from this post no luck..."
Power button on sempron LE-1250 doesn't turn on
Check all cables and connections on Motherboard , if they are ok , the issue may well be the power pack
Feb 21, 2014 | AMD Sempron LE-1250 (SDH1250DWBOX)
I'm looking for chipset R5482 and 5B400 for an asustek A8ae-le main board. i could'nt find them on the hp site.
Hi There
The Motherboard model is not listed on Asus website. so click the mention link and read the answer.
Answer
Dec 12, 2011 | Chips Motherboard EATX Intel 5000P et,...
Hello, I recently Bought a "Asus A8AE-LE Amberinem" motherboard, I just can't figure out which wires goes where and there's just too many, all that I found was this ->...
Each of the wires coming from the front-panel of your computer ends with a labelled connector:
* HDD LED
* POWER (PWR)
* POWER LED (PWR LED)
* RESET (RST)
* SPEAKER (SPKR)
Each group of gold-pins on the motherboard is similarly labelled.
All you _really_ need to connect is the POWER and RESET buttons,
but it's nice to connect the other ones, too.
Dec 23, 2010 | Computers & Internet
AMD Sempron LE-1100 1.90GHz Processor sound drivers
?? You need the motherboard's / sound card driver, the CPU does not drive it directly. They are board specific.
Jun 19, 2010 | AMD Sempron LE-1100 1.90GHz Processor -...
Where i can find amd sempron(tm) LE-1200 drivers
Nowhere. Instead, find the device-drivers for the specific motherboard that you are using in conjunction with the AMD processor.
Apr 03, 2010 | AMD Sempron LE-1200 Processor (2.1GHz)...
I would like to have the manual for ASUS ABAE-LE Mother board
So would a lot of people.
This motherboard is not on the ASUS site, because it is an OEM board for HP/Compaq.
This is the manuals page for the HP A1428x:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=ie&lang=en&product=1843616&
This is the small user manual, such as it is, for the Compaq Presario SR1738NX:
http://h10032.www1.hp.com/ctg/Manual/c00311113.pdf
Here are the specifications for the A8AE-LE (AmberineM) motherboard.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00496280&lc=en&cc=us&dlc=&product=1831241
Here is the HP BIOS update site:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00007682&tmp_track_link=ot_recdoc/c00496280/en_us/c00007682/loc:4&lc=en&dlc=&cc=us&product=1831241
Here are the on-board audio drivers for the ASUS A8AE-LE:
http://mxdtr.com/a8ae-le-motherboard-driver-drivers-download.html
If that helps you, pass it on.
Jan 02, 2010 | ASUS Computers & Internet
My amd sempron le-1200 doesnt have any driver. where can i get drivers for it
processors are being supported by motherboard drivers. install or update your motherboard drivers and voila! You will have a supported le-1200. Hope to be of help to you.
Aug 29, 2009 | AMD Sempron LE-1200 Processor (2.1GHz)...
How can i download AMD Sempron Le-1150 Sound Drivers
You need to know the type motherboard you have (or system) to get the correct drivers. The drivers are dependent upon the motherboard and the chipset on it, not the CPU. If you have that information, I can help you.
Cheers
Nov 18, 2008 | AMD Sempron LE-1150 2.0GHz Processor -...
Upgrade motherboard?
Hello Keith,
The present Motherboard in your computer is Asus A8AE-LE. It has a lot of upgradign options.
It will support the Following CPUs.
Up to AMD Athlon64 X2 4800+
Up to AMD Athlon64 4000+
Up to AMD Sempron 3200+
Also, it has the following memory specifiations.
Memory Installed 1 GB (2 x 512)
Maximum allowed 4 GB* (4 x 1 GB) requires the replacement of the installed 512 MB DIMMs
Speed supported PC-3200 MB/sec
Type 184 pin, DDR SDRAM
DIMM slots Four
Open DIMM slots Two
And the PC has a PCI Express x16 slot you can install a high end Video Card along with a power supply upgrade.
So before you go ahead with replacing the motherboard I would recommend you to consider these options as we can cut down the cost to a greater extend and having the same iprovement on performance.
If you wish to upgrade the motherboard you can use any motherboard having ATX form factor [9.6 in X 9.6 in] in the computer. The CPUs should be selected according to the motherboard you have chosen.
Hope this helps
Pat
Mar 11, 2008 | Computers & Internet
Compaq Presario SR1810NX Sempron 3200+ 1.8 GHz Desktop PC ( Monitor Sold Separatley) (ER912AA) Logo
56 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
