Question about Sanyo VPC-S7 Digital Camera
Sanyo digital camera vpc-s670 lens errors
VPC-S670 Camera won't power down because of lens error 1114. Camera won't power up because of lense error 112. Lense remains open.
  • 1 more comment
  • littlesparky Dec 01, 2008
    Almost there. No more lens errors, but when I power off, the lense protrudes farther out. When I power on, the lense appears to TRY to retract.
    I tried recharging the batteries: no luck;
    I tried slight pressure to the lense: got rid of the lens errors.
    Recharged batteries: no luck;
    Held on/off button when powering up & powering off: no luck.
    I am a "Sir."
    Removed & recharged batteries overnight: no change.
    I'll look up for a service center. thx!
  • Sanyo Master
  • 586 Answers
    Actueally the lens zoom motor atart malfunctioning,And the solution is to replacement of the lens unit assymbally.For this contac any SANYO SERVICE CENTRE nearbby to get the lens assy and change it.
Thanks.
Posted on Dec 01, 2008
  • 10,594 Answers
Lens of camera is fried and camera needs lens assembly replacement but you might have to pay more then camera worth.
Ask an estimate from Sanyo Service for lens replacement or check lens assembly from Sanyo Parts Distributor on following website...
http://sanyoservice.com/partdistributors.htm
    Sergeant:
  • 237 Answers
Reset the camera...there should be a little pin hole, stick a paper clip in there, wait 10 seconds, and restart. This should fix the problem
    Sergeant:
  • 306 Answers
  • 1,879 Answers
Canned air
press it in
  • 162 Answers
The lens is faulty all right, blast it with canned air
  • 6,487 Answers
Try first to remove the battery for about 30 minutes then if still have the same problem you may need to dismantle the lens and clean it for some dirt stuck on it that is causing the problem, but if this is still under warranty better take it to servcie center and let them repair it for you for free..
  • Mark Gil
    Mark Gil Dec 02, 2008
    Yes a service center will the next good option that you can do for this problem,,,,
    Genius:
  • 1,011 Answers
Dear Sir/Madam,
it may just need to be re-set.Check the battery contacts. And use a fresh fully charged battery. try holding the off button for 3 to 5 seconds
thanks
good luck
Posted on Nov 25, 2008
  • Asfiya Ahamed
    Asfiya Ahamed Dec 01, 2008
    sir,
    taking out the SD card and turning on the camera without an SD card inserted. try formatting the SD card through the camera's setup menu. Better contact manufacturer for replacement....
    http://www.sanyoservice.com/
    thanks
    good luck
    Brigadier General:
  • 3,614 Answers
Try removing the battery off the unit.. fully charge the battery and put it back on..
keep us updated and let us know more about it.
  • Sanyo Master
  • 19,396 Answers
Try to push the lens gently inside while you turn camera off.
  • Ginko
    Ginko Nov 25, 2008
    The lense error 112 happens when lens gets stuck because of dirt, or because they are damaged after a shock.
    Try helping the lens back, without putting too muck force, if the camera had been exposed to sand or dust, try blowing canned air on the lens.
    If this does not work, the lens assembly must be taken apart completely and re-assembed, and for that you need a camera repair shop.
WHAT SIZE MEMORY CARD
The VPC-S670 works with MMC and SD cards, which max out at 2GB.
There are nonstandard SD cards up to 8GB in size, which may (or may not) work with the camera. But make sure it's an SD card, not an SDHC card. The camera will not work with SDHC cards.
Apr 18, 2014 | Sanyo VPC-S670 Digital Camera
I lost software to download pictures from camera to pc on my sanyo vpc-s670, dont know what to do now,
You don't need any software.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as Picasa.
Sep 24, 2012 | Sanyo VPC-S670 Digital Camera
WHEN I TURN POWER ON IT CUTS BACK OFF SAYING LENS ERROR 1114
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Feb 23, 2010 | Sanyo VPC-S670 Digital Camera
My Sanyo VPC S670 - digital camera lence is stuck
My camera had the same problem it would turn off after i tried to take a picture and it would say lens error 112 all i did was put duracell batteries in it as soon as i did it worked it seems wierd but try it its cheaper than getting a new camera
Jul 19, 2008 | Sanyo Xacti VPC-S60 Digital Camera
Sanyo VPC-S7 Digital Camera Logo
29 people viewed this question
Top Sanyo Cameras Experts
ray gallant
Are you a Sanyo Camera Expert? Answer questions, earn points and help others
