Question about HP PSC 1610 All-In-One InkJet Printer
Print Cartridge Carriage Stalled
I keep getting this error message on my HP PSC 1610 All-in-One printer. "The print cartridge carriage is stalled." It then tells me to open door, clear carriage jam and press ok. How do I clear the carriage jam?
  • Anonymous Jan 01, 2009
    I repeatedly get the message print cartridge stalled. I have to push the cartridge back and forth. I can see no jam or reason for it to stall
  • Anonymous Jan 05, 2009
    I have the same problem and the paper will not pick up as well
  • 679 Answers
SolutionStep one: Perform a power reset and connect the printer directly into the electrical outlet Remove all the paper loaded in the main input tray.Make sure that the product is turned off.
Disconnect the USB cable from the back of the product.
Disconnect the power cord from the product.
Disconnect the power cord from the electrical outlet and wait 10 seconds.
Reconnect the power cord directly into the electrical outlet and check for the following.
Make sure that the power cord used is the one provided with the product.
If a computer is connected to the product, make sure that the computer is connected to a grounded (three-prong) wall outlet.
Make sure that the power cord is firmly connected to both the product and the power supply.
Reconnect the power cord to the back of the product.
Press the power button ( ) to turn on the product.
Reconnect the USB cable to the back of the product.
If the issue is resolved, proceed to Step six: Print a self-test page.
If the issue continues, proceed to the next step.
for more information please go to below link>>
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458822&cc=us&lc=en&dlc=en
Thanks for using FixYa.
Posted on Feb 03, 2009
Check to make sure that your cartridges are installed properly. Make sure that they are clicked in.
Jul 16, 2012 | HP PSC 1610 All-In-One InkJet Printer
The print cartridge carriage is stalled on HP PSC 1610 All-in-one Printer. Carriage won't go all the way to the right because of a small toggle pin.
If you are tec guy. Open flat bed assm.. check the movement of carriage assm manually, see the obstruction, check service station.ensure that carriage should move freely..close it & check...
Sep 10, 2011 | HP PSC 1610 All-In-One InkJet Printer
I received a new printer today, I installed the software and ready to test print page. I get error message that the carriage is stalled. I found a procedure on HP web site that to fix problem, but it...
The printer may be faulty. I suggest you return it to the supplier to have it fixed or replaced under warranty. If you try to fix it yourself you may void your warranty.
Jul 14, 2011 | HP H470 InkJet Photo Printer
HP PSC 2355 try to print a document and receive an error "Print cartridge carriage is stalled " "Open door, clear carriage jam, and then press OK to continue." I tried this and there is...
This can be said as a bit complicated problem. This problem is exhibited by the printer when the cartridge carriage mechanism is getting stuck at some end. I should advice that you make sure that the SS ( Service Station ) of the printer is not jammed / clogged. If yes, try cleaning it. It is also caused when the motor is malfunctions and tries to move the carriage beyond the path that it should go.
It is best recommended that you consult an authorized HP Service person for the solution of this issue.
Thank you.
Mar 06, 2011 | HP PSC 2355 All-In-One InkJet Printer
Paper Jammed. Have appeared to remove all paper. But I keep getting "Carriage Jam, open door, clear carriage jam then pres OK" message. Message on my computer screen says "The print cartridge carriage is...
HP support has extensive documentation for both paper and carriage jams for your model:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00304007&lc=en&dlc=en&cc=us&lang=en&product=391182
I hope this helps!
Dec 10, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Cartridge carriage is stalled
Please let me know how install the ink cartridges blak and color.
Could I have a copyof manual pls
Apr 26, 2009 | HP PSC 1610 All-In-One InkJet Printer
Stalled printer cartridges
Sounds like an issue with the print carriage. When it's out of alignment and tries to print, it can make awful noises. HP.com has a web page that describes a number of troubleshooting steps when you have print carriage issues:
Carriage Jam Errors
There's also a related web page having to do with the noise coming from the printer:
Noisy Print Carriage
Hope this helps. Good luck.
Oct 07, 2008 | HP OfficeJet 4215 All-In-One InkJet...
Remove and checl color cartridge
The problem most likely is with the electrical contact between the color cartridge and print carriage. Even if you've replaced the cartridge, if the contacts on the carriage are still dirty, it won't make a good connection with the new cartridge and the error message will still appear.
Fortunately, the HP web site has a solution posted at the following link:
Cleaning Cartridge and Print Carriage Contacts
Good luck.
Sep 04, 2008 | HP PSC 1610 All-In-One InkJet Printer
Printer Cartridge Carriage stalled
i believe that u havent install all the latest uptades of the printer...!
u can find all the drivers HERE
dont forget to vote!!
Stratos
Nov 06, 2007 | HP PSC 1510 All-In-One InkJet Printer
Message Ink Cartridge stalled
the machine needs servicing, something is causing the carriage to stall
Nov 04, 2006 | HP PSC 1350 All-In-One Thermal Printer
HP PSC 1610 All-In-One InkJet Printer Logo
873 people viewed this question
Seeker5211
Seeker5211
