Question about Avaya Corded Phone avaparp18d
Programing Ayava partner - 18d Phone
I'm trying to change the default line that picks up when you want to make an outgoing call. How do I do that?
    New Friend:
I need to activate the ringer for tranfered calls, at the moment the transfers go straight to voice mail.
Posted on Jul 12, 2013
From extension 10 or 11
Press feature 00
LEFT INTERCOM
LEFT INTERCOM
RIGHT INTERCOM
Enter the extension number of the extension you need changed.
press ** (start, star)
then the order you want the lines to get picked up (if you want to grab line 4 then 3 then 2 then 1, upon going offhook, press "** line 4 line 3 line 2 line 1)
Then ** (star, star) when done
When finished, press feature 00 to get out of programming.
Posted on Jan 03, 2009
My company has an Avaya phone system that uses Partner 18d phones. When you pick out the receiver the phone would go to one of our 4 outside lines, but recently on ext. 10 when you pick up the receiver it...
http://dstech1.com/changing-the-line-that-is-picked-up-when-you-lift-handset/
All releases of Partner
Lets say that you currently pick up line 1 to make an outgoing call, but you want to pick up your last line (in this case we will say we have 6 phone lines).
This feature is called "Auto line select"
To program Auto line select:
From extension 10 or 11:
Press feature 00
LEFT INTERCOM
LEFT INTERCOM
RIGHT INTERCOM
Then the order you want the lines to get picked up
So, in this example I would enter my extension number (22) and press ** (star, star) and press line 6, line 5, line 4, line 3, line 2, and line 1. Then I press ** (start, star) to signify that I am done programming Auto Line Select. And feature 00 to get out of programming.
Easy as pie.
Aug 20, 2011 | Avaya 700340193 Corded Phone
Phone static on the partner 18d
Is it on the same line? What about when you call other extensions, is there static?
If it is a line, swap that line and another. If you have static on the same line port, then it is a port problem of the system. If it follows the dialtone, the line from the phone company is the problem.
Jan 14, 2010 | Avaya Partner 18 Eurostyle 18D telephone
When I pick up the receiver of my Lucent Partner 18D, it defaults to Line 4. How do I reset it so it will pick up Line 1?
Changing prime line access on a Partner system is done on either ext 10 or 11.
At one of those ext's press the feature key and "00"
Next press the left hand intercom twice
The display should say system programming
Press the right hand intercom once. The display should say Centralized Programming.
Enter in the extension number that you want to program.
Press ** then the lines in the order you want to access them.
press ** when your done the line access
Press feature "00" to logout
Jan 05, 2010 | Lucent PARTNER18 Corded Phone
Cannot change outgoing message on Lucent Partner 18D phone system
For an extension of the Main Automated Attendant greeting when callers call in.
Which voicemail do you have? You indicated the phone model, but not the voicemail model.
Jun 16, 2009 | Avaya Lucent Partner 616 Phone
This will need to be done at Extension 10 or 11.
Press Feature 00
Press LEFT intercom, LEFT intercom
Press right intercom. Display will ask for an extension number.
Enter the extension number you want to modify.
Now it should say "program ExtXX"
Press * * (STAR STAR)
then touch the lines in the order you want to pick them up, when finished entering the order....
PRESS * * (STAR STAR)
Then Press Feature 00 to exit programming.
Apr 30, 2009 | Avaya Corded Phone avaparp18d
Avaya 18D Change Number of Rings
Programming is done on extension 10 or 11
Press feature 00
Left intercom, Left intercom
#506
mode 1
line 01
number of rings 4
do the same for all lines
Cheers
Apr 13, 2009 | Avaya Corded Phone avaparp18d
Avaya 18D unable to make outgoing calls
Sounds like you changed your line selection. Changing line selection on a Partner system is done on either ext 10 or 11.
enter **
press the lit line in the order you want the to be used, i.e. line 2 then line 3 then line 4 etc.
enter ** when finished with line selection
Hope that helps
Mar 20, 2009 | Avaya Partner 18D Display Phone (315807BA)
My line one caller ID is not working, but my other lines are.
Partner gets caller id from a carrier. If you have a caller id service it will show on your 18D
Dec 09, 2008 | Lucent PARTNER18 Corded Phone
Avaya Partner 18D
Oops, the PC card version :-) Try 0# By default the password is 1234
Carl
Oct 10, 2008 | Avaya Corded Phone avaparp18d
Noise in system
Probably in the module. Switch to different port on module and see if it clears the problem
Jun 17, 2008 | AT&T Partner 18 Phone (315805B)
Avaya Corded Phone avaparp18d Logo
411 people viewed this question
Top Avaya Lands Phones Experts
Oloyede Monsuru
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you an Avaya Lands Phone Expert? Answer questions, earn points and help others
