Question about Whirlpool GU2400XTP Built-in Dishwasher
My dishwasher and dishes are turning brown!
Hi, my dishes, crystal glasses and all are turning brown from my dishwasher. The dishwasher itself turns brown, I have to use dishwasher cleaner on it at least once a month. What is causing this! My roommate and I have an ongoing argument, she says it's the liquid cascade, I say it's the water. She says she's had this dishwasher for years and it's never done this until I moved in and started using liquid. Help!
  • Anonymous Feb 15, 2009
    I am experiencing the same problem. We have a 3-year old dishwasher, and have recently started using liquid Cascade. We had been using the palmolive packs up to now. We have never experienced our dishwasher "browning" until recently. I honestly can attribute this to the new liquid soap we have been using. It's worth the shot to change your detergent.
    Sergeant:
    Champion:
  • 338 Answers
I believe this to be a sediment issue. detergent would turn the dishwasher black if it were left in there. however i would suggest using powder
Posted on Nov 26, 2008
Dishes come out with brown streaks. Likely cause ferrous water. Can citric acid crystals be used in the kitchenaid superba monterey 21 model. Would it damage the spray arm which is metallic? Used to...
You can use citric acid, Lemon Shine (Target) or even Glass Magic to the detergent to correct this problem. Just two tablespoons to detergent in the door is all you will need. Run a normal cycle with Hi-Temp option to get the best results.
If you do this on every load you should not have any more problems, Try this.... Its cheaper, is recommend by the manufacture of Finish..... Don't follow the direction on the box.....
Aug 27, 2011 | KitchenAid Dishwashers
My kelvinator dishwasher kd14ss leaves stains in my glasses cups and small bowls in the upper rack after each wash. Never used to do it before - turned up the rinse and check the salt, but after each wash...
It sounds like you need to check the filters and clean them. It’s usually pretty simple to do but makes the dishwasher run like new. I think that it might be obstructed somewhere preventing it from being able to fully rinse the dishes. Is it draining all the water after the cycle has finished?
Feb 03, 2018 | Kelvinator Dishwashers
Cloudy glasses My dishes are not being cleaned. There is a white residue on my glasses and in the dishwasher itself.
You may have hard water. Are you using a rinse aid, you always need to use one. Buy some Tang drink crystals and empty a package into the soap dispenser and run the dishwasher through empty. If you can't buy Tang use about 4-6 cups of white vinegar thrown in the bottom of the machine and run the cycle. Sometimes the white residue on the glasses is there permanently and can't be removed it is called "etching" right in the glass.
Jan 26, 2010 | Kenmore Elite 45986 Front Load Washer
After a wash cycle my unit leaves a film on my glass'
first thing you need to do is purchase a bottle of dishwaser cleaner from your groc store in the diswasher detergent section red the instructions on the label add it to the cutlery tray in an empty dishwasher upside down remove the paper seal off the top of the lid do not remove the wax seal place the bottle upside down in your dishwasher turn on hot water tap and run till it is hot next turn on your washer set it to wasn and let it run a full cycle. when washer finishes open it up when it cools and fill rinse dispenser in door with a good quality rinse agent like jet dry close dispenser and when dishwaser is full of dirty dishes turn it on the jet dry will make your galsses come out crystal clear w no film and the dishwaher cleaner will help all your dishes come cleaner.Use the dishwasher cleaner aroun 4-6 wekks it cleans all the inside of the dishwasher and removes a lot of **** aND RESIDUE THAT ACCUMULATES IN DISHWASHERS OVER TIME
Dec 17, 2009 | Dishwashers
Just bought home with Kenmore dishwasher. Know
Do you have the operating instructions for your dishwasher. If not, open the door and there should be a manufacturer's badge on the inside of the door somewhere. Find out what model machine you have. I can help you find a manual online.
A couple of general tips for your info.
  • Wipe or rinse excess food particles from dishes before you stack them in machine.
  • Stack neatly and spaced apart to give better wash results.
  • Make sure dishes and pot handles are clear of the sprinklers. Turn sprinklers by hand and make sure they dont hit against anything.
  • I prefer using dishwashing tablets as they are a measured amount. Best not to use too much soap or powder.
  • If you are using powder, use rinse aid along with it.
  • Dont put your crystals or good wine glasses in the dishwasher.
Hope this helps somewhat.
good luck.
Ash
Oct 23, 2009 | Kenmore 24 in. 16032 Built-in Dishwasher
The dishes are coming out all cloudy and seem to have a film on them. It is a powdery substance that will not wash off even by hand. It is ruining my dishes. It doesn't matter what soap I use.
Be sure to use a good quality detergent or tablet with rinse aid built in... but before that I would go buy a dishwasher cleaning solution. These are usually in a bottle and you just sit the bottle in the dishwasher by itself (with no other dishes) and run a normal washing cycle. The cleaner will clean the inside of the dishwasher, including the drain area and help produce cleaner dishes thereafter. This should be done every 3-4 months as standard.
Aug 19, 2009 | Whirlpool 24 in. Portable Dishwasher...
Dishes and glasses being etched; looking dirty; embarrassing
First of all, if you're talking about actual glass as opposed to crystal, glass can etch easily. Why? Because like crystal, there are variations in its quality. Cheap glass will etch faster with the use of an electric dishwasher compared to higher quality glass.
Did you know that the main constituent in most automatic electric dishwasher detergents is sodium hydroxide (lye) and chlorine bleach (another caustic acid)
A Bosch dishwasher has very long wash cycles, further exposing your dishes to the possibility of etching damage. You should stop using the sani-rinse cycle if there is such an option and switch to a gel format detergent as opposed to a powder. Use a rinse agent such as Jet-Dry. This should solve your etching problem.
Apr 23, 2009 | Bosch 24 in. SHY66C05 Stainless Steel...
Rinsing agent not dispensing
the problem is hard water. go to www.dishwasherfilter.com. they have a filter designed specifically for this problem. it filters the water going into your dishwasher leaving your dishes crystal clean with every load. it is very affordable and guaranteed to work.
Mar 18, 2009 | Dishwashers
Kenmore dishwasher 15899100
Dennis, Im assuming your model number starts with 665. This model had a service flash on it regarding the upper spray arm. The upper spray arm has been redesigned for better performance. Part number 8269022. This could be covered by Sears if you mention the service flash, 22-714. Other issues that can lead to this problem are; water hardness, if your water is over 7 grains of hardness, this could to this film on the glasses. Try pouring 1/4 cup of Glass Majic into the bottom of the dishwasher. Also run one cup of white vinegar to clean the dishwasher. Make sure the water temp. entering the dishwasher is 120 min. to 150 degrees. Catriver..post back.
Oct 30, 2006 | Kenmore 15899 Built-in Dishwasher
Whirlpool GU2400XTP Built-in Dishwasher Logo
1,268 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
